| Modified Hobie on the water continiously ?? #208230 04/13/10 06:38 PM 04/13/10 06:38 PM |
Joined: Apr 2005 Posts: 53 The Netherlands, Europe flying_dutchman OP
Posts: 53 The Netherlands, Europe | Somewhat strange question on this forum. As H16 sailor I got an old, obsolete TheMightyHobie18 hull to be modified into a motorized instruction cat for my rowing club. To avoid having to take this cat (with outboard engine, fuel tank, seats etc.) out of the water each time however they intend to leave the cat in the water permanently. As H16 sailer I am used to "some" water in my hulls although they are only on the water for a couple of hours. Should we take special precautions to prepare the hulls of this old TheMightyHobie18 ??
Happy sailing from The Netherlands!
Eddie
Hobie 16 (1992) # 99173 & CT11 - with spi
| | | Re: Modified Hobie on the water continiously ??
[Re: flying_dutchman]
#208310 04/14/10 10:11 AM 04/14/10 10:11 AM |
Posts: 921 Alachua, FL | Should we take special precautions to prepare the hulls of this old TheMightyHobie18 ?? You should be OK. Make sure the drain plugs are in tight with new O-rings. The hulls and platform flex more when sailing and that allows tiny leaks to open up that allow water in, especially when they go under water. These joints and such will not be under much flex pressure in your situation.
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: Modified Hobie on the water continiously ??
[Re: hobie1616]
#210406 05/06/10 03:37 PM 05/06/10 03:37 PM |
Posts: 493 Minnesota | Yeah, you want to check the bottom. If there is significant wear, you may have pin holes. Skim it with a layer of resin; cure; then paint. If the gelcoat is intact, no problem.
361
guests, and 45
