Pointing on a Nacra 6.0NA #21116
06/18/03 09:24 AM
06/18/03 09:24 AM
Northern Virginia
SoggyCheetoh Offline OP
Northern Virginia
I'm hoping some fellow 6.0 sailors came help me out on this one. I race in a mixed fleet of Hobie 20's, A-cats, Nacra 5.8's and Inter 20's. I've been racing my 6.0 for a couple of months now (on a weekly basis) and have been very happy with how this boat sails. However, I've got some pointing issues. If I try and sail as high as the Hobie 20's or the other Nacra's she just falls on her face (really slow)but if I fall off about 5 degrees she really comes alive and takes off. Of course now I have to sail a lot of extra distance to the windward mark, so my extra speed is being eaten up by the extra distance. I feel like I must have something set wrong, but I can't figure out what it is. What kind of mast rake should I have on it? What other types of adjustments might improve my pointing ability.
Any advice would be greatly appreciated.
Alec D.
Pirates of the Chesapeake www.teampiratesofthechesapeake.com
Nacra20 1057 - Crew
F16 Viper 152 - Uni
Re: Pointing on a Nacra 6.0NA [Re: SoggyCheetoh] #21117
06/18/03 10:40 AM
06/18/03 10:40 AM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
Try sheeting your main harder. Sheet your main in and steer up with it until the top leeward teltale starts to break. Then let out an inch and sail it. If your crew weight is high this will also effect pointing ability.
Whatever you do don't try to point with other boats. People always ask me how I get my boat to point so high. I always say that I never try to point. I'm always looking to foot. In other words pointing high comes naturally with going fast. The faster you go the higher you point.
Mike Hill
H20 #791
Mike Hill
N20 #1005
Re: Pointing on a Nacra 6.0NA [Re: SoggyCheetoh] #21118
06/18/03 11:02 AM
06/18/03 11:02 AM
Usually the problem is that you are not sheeting the main hard enough. It is common to think that you have the main sheeted in tight, but if someone is following you behind your boat, they can see that the leech is falling way off.
The other usual problem is that the jib is sheeted too tight or is being sheeted from the wrong sheeting point, so it is backwinding the main.
Or it could be that you don't have your outhaul on the main tight enough or that you don't have the correct mast rotation (pointed toward the leeward sidestay).
Re: Pointing on a Nacra 6.0NA [Re: SoggyCheetoh] #21119
06/18/03 12:16 PM
06/18/03 12:16 PM
Alec,
I too am having the same kind of problems. Nigel Pitt gave me some pointers a while back and said that you can't try and point this boat. That big jib just won't do it. "You gotta let the big dog eat". Besides the major points in the tuning guides, I've since found that getting the boat bow down upwind helps a lot and keeping the jib slot open is critical. I've raked the mast all over the place and STILL can't feel much difference.
I've been relatively competitive with the 6.0's I've raced against so far but I too am getting schooled by Hobie 20's around the buoys. In my defense, my sails have something like 1700 miles on them (x-worrell sails at least once and the previous owner and I have sailed the snot out of 'em). However, I have a new set sprawled across my pool table as we speak and I'll let you know how that turns out!
There's a tuning guide on catsailor by Jamie Diamond you might want to look at and you may want to join the N6.0NA forum as well. Links below:
Jamie Diamond tuning guide
Yahoo N6.0 group
Re: Pointing on a Nacra 6.0NA [Re: SoggyCheetoh] #21120
06/18/03 12:53 PM
06/18/03 12:53 PM
Bow down - my skipper and I are right at minimum, and in light to medium air, we're sheeted right (not just tight) and our weight is forward. Give the leeward bow a good aggresive angle, and like Mike and Jake said, use that big jib to your advantage. When you're in the jib and it's drawing well, the combo of apparent wind and the boards will put you up where you need to be.
Good luck - coming to Nationals?
Re: Pointing on a Nacra 6.0NA [Re: SoggyCheetoh] #21121
06/18/03 01:13 PM
06/18/03 01:13 PM
Neb
flounder Offline
flounder  Offline
Neb
It is almost always the "slot" between your jib and main being too narrow or mast pre-bend. Barberhaulers are a crews best friend to correct the slot problem.
Re: Pointing on a Nacra 6.0NA [Re: Mike Hill] #21122
06/18/03 04:58 PM
06/18/03 04:58 PM
Doesn't going faster make your apparent wind direction change to more on the nose? This would mean the faster you go, the less high you can point - right?
There's a sweet spot between boat speed and pointing ability that will get you to A mark faster for any given boat. I'm pretty sure that sailing faster will not help you point higher.
Re: Pointing on a Nacra 6.0NA [Re: Jake] #21123
06/18/03 05:53 PM
06/18/03 05:53 PM
Jensen Beach, FL
BlowMe Offline
BlowMe  Offline
Jensen Beach, FL
If your main has a large draft or old battens this will cause the problem you have mentioned. Some times a little over rotation on the mast with an older sail with older battens will help flatten the sail so you can get a clean slot while you are pointing. Sometimes it will make it fatter. Depends on if it is a square top or a pinhead. A larger set of foam battens in the lower part of the sail will help too. Of course..... If you dont sheet properly it is all for not. I have actually bent 2 clew travellers from sheeting my sails in hard. But I can point with the best of them.
