Page 1 of 9 1 2 3 4 5 6 7 8 9
safe sailing #208121
04/13/10 08:21 AM
04/13/10 08:21 AM
pgp Offline OP
pgp  Offline OP
Downwind the spin throws up a giant blind spot and it's just a matter of time before someone gets hurt. There are a couple of "too close for comfort" stories going around with reliable witnesses in support.
Anyone for changing the right of way rules? I have it on good authority it can be done in the SI.
Pete Pollard
Blade 702
Re: safe sailing [Re: pgp] #208122
04/13/10 08:30 AM
04/13/10 08:30 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
What do you want to accomplish with the new rule, and how do you think it would best be accomplished?
Re: safe sailing [Re: ksurfer2] #208123
04/13/10 08:32 AM
04/13/10 08:32 AM
V
Ventucky Red Offline
V
What is the current ROW rule?
Re: safe sailing [Re: pgp] #208124
04/13/10 08:39 AM
04/13/10 08:39 AM
All spinnakers have the right of way all the time! Yeah!
(actually, spinnaker foots got a lot higher and are easier to see under than they were in the early 2000's.)
Re: safe sailing [Re: Ventucky Red] #208127
04/13/10 08:54 AM
04/13/10 08:54 AM
andrewscott
andrewscott
all helicopters and planes must yield to spinnaker flying beach cats...
I was going to say that i don't have any problems seeing the waterline with my spin out...
Re: safe sailing [Re: Jake] #208128
04/13/10 08:55 AM
04/13/10 08:55 AM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
If you want safe ,join a chess club. Pretty low accident rate.Or better yet PAY ATTENTION. How long have spinnakers been on boats? Nothing has changed.
Isak Dinesen
E. B. White
Re: safe sailing [Re: Jake] #208131
04/13/10 08:59 AM
04/13/10 08:59 AM
What Pete is looking for is something like what they use in iceboating, where the windward boat has the right of way when going off the wind (freedom to bear away in a puff).
It is possible to change Rule 11 in the SIs, although I've never seen the language they use for iceboating.
I think it opens up a whole new can of worms - that doesn't need opening. I've seen (and been in) a few close calls, but usually it's between a boat going upwind and a boat going downwind.
This would not prevent port / starboard situations from occurring between upwind / downwind boats, which is where most of the danger comes from.
Re: safe sailing [Re: mbounds] #208140
04/13/10 09:56 AM
04/13/10 09:56 AM
The "Problem" is the huge blind spot the spinnaker creates, which is even worse when sailing Uni, with no crew to look under it. I don't want to hit anyone, ever, and I often tack/gybe early to stay away from what could turn into a close call, even if that means going the -wrong way-for a 100 yards or so, but still there are times when you just cannot keep track of all the boats coming around the C mark and going upwind, while you are flying a hull with the spin up going downwind, especially when racing in mixed fleets.
There was that incident with the I 20 and Hobie Wave a while back, remember? Was that a "spinnaker induced" collision? I know I nearly took out an A cat last weekend, I only saw the top 1' of his mast over the top of my spin at the last second and was able to bear off to duck him. I don't know if he saw me coming or what he was going to do if I didn't. It could have been ugly! When it's blowing and the spray is flying, you cannot hear another boat hailing until they are nearly too close to miss.
I've always obeyed the golden rule when racing, "Do unto others as you would have them to unto you", or; "Payback's a Bitch!" so I don't intentionally push it, whether I'm the right of way boat going upwind or the spin boat coming down, a couple yards lost to a gybe or duck is not worth the time, money and mental anguish of a collision, not to mention you could be out for the rest of the regatta.
I would be in favor of some type of "Understanding" that when you are going upwind and you see a spin boat hauling butt in a huge puff comging down at you, you might want to assume he does NOT see you, and GTF Outa' the way!
I mean, that's just common sense, right? Unless you own a fiberglass repair company or an ambulance service...
Re: safe sailing [Re: Timbo] #208146
04/13/10 10:21 AM
04/13/10 10:21 AM
One rule I like is :
"No non-spi boat shall ever share the course with a spi-boats."
That is just asking for trouble especially when a non-spi boat is snaking about trying to do the wildthing.
Re: safe sailing [Re: Wouter] #208149
04/13/10 10:33 AM
04/13/10 10:33 AM
I have no problem with other boats going downwind while I'm going downwind, usually, because we are going nearly the same speed and we can usually see each other. It's when I'm running downwind and some guy is coming upwind, in my fleet or any other fleet.
