Do you fear the turtle? #210212
05/04/10 11:21 AM
05/04/10 11:21 AM
JJ_ Offline OP
JJ_  Offline OP
Just curious.
Do you?
The swimming or embarrassment is not so much of problem. Probable cost of damage to mast and sails and other rigging in water under 30' is.
Even an "unflippable" Farrier tri has.
Do you see a need for mast tip flotation when you are not racing?
Many monohull classes preach the need for mast flotation but cat sailors not as much that I can see.
Hobie's Bobs overrule any turtle worries, but they don't fit on all brands. Even though they appear on other brands...
The thought of mounting more hardware to the mast end seems messy.
Re: Do you fear the turtle? [Re: JJ_] #210215
05/04/10 11:35 AM
05/04/10 11:35 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Seal your mast and a "hobie bob" isn't necessary.
Re: Do you fear the turtle? [Re: ThunderMuffin] #210218
05/04/10 11:51 AM
05/04/10 11:51 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
No Tad that is not correct. If you stick it hard in choppy seas going downwind you will turtle quickly regardless of how well your mast is sealed.
F18 USA 242
http://www.solarwind.solar
Re: Do you fear the turtle? [Re: David Ingram] #210220
05/04/10 11:55 AM
05/04/10 11:55 AM
brucat Offline
brucat  Offline
Putting your weight in the wrong place (intentionally or not) will also cause turtling.
I can't imagine why a Hobie Bob couldn't be made to fit on any mast of any boat, it should be just a matter of adapting a bracket.
Re: Do you fear the turtle? [Re: JJ_] #210221
05/04/10 12:09 PM
05/04/10 12:09 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
It is also a positive safety issue to be able to invert the boat.
If there is a capsize and one of the crew gets separated from his boat that is now doing 5 knots on its side, the crew should force the turtle to allow him to swim to the boat.
It may also be preferable to be on a turtled boat in an extreme weather event like hailstones or lightening, or if one of the crew is badly injured or needs picking up from a chopper.
Always look on the bright side hey?
Re: Do you fear the turtle? [Re: TEAMVMG] #210222
05/04/10 12:40 PM
05/04/10 12:40 PM
IndyWave Offline
IndyWave  Offline
Are you a Turtle?
What - Me Worry?
2006 Hobie Wave 7358
"Ish Kabibble"
Re: Do you fear the turtle? [Re: IndyWave] #210230
05/04/10 02:13 PM
05/04/10 02:13 PM
DHO Offline
DHO  Offline
Maybe what you need is an easiy removable Hobie Bob. If you need to turtle, you can swim out to the mast head and remove it.
Re: Do you fear the turtle? [Re: DHO] #210231
05/04/10 02:24 PM
05/04/10 02:24 PM
or that inflatable system that you can choose to deploy or not...
Re: Do you fear the turtle? [Re: waterbug_wpb] #210233
05/04/10 02:32 PM
05/04/10 02:32 PM
andrewscott
andrewscott
or one of these
Re: Do you fear the turtle? [Re: IndyWave] #210235
05/04/10 02:54 PM
05/04/10 02:54 PM
RickWhite Offline
RickWhite  Offline
Are you a Turtle?
"Bet your sweet a$$"
Willing to bet not many folks know about that one.
Rick
Rick White
www.onlinemarinestore.com
Re: Do you fear the turtle? [Re: IndyWave] #210237
05/04/10 03:09 PM
05/04/10 03:09 PM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
Originally Posted by IndyWave
Are you a Turtle?
Only when its cold. grin
Re: Do you fear the turtle? [Re: ksurfer2] #210240
05/04/10 03:28 PM
05/04/10 03:28 PM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
Only the "Snapping" varity ..... but they do make good soup!!!
Harry
Re: Do you fear the turtle? [Re: JJ_] #210242
05/04/10 04:13 PM
05/04/10 04:13 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
Just the peeking variety.
Re: Do you fear the turtle? [Re: RickWhite] #210248
05/04/10 07:12 PM
05/04/10 07:12 PM
JJ_ Offline OP
JJ_  Offline OP
Rick
I'll bite. How much of a turtle/terrapin were you?
So, J, dude, changed a few Huggies, eh?
Re: Do you fear the turtle? [Re: JJ_] #210249
05/04/10 07:37 PM
05/04/10 07:37 PM
Lake Murray SC
FasterDamnit Offline
Lake Murray SC
Trogg yes. Turtle, no.
E-Scow
24' ULDB
I like turtles [Re: FasterDamnit] #210252
05/04/10 08:11 PM
05/04/10 08:11 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: I like turtles [Re: arbo06] #210258
05/04/10 10:19 PM
05/04/10 10:19 PM
Re: I like turtles [Re: Jake] #210263
05/05/10 01:31 AM
05/05/10 01:31 AM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
My friend hit a turtle with his nacra 5.8 in northern QLD. split the bow wide open... good reason to fear the turtle!
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: Do you fear the turtle? [Re: RickWhite] #210273
05/05/10 05:56 AM
05/05/10 05:56 AM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
Many years ago when racing a Prindle 16 a sailor named Jim Pate taught me a very good trick. We had gone over during a race (not a pitchpole) to the weather mark. He instructed me to help him turn the boat to a turtle position and continue to right the boat, actually doing a 360. The result was when the boat was righted we were going in the proper direction on the same tack as before the flip and did not lose as much time or distance as we would have if we turned the boat while it was on its side into the wind to right and then tack or gybe to head back toward the weather mark. I was surprised how easy and quick this worked. Not sure if it would work with the newer high tech cats. We were in the Pacific Ocean so we had plenty of water to accomplish this.
Re: Do you fear the turtle? [Re: RickWhite] #210280
05/05/10 07:02 AM
05/05/10 07:02 AM
IndyWave Offline
IndyWave  Offline
Originally Posted by RickWhite
Are you a Turtle?
Rick
I'll buy you a beer Rick!
What - Me Worry?
"Ish Kabibble"
0 registered members (), 2,368 guests, and 417 spiders.
Yesterday at 10:10 AM
