| Copying a Super Wing Mast in carbon... #214854 06/29/10 12:44 AM 06/29/10 12:44 AM |
Joined: Apr 2002 Posts: 695 Ft. Pierce, Fl. USA Seeker OP
Posts: 695 Ft. Pierce, Fl. USA | The way the super wing mast is talked about here it is the best thing since sliced bread...if that is the case, is there an engineer here who can calculate the laminate schedule to mimic the bend characteristics? I am talking about in widely available carbon materials, not some mil spec pre-preg and bogging down in discussions of Autoclaves and such...that has been done ad nausea around here... and from what I can find searching the archives ....no one has ever just answered the most basic question... Forget the building technique.......how about just the laminate schedule...how many layers of what type of material with what fiber orientation and the properties of an Epoxy resin that can be post cured, I can even give you the properties of the resin I prefer to use: http://www.resinresearch.net/id3.html Assume a vacuum bagged hand lay-up. And no... I don't want to just go out and buy an aluminum one. Not interested in "kicking the can around the parking lot"... can a qualified engineer give a straight answer to a straight question? I am sure it would be greatly appreciated by many. If that is too much to ask, does anyone have the accurate specifics bend characteristics of super wing itself...specific enough to allow an engineer to calculate the proper laminate? Regards, Bob | | | Re: Copying a Super Wing Mast in carbon...
[Re: macca]
#214857 06/29/10 03:09 AM 06/29/10 03:09 AM | Scarecrow
| Scarecrow
Unregistered | Contact Gato,
I gave him the schedule two years ago, but can't be bothered digging it out. | | | Re: Copying a Super Wing Mast in carbon...
[Re: Seeker]
#214863 06/29/10 07:16 AM 06/29/10 07:16 AM |
Posts: 548 MERRITTISLAND, FL | The way the super wing mast is talked about here it is the best thing since sliced bread...if that is the case, is there an engineer here who can calculate the laminate schedule to mimic the bend characteristics?
Already done. Bimare has built a mast section specifically designed for us. Their A class profile varies less than 1mm in any direction from the aluminum superwing section. It has been engineered and several different sections tested. Tooling is already done in metal and they are autoclaved, not simple vacuum bag. I know of several vacuum sections that did not hold up to the the long term use on an F16. Jay and Pease have been working with us now for almost a year on the sail program fro these. Carbon is nice but without a matched sail plan it does no good. | | | Re: Copying a Super Wing Mast in carbon...
[Re: Matt M]
#214878 06/29/10 08:37 AM 06/29/10 08:37 AM |
Posts: 439 Memphis, TN | If I'm reading into Matt's post.... He is basically saying, DON'T do it if you plan on doing vacuum bagging for the mast....AND he is also saying, if you don't have the sails cut to the mast, DON'T do IT! Matt, if I'm wrong, please say so.... Mike
Viper USA 132
1984 Hobie 18
[Re: mikeborden]
#214887 06/29/10 09:43 AM 06/29/10 09:43 AM |
Posts: 548 MERRITTISLAND, FL | If I'm reading into Matt's post.... He is basically saying, DON'T do it if you plan on doing vacuum bagging for the mast....AND he is also saying, if you don't have the sails cut to the mast, DON'T do IT! Matt, if I'm wrong, please say so.... Mike You can vacuum bag and probably be OK as long as you take into account the differences in the end product. Carbon is very unforgiving and fails rather catastrophically. There is a big difference often between real world laminates and engineered calculations or lab samples that needs to be addressed. More refined manufacturing techniques can help eliminate these. The builder/buyer just needs to be cautious. On the question of sail, you are spot on. If the sail does not match the mast carbon or not, you will be slow. The same goes for aluminum. This is why I am opposed to those nice tuning guides where they tell you the tension and rake and setting for each condition. You need to set your mast setting to match your sail. Each sail will vary slightly. Different makers can vary significantly and we are F boats so this is allowed. Different masts or mast from different batches also have shown huge differences in their properties. Different crew weight combos or sailing style will pay in as well. What works for 1 boat will not necessarily be right for the boat right next to them. | | | Re: Copying a Super Wing Mast in carbon...
[Re: Matt M]
#214895 06/29/10 10:31 AM 06/29/10 10:31 AM |
Posts: 695 Ft. Pierce, Fl. USA | Perhaps I didn't make my question clear ......The question wasn't has it been commercially done...but what is the laminate schedule for someone who wants to recreate a one- off for themselves.
I actually want to make one up for a F14 Project...but since the F16 class revolves around this mast section this is the logical place to ask...
It will be shorter than an F 16 mast at 25', and as such will experience lower loads. No sails have been designed or fabricated. However since there are at least a few sail makers that are familiar with the superwing and its properties it seemed like a logical step to start with a known/accepted/successful mast section/bend. To just build something with arbitrary bend characteristics and hope someone could design a well performing sail around it would be foolish. Coming from an extensive windsurfing background I know how hyper critical mast bend is to the performance of a sail…I want to get it right the first time. Scarecrow, thank you for pointing me in the right direction…I will ask Gato if he has your lamination schedule handy.
