Corrosion in a new mast section #214205
06/20/10 05:51 AM
06/20/10 05:51 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Hi All,
Some of you will have seen the damage done by corrosion to my 1 year old mast section discovered at the Sauna Sail. mad
Well, I have popped the top cap and step out of it in an attempt to find the source. A torch was shone in and the light didnt reach the other end - Neither did the water from the hose confused
I poked around a bit and managed to remove a few peices of grass and a clothing label out of the bottom end I then got the mast almost vertical and filled it up with water from the top when it was full (remember the caps are gone) i banged it on the ground and this fell out:
It is not really clear, but the egg shells and dead bird tell the story - A bird had nested up in there about half way at some stage in the sections life. When the fittings were put in, the rivet heads at the diamonds held the nest and carcass in place. The corrosion was done by the acids in the bird. sick
I am telling this story to get everyone to check up a new section prior to sealing it up. Make sure you can see daylight laugh
Good first project for winter...
Trevor
Mozzie 1828
Sugarloaf Sailing Club
Melbourne
Re: Corrosion in a new mast section [Re: Trevor] #214314
06/22/10 05:09 AM
06/22/10 05:09 AM
Matt_Stone Offline
Matt_Stone  Offline
well, that was interesting, ewwww, well atleast you got to it b4 it got worse
Re: Corrosion in a new mast section [Re: Matt_Stone] #214321
06/22/10 07:50 AM
06/22/10 07:50 AM
East Gippsland, Australia
Tim_Mozzie Offline
Tim_Mozzie  Offline
Not very nice. sick I'm glad we can't smell it!
Tim Shepperd
Mosquito 1775
Karma Cat
Re: Corrosion in a new mast section [Re: Tim_Mozzie] #214398
06/22/10 05:49 PM
06/22/10 05:49 PM
Simon C Offline
Simon C  Offline
That bird must have wondered about it's universe if it hatched in there!!
On the bright side Trev, you've removed some weight.
Simon
Taipan AUS341
Re: Corrosion in a new mast section [Re: Trevor] #214417
06/23/10 02:38 AM
06/23/10 02:38 AM
thricebitten
thricebitten
Hi all,
allways a good idea to check a section inside and out when you first get it. I found some unusual looking die marks inside one a while back, could have been faults which could have lead to a breakage.
Re: Corrosion in a new mast section [Re: Trevor] #214858
06/29/10 03:52 AM
06/29/10 03:52 AM
Peter_Foulsum Offline
Hi Trevor,
What's the saying; a bird in each hull is better than a bird in the mast ? laugh
What's the chance of ordering birds nest at the local Chinese restaurant next time you are having take away ? grin
Peter
Mosquito 1814
Macka Mozzie
0 registered members (), 2,708 guests, and 415 spiders.
13 hours ago
