| Re: Pointing on a Nacra 6.0NA
[Re: SoggyCheetoh]
#21138 06/19/03 01:15 PM 06/19/03 01:15 PM |
Joined: Aug 2002 Posts: 24 Annapolis, Maryland Marschassault
Posts: 24 Annapolis, Maryland | Alec,
(To everyone else - I was Crew that night)
Physical - crew weight - 225lbs Winds - +20's that night Seas - 1-2ft (wouldn't you say?)
Guys, This was the first time I had ever crewed on a 6.0na. One thing we were trying to do was point as well as another 6.0na also! (we were close). I remember Ricks rules "Weight, wind, waves" "keep the power on when all are heavy.
The jib car was in the rear most position, and yes, I was traveling in on the jib. I kept an eye on the main, checking for backwind conditions - I evened lossened the jib up at times to double check - that big jib would luff up in a heart beat! I did use the barberhauler on the down wind legs - she was fast there. I though maybe we were running to tight and I eased the downhaul to almost nothing (hoping to help her power up) but she seemed to run just as fast on the blade.
There has to be something else - or maybe you guys are right and I was choking the slot do to much (that was the only position were the jib had good shape)
I tried to get my weight as far forward as I could (front beam or better - until the waves knocked my feet out from under me).
Like Rick said Alec - I'm a pincher - sorry Dude, but thanks for the ride Tuesday night shes a blast to sail - great power!
Hang in there - you'll run down Keith on that H20 before to long!
Ballast | | | Re: Pointing on a Nacra 6.0NA
[Re: Marschassault]
#21139 06/19/03 01:52 PM 06/19/03 01:52 PM |
Posts: 12,310 South Carolina | I sure wish we could find a couple of 6.0s reasonably near by that would want to spend a weekend testing and tuning (I'm in Greenville, SC) - or maybe we could get together a couple of days early before a major event.
Jake Kohl | | | Re: Pointing on a Nacra 6.0NA
[Re: Marschassault]
#21141 06/20/03 12:12 AM 06/20/03 12:12 AM |
Posts: 364 | I was Crew that night)
Physical - crew weight - 225lbs Isn't that terribly light?
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
[Re: carlbohannon]
#21145 06/20/03 05:14 PM 06/20/03 05:14 PM |
Posts: 396 Annapolis Md. | Carl has raised a point that I have been pondering (thinkin bout) lately. Does a larger jib i.e. low aspect with a somewhat longer foot hinder pointing ability verses a high aspect jib with a shorter foot i.e. Tornado (new) and I-20? Other than windage would you be better off with the jib furled and going uni to weather? The second one is a bit extreme but hey, what if? Don't tell Alec but we are overipening tomatoes this weekend in case he passes us Tuesday night.
Still hazey after all these beers. F-16 Falcon #212
[Re: SoggyCheetoh]
#21146 06/23/03 09:34 AM 06/23/03 09:34 AM |
Posts: 887 Crofton, MD | Thank you for this post, it has been very informative. We will be moving our jib car all the way back tomorrow night. I think our upper slot is closing on us.
I believe you or Bobby was referring to our 6.0 from last Tuesday. Tyler was driving and had the a-cats commenting to him after the race about how well he was pointing upwind.
A very accomplished big boat sailor friend and I were talking about mast prebend. He felt that the right amount of mast prebend was critical to going up wind effectively.
We asked Jim Boyer, before the Ice Breaker Race, how to determine the right amount of prebend. If I understood him correctly, he said to set it then go sailing on a closehauled course for your boat. As you apply mainsheet, look up at the leach, the leach should stand-up just when the draft looks right and the telltales are flowing. We left our spreader rake where it was from last season, then set our outer diamonds to Rick Bliss's numbers of #38 to #39 (450#s - 500#s) and the inner diamonds to #20. These numbers appear to be working for us, based on Jim Boyer's suggestions, our pointing and speed comparison with other boats. We have not adjusted it from these numbers. Our crew weight varies between 380#'s to 400#'s.
Two months ago we, Alec and I compared our rig tensioning devices. We found that Alec's, the professional model, read a little over half of what ours, the standard model, reads. Is there a conversion I am missing?
Regarding Mary's zipper suggestion, our jib is bigger than an NA jib and it has a leach line installed. We do adjust this line for the wind conditions. However, whenever it is about double trap conditions, the line always comes out of its plastic cleat causing our leach to flog. It is incredible annoying, destracting, and is probably quickly destroying our sail, but it may be helping us point upwind.
Alec, if we get there early enough tomorrow night, we can measure spreader rake and rig tensions. | | | Re: Pointing on a Nacra 6.0NA
#21148 06/23/03 04:07 PM 06/23/03 04:07 PM |
Posts: 2,844 42.904444 N; 88.008586 W | Jake,
Nice Mugshot! Is that how you look when you're stoned? J/K
NO-ONE has even mentioned the 4-way system in opening up the slot! If it's way inboard, it better be light air. Start with it most of the way out towards the hull, and pretty much leave it there. Sure, you get get infinite adjustments:fore-aft, in-out board, unless your leech, or foot is flapping when sheeted hard, it's probably OK where it is.
I've raced against 6.ona's that have gotten rid of the 4-way system for tramp cleanliness, and don't seem to point qyuite as high, with the same speed as me. (mine's still on) So, I think you point a little higher, with speed with the 4-way jib system, and leaving it most of the say outboard. My jib block is about the length of putting my pointer finger and pinky out, probably around 8 or ninw inches (what she said), from the inboard of the hull.
Good luck, theres some great advice here.
Todd Bouton
F-18 Infusion #626- SOLD it!
[Re: Todd_Sails]
#21149 06/23/03 04:12 PM 06/23/03 04:12 PM |
Posts: 12,310 South Carolina | naaah - that shot is after a few beers / playing with epoxy all day.
Jake Kohl | | |
1 registered members (vasil),
386
guests, and 25
