Replacing mast base - Silicone ??? #21065
06/17/03 01:14 PM
06/17/03 01:14 PM
Durham, North Carolina
jwrobie Offline OP
jwrobie  Offline OP
I am replacing the mast base, and I want to make sure the mast is watertight. Someone suggested I use silicone - what kind is best? One person said aquarium sealant would be good....
Jonathan
Re: Replacing mast base - Silicone ??? [Re: jwrobie] #21066
06/17/03 02:11 PM
06/17/03 02:11 PM
if you're going to use sealant, get a marine grade sealant like 3M 5200.
Make sure clean the surfaces really well before you apply too.
Re: Replacing mast base - Silicone ??? [Re: jwrobie] #21067
06/17/03 03:37 PM
06/17/03 03:37 PM
Charleston SC
h17windbtch6333 Offline
Charleston SC
This may not be necessary since the base of the mast won't be in the water during a capsize. And if it is you have more serious problems than water in the mast. If some water gets in the mast from the top of the pole during a capsize an unsealed base would drain water after righted. by the way: why are you replacing it? last thursday when I was 'sick' I went sailing instead of work(the conditions happened to be perfect). I was lowering the mast and one of the holes that the pin goes thru broke off. I am stilled pissed about that. It was a relative new $69 part. Do you h17 guys rotate the mast 90 degrees or 180 degrees when lowering the mast?
Re: Replacing mast base - Silicone ??? [Re: h17windbtch6333] #21068
06/17/03 03:52 PM
06/17/03 03:52 PM
90 degrees.
and I have an extra mast base laying around here somewhere that I'd sell for half of what hobie wants for a new one.
Re: Replacing mast base - Silicone ??? [Re: h17windbtch6333] #21069
06/17/03 04:38 PM
06/17/03 04:38 PM
if your boat goes turtle, you will quickly appreciate the fact that the bottom of your mast is sealed.
0 registered members (), 285 guests, and 47 spiders.
