Re: material [Re: waterbug_wpb] #209526
04/26/10 10:34 AM
04/26/10 10:34 AM
pgp Offline OP
pgp  Offline OP
Then the deck would weigh more than the boat.
Pete Pollard
Blade 702
Re: material [Re: pgp] #209567
04/26/10 04:26 PM
04/26/10 04:26 PM
Pete,
If you are re-decking your tri I'd use ply. 3 coats epoxy each side making sure you remove any amine blush between coats and a layer of glass on the outside to prevent the grain from opening up and letting water in. I expect the deck would then outlast the both of us.
Re: material [Re: phill] #209572
04/26/10 06:43 PM
04/26/10 06:43 PM
pgp Offline OP
pgp  Offline OP
It's a thought. Problem is that the deck comes in three pieces for trailering and they're a pita to store.
Pete Pollard
Blade 702
Re: material [Re: pgp] #210058
05/02/10 09:14 AM
05/02/10 09:14 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Pete,
You might look into foam core instead of plywood. Corecell foam comes in various thicknesses and will bend in a radius similiar to plywood, and can be worked easily. Cover with glass or carbon or whatever and you have marine friendly part.
Lighter than wood, wont ever rot.
Bill
Re: material [Re: Kevin Cook] #210104
05/03/10 04:06 AM
05/03/10 04:06 AM
ncik Offline
ncik  Offline
http://perverted-moth.blogspot.com/
flat pack, carbon & foam, foiling moth hull
yeah, the taping laminates were a pain on such a small boat. not the laminating itself but the fairing. would consider laminating L's to slide between the skins instead next time.
The flat pack parts were surprisingly flexible.
0 registered members (), 3,537 guests, and 1,449 spiders.