No one has mentioned the jib car placement. Another critical issue when you are trying to get the 6.0 to point. I'm assuming mid-track and traveled in about 1 fist from the hull. I dont know because I use a monster jib on mine (makes an NA jib look like a sliver). The NA guys will have to help you with that one. I'm sure Rick or Captain Kirk would know. They are always willing to give good advice.
Good luck!
AJ
Nacra 6.0 Express
Re: Pointing on a Nacra 6.0NA [Re: SoggyCheetoh] #21124
06/18/03 07:22 PM
06/18/03 07:22 PM
Annapolis Md.
LuckyDuck Offline
LuckyDuck  Offline
Annapolis Md.
Hey Alec. Just had to laugh, your first response was from a H-20 driver. Sage advice.
F-16 Falcon #212
Re: Pointing on a Nacra 6.0NA [Re: Jake] #21125
06/19/03 07:16 AM
06/19/03 07:16 AM
Cape Town, South Africa
Steve_Kwiksilver Offline
"Doesn't going faster make your apparent wind direction change to more on the nose? This would mean the faster you go, the less high you can point - right? "
Right, and wrong too. Sailing theory is quite diverse, and contradicts itself sometimes. By footing off & going for speed, you load up the centreboards which gives you drive to windward, so although you are footing off you are actually pointing higher than someone who is pinching & going slow. His heading may be higher than yours, but becuase he isn`t loading up the foils, he will be slipping sideways. You`ll get there first.
Steve
Re: Pointing on a Nacra 6.0NA [Re: LuckyDuck] #21126
06/19/03 09:48 AM
06/19/03 09:48 AM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
I had to look up "Sage advice" to see if I was being slammed.
"Proceeding from or marked by wisdom and calm judgment: sage advice. "
Heck, I'll take that.
Mike Hill
H20 #791
Mike Hill
N20 #1005
Try Speed Testing! [Re: BlowMe] #21127
06/19/03 10:08 AM
06/19/03 10:08 AM
RickWhite Offline
RickWhite  Offline
There is really no way you can improve boat speed without relativity to another boat. You have gotten a lot of advice -- a lot of it may be right. But, I don't believe there is any magic place to set your main or jib. Everything is relative to the wind, the seas, your crew weight.., in other words, the old Three W's of Wind, Water and Weight.
That is where Speed Testing comes in.
In my latest book, "Sailing Drills:" there is a section on Speed Testing. Basically, you need at least two boats. One boat must stay the same no matter what -- you need a constant.
You should line up so that one boat does not affect the other's wind. Then sail for about two minutes and determine if one boat went faster and by how much, and one boat sailed higher and by how much.
Record that and do it over and over until you have established an average.
Now experiment with changes on one of the boats.., should be the one that is performing worse. You can try jib lead positions, mast rotation, mast rake, sheet tension, and even different styles of sailing.
But, be sure to try only one at a time and try it a number of times to get realistic data.
If the winds are fluky, forget about it -- try it on another day when the winds are pretty steady.
By the way, the data you would be gathering would be valuable ONLY for that wind, water and weight condition. Keep that in mind.
I know we spent close to a week here in Key Largo a number of years ago tuning the N6.0NA and came up with some pretty good numbers. Then folks started sailing with a more radical aft mast rake and our numbers went out the window. Sorry to say we never Speed Tested again after that to find the new magic numbers.
Also, the "loose nut on the tiller" could be a problem. Some folks are pinchers.., and others are footers. A good way to find out which you are is to try my "Eyes Closed Drill."
Simply go out sailing with another similar boat and get in what you think is your groove. Once there the Skipper closes his or her eyes and sails by feel. You are only eliminating of you senses -- you still have 4.., or maybe 5 in some cases, left. Use them. Feel the wind in your hair on your arms, feel the waves, the heeling of the boat, listen to the telltales tickle on the sail, etc.
After sailing for about 5 minutes, relate how you are doing with the other boat. One boat may be much higher (pincher) and the other much lower (footer).
In my Sailing Seminars I do this drill with the entire class and find it amazing the differences in helmsmanship.
Once you discover you are a natural footer, practice working on going higher. If you discover you are a pincher, practice driving off and getting more speed.
To give you exact place to put your jib settings, how must mast rake, how hard you sheet, etc. would be impossible to do in this armchair position we are all sitting in right now.
It takes work.
Generally, I will say this. The first day of every seminar I try to espy general sheeting of each boat. I would have to say that usually 90 to 100% of the students are not sheeting the main enough. The 90% is exact, and once in a while I will get a student that understands you need to sheet the main much harder than the jib. But, that is rare.
Of course, as mentioned in previous posts, you can't sheet in tight until you get flow across the boards and rudders. Once that flow is established, you can sheet the main very hard in most cases. Most folks err in the direction of losing gobs of power by not sheeting enough.
