Bim2000 A-cat downhaul configuration #20704
06/10/03 03:59 AM
06/10/03 03:59 AM
Ljubljana, Slovenia
mayhem Offline OP
mayhem  Offline OP
Ljubljana, Slovenia
I am trying to return my boat back to the original configuration with the combination rig-tensioner and downhaul. The blocks inside the mast are ok, but what happens outside the mast?
I assume it pulls down the lever (attachning boom and adjusting rig tension), but is his 2:1 (block on lever and terminated at mast base) or direct to lever?
I assume the mainsail downhaul grommets are attached to this system. The 'hook' that forms the boom attachment point has a welded nut on the top. Is there some missing hardware that is used to pre-tension the downhaul to this lever?
Thanks,
Matt
Re: Bim2000 A-cat downhaul configuration [Re: mayhem] #20705
06/10/03 04:04 PM
06/10/03 04:04 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
We have 2 Bim2000s at the Rudder Club, Jacksonville, Florida, and we love them. In light air they are particularly fast to weather, which is 95% of the time here! We have not changed the factory setup. It has the U-shaped lever or "stirrup" downhauling the diamond wires, and the boom attaches over the "hook" on the tip of the stirrup. I attach a D-shackle through the hole in the hook, and run a line from it through a jam cleat to the clew of the main then back down to the jam cleat. One loop, 1:1. This could be doubled by using a double block above on the sail and a single block below for 4/1. When cleated and tied this keeps the same tension all day.
I think going to the mast base would not work.
see boat pix at www.rudderclub.com ...on the multihull page
Dacarls:
0 registered members (), 2,851 guests, and 162 spiders.
