Modified Hobie on the water continiously ?? #208230
04/13/10 06:38 PM
04/13/10 06:38 PM
The Netherlands, Europe
flying_dutchman Offline OP
Somewhat strange question on this forum. As H16 sailor I got an old, obsolete TheMightyHobie18 hull to be modified into a motorized instruction cat for my rowing club.
To avoid having to take this cat (with outboard engine, fuel tank, seats etc.) out of the water each time however they intend to leave the cat in the water permanently.
As H16 sailer I am used to "some" water in my hulls although they are only on the water for a couple of hours. Should we take special precautions to prepare the hulls of this old TheMightyHobie18 ??
Happy sailing from The Netherlands!
Eddie
Hobie 16 (1992) # 99173 & CT11 - with spi
Re: Modified Hobie on the water continiously ?? [Re: flying_dutchman] #208310
04/14/10 10:11 AM
04/14/10 10:11 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
You should be OK.
Make sure the drain plugs are in tight with new O-rings.
The hulls and platform flex more when sailing and that allows tiny leaks to open up that allow water in, especially when they go under water.
These joints and such will not be under much flex pressure in your situation.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Alachua FL/Put-In-Bay
Re: Modified Hobie on the water continiously ?? [Re: Mugrace72] #208322
04/14/10 10:48 AM
04/14/10 10:48 AM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Bottom paint wouldn't hurt.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Modified Hobie on the water continiously ?? [Re: flying_dutchman] #208872
04/19/10 11:28 AM
04/19/10 11:28 AM
srm Offline
srm  Offline
The portholes on the TheMightyHobie18 make it very convenient to get water out of the hulls while afloat. Just keep a large sponge on board and pop the porthole open before going out to get the water out. When racing, we do this after each race to keep the boat light.
sm
Re: Modified Hobie on the water continiously ?? [Re: hobie1616] #210406
05/06/10 03:37 PM
05/06/10 03:37 PM
Minnesota
Jeff Peterson Offline
Minnesota
Yeah, you want to check the bottom. If there is significant wear, you may have pin holes. Skim it with a layer of resin; cure; then paint. If the gelcoat is intact, no problem.
Jeff Peterson
H-16 Sail #23721
Big Marine Lake, MN
Re: Modified Hobie on the water continiously ?? [Re: Jeff Peterson] #219160
09/10/10 08:17 AM
09/10/10 08:17 AM
FL
sail7seas Offline
sail7seas  Offline
FL
My guess is was in the 60's when resin was impervious to water.
Something changed it was not until say the 2000's when monohulls
started using Vinlyester resin, or whatever to resist blistering.
If you want to keep you boat in the water, and want to prevent blistering,
I recommend 5 coats of VC17 bottom coat expoxy to seal the gelcoat.
I tried 1 coat not following manufature's instructions and it blistered again.
Re: Modified Hobie on the water continiously ?? [Re: sail7seas] #219204
09/10/10 12:56 PM
09/10/10 12:56 PM
California
mmiller Offline
mmiller  Offline
California
All gel coat will blister if left in water over long periods. Nothing has really changed on that that I am aware of. Bottom paint is required for in the water storage.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
0 registered members (), 407 guests, and 47 spiders.
