Page 3 of 3 1 2 3
Re: How about a polymer truck bed coating? [Re: mbounds] #214014
06/16/10 08:40 PM
06/16/10 08:40 PM
Brisvegas
ACE11 Offline
ACE11  Offline
Brisvegas
This is what you need - used for ply boats - great product.
http://www.biasboating.com.au/p-768-international-everdure.aspx
Re: How about a polymer truck bed coating? [Re: Karl_Brogger] #214015
06/16/10 09:06 PM
06/16/10 09:06 PM
andrewscott
andrewscott
Originally Posted by andrewscott
(are those called dove tails or something)
I think what you're talking about is the just a profile so the panel has a spot to go. Its all done with a machine, so zero skill involved. Basically I made doors and mitred and glued them together to make up the "box" part.
Dovetails are a mechanical joint heralding from the days when you had to cut off Bessie's hooves to make glue. Glue from way back when sucks, and when the glue fails you still have a joint that'll hold tight. When done correctly, glue isn't really all that neccessary. The flip side is that glue has gotten so good that dovetails should be obsolete, but the process has gotten so cheap that its more popular than ever.
The joint in the corner of these draweres are dovetailed:
I thought the corners in this picture looked like you had cut some type of joint groves that it would slide into and lock together
Re: Weather proofing a wood box? [Re: orphan] #214033
06/17/10 10:05 AM
06/17/10 10:05 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
I agree, thats a really nice looking box, it would be a shame to cover it up. Bedliner will peel off wood, probably very quickly, within a season. The only finished made for wood will stick to wood long term due to the way wood swells and shrinks with the changes in the surrounding air/moisture content.
http://www.woodworkerssource.com/wood_movement.php
Re: How about a polymer truck bed coating? [Re: ] #214034
06/17/10 10:12 AM
06/17/10 10:12 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Thats a pretty common technique, he used a router to mill those parts and it allows for the frame to float in the frame to help compensate for wood movement.
http://en.wikipedia.org/wiki/Frame_and_panel
Re: How about a polymer truck bed coating? [Re: bvining] #214065
06/17/10 09:02 PM
06/17/10 09:02 PM
SC
zander Offline
zander  Offline
SC
Would I be correct in calling that joint a "mortise & tenon" just trying to remember the Norm and the New Yankee Workshop.
Always borrow money from a pessimist. He won't expect it back.
Re: How about a polymer truck bed coating? [Re: zander] #214084
06/18/10 07:23 AM
06/18/10 07:23 AM
It's a type of mortise and tenon joint, but it's a specialized one for rail and stile joints. Like Karl said, it's done on a purpose built machine and there's really not much skill involved.
I can't believe nobody's commented on the pocket screws holding it together from the inside. You can see the holes for them on the underside of the lids. That's a slick trick for no visible fasteners on the outside.
Re: How about a polymer truck bed coating? [Re: mbounds] #214088
06/18/10 08:07 AM
06/18/10 08:07 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Jesus Karl don't f&*@ up your finger again building a cat box.
It was barely hanging on by a thread when I saw it down in Florida :P
Re: How about a polymer truck bed coating? [Re: ThunderMuffin] #214090
06/18/10 08:17 AM
06/18/10 08:17 AM
Nimrod Offline
Nimrod  Offline
Karl:
Haven't read this whole thread, and if not suggested why not use some silicon enamel the stuff they use for topside paint on wooden boats?
Stuff is not cheap and kind of nasty to work with. We used it on some outdoor wooden furniture and still looks good as it did when we painted it a few years back.
Re: How about a polymer truck bed coating? [Re: Nimrod] #214100
06/18/10 11:10 AM
06/18/10 11:10 AM
SC
zander Offline
zander  Offline
SC
I should trade an aluminum one for that thing, I want to buried is something that nice. smile
Re: How about a polymer truck bed coating? [Re: zander] #214111
06/18/10 01:41 PM
06/18/10 01:41 PM
it's big enough...
Re: How about a polymer truck bed coating? [Re: ThunderMuffin] #214126
06/18/10 04:56 PM
06/18/10 04:56 PM
Karl_Brogger Offline OP
That was caused from me having my head way, way up my butt. I was scrambling to get a big job delivered so I could go to Florida. Its all healed up, and semi normal again.
I still haven't coated it with anything yet. Had to work today and yesterday (*GASP*), gotta go sailing tomorrow. Being I've got next to nothing going on next week, I should have it wrapped up by then.
I haven't had any bright ideas on what to do for a latch yet either.
Re: How about a polymer truck bed coating? [Re: mbounds] #214127
06/18/10 05:08 PM
06/18/10 05:08 PM
Yeah, but they're taboo for anything that is visible. You couldn't sell something with those being seen.
I use the **** outta pocket screws when I can. I wouldn't use them as much as I do if it weren't for a Castle Machine.
http://www.castleusa.com/pocket_joinery.html#TSM-21
This is taking longer than I'd like. [Re: Karl_Brogger] #214371
06/22/10 01:09 PM
06/22/10 01:09 PM
Almost there. Second coat of Varnish is on, a few more to go, then I can flip the box and lids over and coat all crap I can't get at right now.
I've skipped the idea of doing the inside of the box with the bedliner stuff. I was kinda thinking I'd do the bottom side of the box, and the inside of the lids with it, but I don't really think that is neccessary, and the $100 I spent on the bedliner stuff I could buy some 90* aluminum pieces to protect the bottom edge, and to hold it up from the deck of the trailer.
Watching varnish dry is alot like watching paint dry.
Re: This is taking longer than I'd like. [Re: Karl_Brogger] #214382
06/22/10 03:02 PM
06/22/10 03:02 PM
yeah, but in an enclosed area, it's much "nicer" to watch varnish.. smile
Page 3 of 3 1 2 3
0 registered members (), 337 guests, and 99 spiders.
Posts267,056
