Infusion daggerboard positioning #213815
06/14/10 03:34 PM
06/14/10 03:34 PM
Missoula, MT, USA
uogecko Offline OP
uogecko  Offline OP
Missoula, MT, USA
Are the port and starboard daggerboards on the Infusion interchangeable? They both seem to work on either side of the boat.
Also, mine aren't staying up - they're sliding most of the way down. Anyone else having that problem?
Re: Infusion daggerboard positioning [Re: uogecko] #213823
06/14/10 04:51 PM
06/14/10 04:51 PM
To keep them up, you can do one of three things - tighten the screws on the rubber stopper, which squeezes it and increases it's width, thereby holding the board better; you can replace the stopper if yours has begun to break down, or you can install another stopper on the opposite side of the boardwell, thereby giving you two stoppers to hold up each board. I've done all three and they work equally well.
Re: Infusion daggerboard positioning [Re: John Williams] #213824
06/14/10 04:56 PM
06/14/10 04:56 PM
Missoula, MT, USA
uogecko Offline OP
uogecko  Offline OP
Missoula, MT, USA
Thanks John - and I'm assuming that the boards are identical and can be used on either side of the boat?
Re: Infusion daggerboard positioning [Re: uogecko] #213830
06/14/10 05:27 PM
06/14/10 05:27 PM
Every Infusion skipper I sailed with had them marked "port" and "starboard." I honestly don't think it mattered... don't ask me how I know. grin
Re: Infusion daggerboard positioning [Re: John Williams] #213835
06/14/10 06:08 PM
06/14/10 06:08 PM
AFAIK the F18 rules mandate that boards profiles be symmetrical.
Re: Infusion daggerboard positioning [Re: Tony_F18] #213840
06/14/10 06:34 PM
06/14/10 06:34 PM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
The reason for the marking is that one board will fit worse in one side than the other. Maybe it is a mm thicker and just has a harder time up and down. I mark mine and I can put them opposite but it is better when they stay on similar sides.
The Capricorn may never know if they have a strap in place for lifting they have to put them in on the same side each time to use the lifting strap.
Re: Infusion daggerboard positioning [Re: Dan_Delave] #214285
06/21/10 12:59 PM
06/21/10 12:59 PM
Vancouver, BC
westcoaster Offline
westcoaster  Offline
Vancouver, BC
A bit off topic... Does anybody have any suggestions on what can be used as a replacement for those rubber stopper pieces that go into the top of the daggerboard wells? The infusion I sail on is missing a stopper on one side, so the board slides down. It just seems to be a stiff piece of rubber, but I haven't come across anything that seems suitable to use as a replacement.
Re: Infusion daggerboard positioning [Re: westcoaster] #214304
06/21/10 07:52 PM
06/21/10 07:52 PM
Dan_Delave Offline
Dan_Delave  Offline
Seems like a piece of one of those white resin squeegees would do it. something like this:
0 registered members (), 17,471 guests, and 436 spiders.
Yesterday at 04:54 AM