Or maybe there was no problem when he rounded, but then he tacks, I never see him. Maybe he never saw me coming, or he thinks it won't be close, then a puff comes along and I've got to bear off deep...all of a sudden, it's a problem and I'm busy trying to keep it upright, not looking out below, in the blind spot the spinnaker causes.
Re: safe sailing [Re: Timbo] #208152
04/13/10 10:48 AM
04/13/10 10:48 AM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Originally Posted by Timbo
.... I'm busy trying to keep it upright, not looking out below, in the blind spot the spinnaker causes.
I've mentioned before, I'll mention again ... I have a blind spot REGARDLESS of the spinacker flying.
STAY CLEAR OF 733!!
USA 777
Re: safe sailing [Re: mbounds] #208154
04/13/10 11:00 AM
04/13/10 11:00 AM
pgp Offline OP
pgp  Offline OP
It isn't just me. Some people with impeccable credentials are very concerned.
The greatest danger is deemed to be after a spin boat clears the windward offset, bears away, and sails across the course of boats still on a beat.
I'll bring this matter up with the F16 class, those of you interested can PM me and I'll keep you in the loop.
Pete Pollard
Blade 702
Re: safe sailing [Re: Timbo] #208155
04/13/10 11:01 AM
04/13/10 11:01 AM
I'm with Wouter on this. And it's not just about spinnaker and non-spinnaker boats. It's more generally about fast boats and slow boats being on the same course. Especially downwind, where various speeds of boats and sail configurations are all sailing different angles downwind -- including some sailing straight downwind. And slow boats may see the collision coming, but they do not have the ability to get out of the way -- sort of like a manatee getting run over by a powerboat.
Re: safe sailing [Re: tback] #208156
04/13/10 11:07 AM
04/13/10 11:07 AM
brucat Offline
brucat  Offline
I respectfully disagree that it is possible to change RRS 11 with the SIs. RRS 86.1(b) states the specific rules that cannot be changed by SIs, and that refers to 86.1(a) which includes all Part 2 rules. And, RRS 11 is in Part 2.
I actually think this is a good thing, because Part 2 rules are really the fundamental rules that keep boats from going boom. As has been pointed out several times on this site, no one ever reads the SIs anyway, so trying to change this rule for a specific event (or series) could lead to a false sense of security, and more crashes caused by those who didn't know about the SI change.
There are enough other rules already, and besides common sense, those tell you to not hit another boat, no matter who has the right of way.
My rule of thumb has always been, if I can't see the other guy's eyes, he can't see me.
I've sailed on spinnaker boats, and they have certainly gotten better (higher off the water, etc.), but the onus is always on everyone to keep watch. If that doesn't work, avoid the collision, hail protest and figure it out later.
EDIT: Or, work to have the RRS changed...
Re: safe sailing [Re: brucat] #208162
04/13/10 11:27 AM
04/13/10 11:27 AM
Simple as that.
Isak Dinesen
E. B. White
Re: safe sailing [Re: brucat] #208169
04/13/10 11:52 AM
04/13/10 11:52 AM
Mike is correct regarding the Rules in Part 2 - I was shooting from the hip, thinking that ice boats used a modified RRS. They do not.
They have their own "Constitution and Racing Rules of the National Iceboat Authority". Those would not help in this situation, since the primary problem is the conflict between upwind / downwind boats.
Re: safe sailing [Re: mbounds] #208172
04/13/10 11:59 AM
04/13/10 11:59 AM
And still I remember there was one very experienced ice boater killed not too long ago when two of them came together at speed...
Be careful out there, and -never- assume the other guy see's you coming.
Re: safe sailing [Re: pgp] #208173
04/13/10 12:02 PM
04/13/10 12:02 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
In that case, the offset mark was set wrong!
The offset mark was introduced because of the concerns voiced in this thread. You should be able to bear off after the offset and not encounter any upwind boats until after your gybe.
Re: safe sailing [Re: TEAMVMG] #208175
04/13/10 12:04 PM
04/13/10 12:04 PM
that assumes you don't grossly overstand the left layline like some of us commonly do
Re: safe sailing [Re: waterbug_wpb] #208181
04/13/10 12:16 PM
04/13/10 12:16 PM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
The answer is: back to triangle courses. Or any non up-down course. It is also more fun.
0 registered members (), 2,582 guests, and 261 spiders.
