| water in mast #213696 06/13/10 04:10 PM 06/13/10 04:10 PM |
Joined: Sep 2003 Posts: 264 Long Island, NY gregP19 OP
Posts: 264 Long Island, NY | I have a small amount of water in my mast from having it lie on its' side outdoors this winter. The water seems to be in the bottom section of the mast in a confined space. I removed the silicone where the diamonds attach to the mast and loosened the thru bolt for the internal downhaul. I couldn't get the water to drain out. Are there cross-sectional pieces in this Blade wingmast that won't allow the water to drain out?
G Gove
Blade #728
Long Island, New Yawk
| | | Re: water in mast
[Re: gregP19]
#213769 06/14/10 09:28 AM 06/14/10 09:28 AM |
Posts: 5,525 | Have you tried to contact Matt? He would know.
Pete Pollard Blade 702
| | | Re: water in mast
[Re: pdwarren]
#213828 06/14/10 05:24 PM 06/14/10 05:24 PM |
Posts: 264 Long Island, NY | Thanks guys. I sent an email to Falcon Marine and haven't heard back yet. It's not a lot of water but it's annoying that it's in there. It would make sense that there is a foam plug above the bolt for the downhaul. The water seems to stop there. I worry that too much water might come in if I flip or turtle.
G Gove
Blade #728
| | | Re: water in mast
[Re: gregP19]
#214155 06/19/10 05:46 AM 06/19/10 05:46 AM |
A plug right above the internal downhaul system is pretty common.
My solution would be to just drill a small hole just above this plug and drain the water water out that way. Possibly by drilling a second hole 100 mm higher up the mast (to let air in more easily). This should be about 1500 mm up from the mast base BUT PLEASE CHECK THIS with the builder of your boat/mast.
These holes will be in a pretty safe place as this part of the mast will never submerge in a normal capsize. Only when the boat goes turtle but that is an extremely rare occurance with the F16's due to their overall lightweight and relative bouyant masts. So one could leave these holes open and allow the mast to vent. This also avoids underpressures in hot masts when they are suddently cooled by the water during a capsize. This underpressure can be a cause for the water inside the mast.
Anyway, but if this is not to your liking then putting two aluminium blind rivets (pop rivets) in will seal the mast again. Aluminium rivets are also very easy to drill out when you'll find water inside your mast at a later time, thus reusing the holes. Alternatively, you can place a screws into the holes or just take them off.
3,459
guests, and 106
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online3,694 2 hours ago | | |
