| Installing new mast base. #21493 06/25/03 07:37 AM 06/25/03 07:37 AM |
Posts: 25 Lansing, Michigan | Just ordered a new mast base. I am assuming that all I need to do is drill out the old rivets and insert the new ones. Or am I kidding myself? Any insights would be appreciated. Thanks, Nick
1978 Hobie 16 "Burt The Cat"
| | | Re: Installing new mast base.
[Re: Nick]
#21494 06/27/03 09:23 AM 06/27/03 09:23 AM |
Posts: 45 South Florida | if you mean the aluminum insert that goes in the bottom on the mast, then yes, just drill out the rivets and replace. not quite as easy as it sounds, i actually had to cut 3/16" off the bottom of the mast extrusion to gain new ground for better holes. my advice, silicon the mast base, stick it in and let it dry. then completely redrill all new holes for the rivets. if the holes in your mast are ok you may not have to do this, but i tried using the old holes and couldn't get the base to seat right.
justin
um engineering student
my H16 is older than i am
[Re: Nick]
#21495 07/01/03 10:00 AM 07/01/03 10:00 AM |
Posts: 50 Roanoke, VA | I recently redid the connnection of my mast base. The two rivets were starting to tear loose. I drilled out the old rivets and drilled and tapped 4 new holes for 1/4-20 x 1/2 BHSCS. The only thing that concerned me was how thin the aluminum of the base was to tap into. I just made sure that I used loctite and didn't torque too much. Seems to be working just fine so far.
(Insert Witty Signature Here)
1988 H16
[Re: mattp]
#21496 07/01/03 12:59 PM 07/01/03 12:59 PM |
Posts: 25 Lansing, Michigan | Forgive my ignorance, but what are 1/4-20 x 1/2 BHSCS?
[Re: Nick]
#21497 07/02/03 12:10 PM 07/02/03 12:10 PM |
Posts: 50 Roanoke, VA | Nick,
1/4" dia 20 threads per inch 1/2" long, stainless steel, button head socket cap screw. A lot of words for such a small thing.
1988 H16
657
guests, and 140
