Re: material [Re: waterbug_wpb] #209526
04/26/10 10:34 AM
04/26/10 10:34 AM
pgp Offline OP
pgp  Offline OP
Then the deck would weigh more than the boat.
Pete Pollard
Blade 702
Re: material [Re: pgp] #209567
04/26/10 04:26 PM
04/26/10 04:26 PM
Pete,
If you are re-decking your tri I'd use ply. 3 coats epoxy each side making sure you remove any amine blush between coats and a layer of glass on the outside to prevent the grain from opening up and letting water in. I expect the deck would then outlast the both of us.
Re: material [Re: phill] #209572
04/26/10 06:43 PM
04/26/10 06:43 PM
pgp Offline OP
pgp  Offline OP
It's a thought. Problem is that the deck comes in three pieces for trailering and they're a pita to store.
Pete Pollard
Blade 702
Re: material [Re: pgp] #210058
05/02/10 09:14 AM
05/02/10 09:14 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Pete,
You might look into foam core instead of plywood. Corecell foam comes in various thicknesses and will bend in a radius similiar to plywood, and can be worked easily. Cover with glass or carbon or whatever and you have marine friendly part.
Lighter than wood, wont ever rot.
Bill
Re: material [Re: Kevin Cook] #210104
05/03/10 04:06 AM
05/03/10 04:06 AM
ncik Offline
ncik  Offline
http://perverted-moth.blogspot.com/
flat pack, carbon & foam, foiling moth hull
yeah, the taping laminates were a pain on such a small boat. not the laminating itself but the fairing. would consider laminating L's to slide between the skins instead next time.
The flat pack parts were surprisingly flexible.
Most Online22,490
Yesterday at 08:14 AM
