| Do you fear the turtle? #210212 05/04/10 11:21 AM 05/04/10 11:21 AM |
Posts: 235 | Just curious. Do you? The swimming or embarrassment is not so much of problem. Probable cost of damage to mast and sails and other rigging in water under 30' is. Even an "unflippable" Farrier tri has.Do you see a need for mast tip flotation when you are not racing? ![[Linked Image]](http://www.mustoskiff.com/images/other-page-pics/mast-head-float.jpg) Many monohull classes preach the need for mast flotation but cat sailors not as much that I can see. Hobie's Bobs overrule any turtle worries, but they don't fit on all brands. Even though they appear on other brands... ![[Linked Image]](http://i4.photobucket.com/albums/y135/Pandabonium/seven/IMGP03312.jpg) The thought of mounting more hardware to the mast end seems messy. | | | Re: Do you fear the turtle?
[Re: ThunderMuffin]
#210218 05/04/10 11:51 AM 05/04/10 11:51 AM |
Posts: 3,906 Clermont, FL, USA | Seal your mast and a "hobie bob" isn't necessary. No Tad that is not correct. If you stick it hard in choppy seas going downwind you will turtle quickly regardless of how well your mast is sealed.
[Re: JJ_]
#210221 05/04/10 12:09 PM 05/04/10 12:09 PM |
Posts: 1,203 uk | It is also a positive safety issue to be able to invert the boat.
If there is a capsize and one of the crew gets separated from his boat that is now doing 5 knots on its side, the crew should force the turtle to allow him to swim to the boat.
It may also be preferable to be on a turtled boat in an extreme weather event like hailstones or lightening, or if one of the crew is badly injured or needs picking up from a chopper.
Always look on the bright side hey?
[Re: DHO]
#210231 05/04/10 02:24 PM 05/04/10 02:24 PM |
Posts: 5,590 Naples, FL | or that inflatable system that you can choose to deploy or not...
[Re: waterbug_wpb]
#210233 05/04/10 02:32 PM 05/04/10 02:32 PM | andrewscott
| andrewscott
Unregistered | or one of these | | | Re: Do you fear the turtle?
[Re: RickWhite]
#210248 05/04/10 07:12 PM 05/04/10 07:12 PM |
Posts: 235 | Willing to bet not many folks know about that one. Rick I'll bite. How much of a turtle/terrapin were you? So, J, dude, changed a few Huggies, eh?
| | | Re: I like turtles
#210263 05/05/10 01:31 AM 05/05/10 01:31 AM |
Posts: 586 Hobart, Tasmania, Oz. | My friend hit a turtle with his nacra 5.8 in northern QLD. split the bow wide open... good reason to fear the turtle!
2,646
guests, and 612
