New jib, battens or not? #214405
06/22/10 09:09 PM
06/22/10 09:09 PM
Graham, NC
WindyHillF20 Offline OP
Graham, NC
Having a new jib made for the franken 18. I was leaning toward a full batten jib but the sail maker seems to see it as a compromise, soft sail offering better performance in lighter wind conditions.
What do you guys think, soft or hard?
Re: New jib, battens or not? [Re: WindyHillF20] #214468
06/23/10 11:27 AM
06/23/10 11:27 AM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
Battens will lengthen the life of your sail.
Re: New jib, battens or not? [Re: Dan_Delave] #214469
06/23/10 11:30 AM
06/23/10 11:30 AM
andrewscott
andrewscott
extend it by how much? 15% 20%?
why not get partial/angled ones so you can furl? (i would give up 20% of its life to have the ability to furl (for anchoring) and or in case i am overpowered ... in a heart beat
Re: New jib, battens or not? [Re: ] #214498
06/23/10 01:53 PM
06/23/10 01:53 PM
Clearwater, FL
stevefisherkeller Offline
Clearwater, FL
I agree Andrew, the ability to furl outways full battens. You also don't have the jib getting caught up against the mast. Do you remember the H-16 days?
Steve Fisherkeller
P19MX
Re: New jib, battens or not? [Re: stevefisherkeller] #214510
06/23/10 02:34 PM
06/23/10 02:34 PM
Daytona Beach Florida
O
orphan Offline
orphan  Offline
O
Self tacking?
Over Lap? If so how much?
Used for racing or fun sailing?
Re: New jib, battens or not? [Re: orphan] #214545
06/23/10 08:06 PM
06/23/10 08:06 PM
Graham, NC
Graham, NC
Yes
No overlap
Racing and fun
Re: New jib, battens or not? [Re: WindyHillF20] #214554
06/23/10 10:58 PM
06/23/10 10:58 PM
Mike Fahle Offline
Mike Fahle  Offline
Typically full length battens are used on self tacking jibs to try to fill the entire front triangle between mast and forestay; filling in even the leech curve that would normally be cut into a jib to (re)gain even that small amount of area. As already mentioned, an extra benefit is that the sail lasts longer as the battens prevent most wear and tear from the sail beating itself up in the breeze. The downside is that you cannot use a roller furler and the sail is less shape sensitive in light air as already mentioned.
Pelican strikers allow an even bigger gain in area by extending the luff length down to a pole from the front beam to below the bridle - if you already have a spinnaker pole then you get more bang for your bucks as it serves double duty. A large window in the jib gets to be pretty important otherwise you cannot see what is on the other side of the boat. The attempt to gain more sail area inside that triangle is to try to regain some of the area lost from using an overlapping jib. However another gain from that move is a much tidier tramp and faster, more consistent good tacks with a self tacker.
The gain in sail area using full length battens is very small but the gain from using the pelican striker is significant and trying to use a furler with a pelican striker would be problematic. So if you want to use a furler you would end up with a smaller jib. You just have to decide for yourself which of these considerations carry the most weight for you in your situation.
Re: New jib, battens or not? [Re: Mike Fahle] #214555
06/23/10 11:37 PM
06/23/10 11:37 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Excellent synopsis Mike!
Dave
0 registered members (), 4,481 guests, and 513 spiders.