So, in essence, with your main not sheeted too tight, you are powering up (in 2nd gear), but not pointing very well. Once there is flow across the boards, you can sheet in and flatten out the sail (shift to high gear).
At any rate,
Good luck
Rick
Rick White
www.onlinemarinestore.com
Re: Pointing on a Nacra 6.0NA [Re: SoggyCheetoh] #21128
06/19/03 10:20 AM
06/19/03 10:20 AM
Houston
carlbohannon Offline
Houston
I had the same problem. The main cause is that monster overlapping jib. The comments I am giving were based on me trying to run a windward leeward course against A-Class cats. We had changed from a reach dominated course because nothing could touch the 6.0NA. When the A's showed up, I really regretted that.
1) Watch for the jib back winding the main. When you see it ease off. Back winding you can't really see hurts. Try adding a tell tail to the main ~ 1/3 of the jib height up and 12-18 inch aft of the mast.
2) Jib sheeting position is important. Start with the track centered and the traveler about 3 inches from the inside of the hull. Move it about an inch out for heavy air and a 1/2 inch in for light air. This is a starting point, find out what your sails like. Sheeting the jib properly is important. Sheeting it board flat all the time, will not cut it. If in doubt, ease the jib a little.
3) You don't have a boom. Some of the comments from H20 sailors can hurt you. Talk to 6.0 and 5.8 skippers. You are basically pulling down on the leach and depending on the cut of the sail to set the draft. IF you sheet too hard, you can hook the leach. You can try moving the mainsail traveler forward 1/2 inch and sheeting HARD with both hands. Get someone to take photos from behind.
4) Try using your mast rotation inducer as a rotation limiter. (This is tricky, with the rotation inducer, you must release and reset the inducer every time you tack. If you forget you can break your mast.) If it helps you can put a real rotation limiter on. Basically you want to limit the rotation to the centerline of the mast pointing at the shroud (the H20 sailors can help you with this).
If all else fails, fall off and point with the Tornado's. We love to watch the 6.0's trying hold the boat down when the wind picks up. If you see me trying to point too high, kick me hard when we get back to the beach.
Re: Pointing on a Nacra 6.0NA [Re: Mike Hill] #21129
06/19/03 10:29 AM
06/19/03 10:29 AM
iro-ny, n. use of words to express the opposite of what one really means.
I think his comment related to the original post being about how the guy's getting dogged by H20s around the marks and you chimed in, albeit with good advice, but with "Hobie 20" proudly in your signature block. I got a grin out of that, too. The good-natured battle between between the 6.0 and the H20 continues!
Re: Pointing on a Nacra 6.0NA [Re: John Williams] #21130
06/19/03 10:33 AM
06/19/03 10:33 AM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
What battle? I thought that the H20s were long gone! (In the rear that is)
Re: Pointing on a Nacra 6.0NA [Re: pitchpoledave] #21131
06/19/03 10:52 AM
06/19/03 10:52 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
We're baa-aack!!!
Re: Pointing on a Nacra 6.0NA [Re: carlbohannon] #21132
06/19/03 11:06 AM
06/19/03 11:06 AM
Carl,
You lost me with the tell-tale to detect that you're backwinding the main. I would certainly welcome some sort of tool to indicate this condition but I don't understand how the extra tell-tale can do it.
Re: Pointing on a Nacra 6.0NA [Re: Jake] #21133
06/19/03 11:38 AM
06/19/03 11:38 AM
Neb
flounder Offline
flounder  Offline
Neb
Barberhauler is a nice tool to control that slot... and as far has H20's being long gone, I think the class racing is as good as any.
Re: Pointing on a Nacra 6.0NA [Re: flounder] #21134
06/19/03 11:56 AM
06/19/03 11:56 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
One of the best ways to keep the slot open is to ensure that the jib has proper twist in its shape, which opens the leech up keeping the slot open from top to bottom. The best way to do this is move your cars back - this goes against some folks advice to move cars forward to open the slot. Moving cars forward opens the slot at the bottom of the sail (simple geometry), but kills the twist and closes the upper slot.
Barberhauling upwind may give a more open slot at the bottom of the sail, but it will tighten the leech which will close the slot higher up. The effect is similar to sliding your jib cars forward. You would need to find the right combo of sheeting angle to barberhauling to get a good shape with proper twist.
I've always found that when upwind speed or pointing doesn't feel right, the first thing I do is sheet the jib out a little and make sure the bows are down. You're better off with the jib slightly luffing than sheeted hard and closing off the main.
Although I'm not a 6.0 sailor, this has worked on just about anything I've sailed.
Re: Pointing on a Nacra 6.0NA [Re: Keith] #21135
06/19/03 12:35 PM
06/19/03 12:35 PM
the 6.0 has a 4 way jib car adjustment with the cable running across the trampoline. I can't imagine having to use the barberhauler upwind because there is already so much adjustment - does anyone do this on their 6.0?
