| Re: help re t foils
[Re: waynemarlow]
#208062 04/12/10 07:39 PM 04/12/10 07:39 PM |
Joined: Jul 2001 Posts: 953 Western Australia Stewart
Posts: 953 Western Australia | talk also with the International 14 guys. If you are sailing a skiff type boat this is the standard currently.
Also Bloodaxe in UK has a T foil for their Cherubs.
| | | Re: help re t foils
[Re: C2 Mike]
#208102 04/13/10 06:31 AM 04/13/10 06:31 AM |
Posts: 1,382 Essex, UK | On the early Stealth rudders the horizontal fin is about 12cm long each side of the rudder with a root width of about 5cm and they are symmetrical. The newer ones are much smaller with a fin length of about 9cm and a root of 5cm. I set mine up by adjusting the stock so that the fin is neutral with the boat very, very slightly bow down. This way I theorise that the T foil doesn't interfere until it absolutely needs to - maybe that's why there's that 'famous' picture of me with a bow wave at the mast base?????
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: help re t foils
[Re: Jalani]
#208104 04/13/10 07:11 AM 04/13/10 07:11 AM |
Posts: 5,525 | Has anyone ever put a lifting foil on the bow?
Pete Pollard Blade 702
| | | Re: help re t foils
[Re: pgp]
#208116 04/13/10 07:51 AM 04/13/10 07:51 AM |
Posts: 548 MERRITTISLAND, FL | Has anyone ever put a lifting foil on the bow? They made a lifting foil for the H16 to try and make it pitch pole proof - NOT You never have crashed as hard as you will when those things pass verticle. We broke both bows right off one trying this out. | | | Re: help re t foils
[Re: Matt M]
#208136 04/13/10 09:38 AM 04/13/10 09:38 AM |
Posts: 6,049 Sebring, Florida. | That's the big drawback to any -fixed- foils, front or rear, you cannot adjust the angle of attack so if you do go "nose down" you're going to go VERY nose down if it's on the front, or get a ton of drag if they are on the rudders.
I was not having a problem with nose diving at the NA's, as long as I saw the big puffs coming and bore off deep before they hit, ease the spin sheet out, etc. It was only when I overstood the gate and was trying to keep up high in the gusts that I was stuffing it to the mast.
BUT...Boca Ciega Bay is small and very lake like, we were not sailing downwind in big waves like you would have at any open water venue in 20knots of wind. I'm not sure T foils on the rudders would "save you" when surfing down a big wave anyway, you are going to stuff it to the mast when you hit the wave in front of you, no matter what!
Blade F16 #777
| | | Re: help re t foils
[Re: Timbo]
#208171 04/13/10 11:58 AM 04/13/10 11:58 AM |
Posts: 3,528 Looking for a Job, I got credi... | That's the big drawback to any -fixed- foils, front or rear, you cannot adjust the angle of attack so if you do go "nose down" you're going to go VERY nose down if it's on the front, or get a ton of drag if they are on the rudders. I do not "feel" a ton of drag when sailing with T's in the gusts; I get get more acceleration! IT IS important to understand what is happening with T's. As the bows dive; the T's SING the whole hull; you are balancing the pitching fore by opposing it at the back of the boat; all that can happen is the hull SINKS. Is there More drag than if they were not there? Yes; but you are not upside down or stuffing the front beam in the water and dumping power!!!! IMO T's allow you to drive the boat harder and so you over come the small amount of extra drag.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: help re t foils
[Re: macca]
#208264 04/13/10 11:49 PM 04/13/10 11:49 PM |
Joined: Feb 2004 Posts: 1,012 South Australia Darryl_Barrett
Posts: 1,012 South Australia | Quote "Just put a set of curved foils in, much better performance gain than T foils will ever be. Plus they are much easier to live with (launching etc)
Oh, hang on... this free and open development class doesn't allow them... Shame smile" end QUOTE
You really do shoot off your mouth sometimes giving inflammatory self indulgent opinions on subjects of which you have apparently no real knowledge or understanding, which I can only conclude is to either increase your sense of self importance, promote argument simply for the sake of argument, or to promote some self serving agenda. You certainly don’t, in my opinion, participate for the betterment of understanding, why is that? | | | Re: help re t foils
[Re: Darryl_Barrett]
#208266 04/14/10 12:38 AM 04/14/10 12:38 AM |
Posts: 586 Hobart, Tasmania, Oz. | I don't mean to be pedantic Darryl.. or maybe I do....
Either is an English pronoun, adjective, conjunction and adverb. As a pronoun or adjective it means one, or the other, of two choices.
you can't say either and give three choices!
Macca, you failed... the test by not reading the question. that is the OLDEST trick in the book!
482
guests, and 47