To the naysayers...If I avoided every building project that had been attempted by someone else, and was unsuccessful, I would never have built anything. My whole life has been spent building things that others say “you can’t do that”, “can’t be done”, “that will never work”, “we tried that already, it didn’t work”…both in the marine industry and the residential/commercial building industry. I am sure many of you can relate and have a similar story…
Thank you again to Scarecrow and Matt for you constructive, informed response.
[Re: Seeker]
#214898 06/29/10 10:55 AM 06/29/10 10:55 AM |
Posts: 439 Memphis, TN | I wasn't trying to be a naysayer.... I was trying to make the point that having a custom built carbon mast wasn't going to gain you any advantages like a lot of people think.....AND....it would be too much work to get it up to spec for F16 at this point in time. That is until some groundwork has been laid. If that was said in the OP, I wouldn't have posted my comments.... This is an F16 forum...  I say go for it!
Viper USA 132
1984 Hobie 18
[Re: Seeker]
#214907 06/29/10 11:52 AM 06/29/10 11:52 AM |
Posts: 571 Hamburg | for your simple "I want just to build it approach": 1 Make a plain test piece of a 25%/50%/25% (0°/+-45°/90° direction). 2 Measure the tension stiffness of it at compare it to the tension stiffness of a aluminium plate. 3 Use the stiffness ratio to scale the skin thickness (e.g. if the CFRP is twice as stiff you need half the thickness 4 build the mast with same outer shape and the found skin thickness
The mast will have the same bending stiffness, but not the same weight, strength and so on. Other layer set-up will give lighter masts and varying the skin thickness over the mast length would just be another parameter. It will not be "first time right" if this is the first mast you build and by the way, a shorter mast need to have a lower second moment of inertia to have the same bending curve. If all these expressions are greek to you, better buy a mast. It will be cheaper (you forget to mention this specific point of nay saying :)) Seriously, I can't give you more detailed numbers, as I don't know the skin thickness of the super wing mast and which sort of carbon and resin you want to use.
Cheers,
Klaus
[Re: Seeker]
#214934 06/29/10 04:38 PM 06/29/10 04:38 PM |
Posts: 571 Hamburg | I miss 4) properly engineered laminate, but engineer don't know about the builders background + properly executed or 5) properly engineered + properly executed, but builder doesn't know about design rationals
Ask Boeing 787 engineers about that...
And yes of course, I change my sentence: ...if this is the first mast or similar complex composite part you build.
I meant my approach seriously. In your first post, you said, you don't want to use mil-std composite. Hence you should make in any case test pieces to get the stiffness properties of the fibre you want to buy. Costs you one day, not your whole life. The laminate schedule is not optimsed, but it will work (it is an isotropic layout, same strength in any direction). You asked a simple question and I gave you a simple answer.
If you want a more complex answer, send me the cross section of the super wing mast and the material properties of the fibre and resin you want to use. I would charge you at least 3500 Euro for that job, not for the mast, just for the design (not because I am insane, but because it is my first mast and I need some lead time + testing). And than, you still have the risk 4). Any commercial mast builder will be cheaper, because he has done already this job and changes only a few parameters in his calc. Apart from the fact that those products are already tested. Or you ask your relatives or buy books about composits and engineering. (Again this is a serious proposal)
My 2cts as an engineer.
Cheers,
Klaus | | | Re: Copying a Super Wing Mast in carbon...
[Re: Seeker]
#214935 06/29/10 05:13 PM 06/29/10 05:13 PM |
Posts: 6,049 Sebring, Florida. | Why don't you contact Ben Hall or Goran Marstrom? I'm sure they could help you.
Blade F16 #777
[Re: Timbo]
#214960 06/30/10 12:09 AM 06/30/10 12:09 AM |
Posts: 695 Ft. Pierce, Fl. USA | Klaus I appreciate your response, and your offer to do the calculations and testing. $3,500 does not sound unreasonable for the scope of work you propose...However my wife works in design engineering for United Space Alliance and is up to her eyeballs in every discipline of world class engineer you can imagine, several floors deep. After 32 years at the Kennedy Space Center, and her position in design engineering operations, she knows, and has worked with, the majority of them personally at one time or another. My search is now focused on the same information that I would need to supply to you if you were to do the calculations. Capable engineers are fortunately not a problem for me...I just need the specific information...and I may have found it from a source outside of this forum. I have no shortage of family, friends and my wife’s co-workers who are engineers that would be happy to do it as a favor...you can't compete with free...especially when it is coupled with some of the greatest engineering minds on the planet. Thank you again for your offer to help.
Regards, Bob
[Re: Seeker]
#214964 06/30/10 01:22 AM 06/30/10 01:22 AM |
Posts: 242 Brisveagas | Why are you bothering to ask to question here then? Im sure your engineering guru friends and family could come up with something better couldnt they?
Im only guessing here but wouldn't shortening the mast completely change the way it behaves. Maybe you'd be better off starting from scratch.
Aido Viper 288
[Re: Seeker]
#215017 06/30/10 12:22 PM 06/30/10 12:22 PM |
Posts: 6,049 Sebring, Florida. | Maybe you could find a broken A cat mast that still has enough length for the F14? What do you need, about 25 feet? And what's an A cat mast, about 32-34?
It might be -too stiff- if cut down from 32 to 25 though.
Blade F16 #777
20,577
guests, and 826
