H-16 Crossbar Cracked #209097
04/21/10 06:25 PM
04/21/10 06:25 PM
Mesa, Arizona
RickInMesa Offline OP
Mesa, Arizona
Last year, a thunderstorm tossed my 1971 H-16 and caused quite a bit of damage. I discovered a large crack yesterday in the front crossbar, just inboard of the starboard casting. It runs through a jib track rivet, and goes 3/4 of the way around the bar. Obviously, I won't be sailing until this is fixed.
I'm located in Tempe, Arizona, and I'm interested in replacing the crossbar with a used one. If anyone has an old H-16 front crossbar for sale, let me know. I understand that shipping one of these might be pricey.
I'm planning to remove the tramp, remove the striker, and then drill out the rivets in the castings. I have a heavy-duty manual rivet puller, but will this serve for the massive SS rivets that hold these parts together?
If anyone has gone through this, I'd appreciate any tips and tricks to doing the job right. Thanks!
Rick
<< cross-posted from H-16 forum, to reach a broader audience >>
Re: H-16 Crossbar Cracked [Re: RickInMesa] #209130
04/21/10 10:16 PM
04/21/10 10:16 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
Try Jeremy at Surf City Catamarans.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: H-16 Crossbar Cracked [Re: F-18 5150] #209132
04/21/10 10:27 PM
04/21/10 10:27 PM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
Can you pull the rivets out fairly easily? Yes. The big thing is YOU HAVE to remove the castings from the hulls (at least that's the way I did it). These castings are very brittle and liable to crack when doing this procedure; my best idea is to squirt your favorite corrosion eater between the castings and the posts on the hulls, then gently pull or tap the castings of the hulls. I'm sure others have done this more than I have and have some other tips.
Scorpion F18
Re: H-16 Crossbar Cracked [Re: samc99us] #209136
04/21/10 10:38 PM
04/21/10 10:38 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
I've got a stack of those laying around. I would just remove the crossbar from the hulls and replace the whole thing as one unit. Sometimes the x bars are too difficult to remove from the castings.
Re: H-16 Crossbar Cracked [Re: SurfCityRacing] #209189
04/22/10 11:34 AM
04/22/10 11:34 AM
brucat Offline
brucat  Offline
100% agree with Jeremy. It should be just bolted to the hull posts, unless someone glued/epoxied it at some point...
Dealers often have tons of these parts lying around when they get rid of old boats with bad hulls. Someone always needs crossbars or castings.
Re: H-16 Crossbar Cracked [Re: samc99us] #209242
04/22/10 02:23 PM
04/22/10 02:23 PM
Mesa, Arizona
Mesa, Arizona
Thanks for the tip about the brittle corner castings. I'll watch those closely.
Rick
Re: H-16 Crossbar Cracked [Re: RickInMesa] #209243
04/22/10 02:27 PM
04/22/10 02:27 PM
andrewscott
andrewscott
Just drive it to Santa Cruz and let Jeremy do it for you... smile
Re: H-16 Crossbar Cracked [Re: RickInMesa] #209247
04/22/10 02:37 PM
04/22/10 02:37 PM
Mesa, Arizona
Mesa, Arizona
It looks like I'll be able to get a whole assembly from Jeremy and have it shipped for a VERY reasonable cost. I'm encouraged by the fact that I'm not the first Hobie owner to go through this. I sure appreciate the tips and referrals!
Thanks, all.
Rick
Re: H-16 Crossbar Cracked [Re: RickInMesa] #209465
04/25/10 03:24 AM
04/25/10 03:24 AM
Bernhards Bay, N.Y.
popeyez7 Offline
popeyez7  Offline
Bernhards Bay, N.Y.
I've done it a few times... cracked the first one I took off.... buy a rubber mallet, if ya don't have one use a short 2x4... don't hit to hard, taps will do it. A few cuss words help
~~Don't fear the ''SPEED''~~ Fear the''ADDICTION''
~17,18 Hobies,
~Jet boat~Speedster 150
~2 Kayaks~
~~~~VIETNAM VET. 69-71~~~~
Re: H-16 Crossbar Cracked [Re: popeyez7] #209470
04/25/10 09:12 AM
04/25/10 09:12 AM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
I agree with popeyez always cuss first and have beer then you have that part over with.
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
1 registered members (vasil), 512 guests, and 31 spiders.
