| Re: best vmg
#215901 07/14/10 12:57 PM 07/14/10 12:57 PM | andrewscott
| andrewscott
Unregistered | Also note that with a straight traveler in-line with the rear beam, the action of releasing the traveler down the beam actually sheets the mainsail in tighter.
1) set diamond wire tension for the conditions anticipated that day 2) upwind sailing, work the downhaul to control power in gusts combined with some light helm corrections. 3) upwind sailing, when the downhaul is no longer enough to control the power in the boat, the crew needs to set the downhaul in a moderate to upper position and start working the mainsheet in and out slightly...again in conjunction with some light helm correction. 4) when it's getting really sporty upwind, and the crew is having to really saw the main in and out deeply, it's time to drop the traveler an inch or two and leave it there. Continue working the mainsail and helm. not sure i know what the upper position of the downhaul means (#3) How would you set the downhaul in situation 4? | | | Re: best vmg
[Re: ]
#215902 07/14/10 01:48 PM 07/14/10 01:48 PM |
Posts: 12,310 South Carolina | situation 4 give the downhaul all the cowbell you have. MORE COWBELL!
Jake Kohl | | | Re: best vmg
#215905 07/14/10 02:51 PM 07/14/10 02:51 PM |
Posts: 5,590 Naples, FL | make the top of that sail flap in the breeze ,make the mast look like a banana, and the sail flat as a pancake?
| | | Re: best vmg
#215907 07/14/10 03:02 PM 07/14/10 03:02 PM | andrewscott
| andrewscott
Unregistered | situation 4 give the downhaul all the cowbell you have. MORE COWBELL! gotcha thanks | | | Re: best vmg
[Re: waterbug_wpb]
#215910 07/14/10 03:28 PM 07/14/10 03:28 PM |
Posts: 3,528 Looking for a Job, I got credi... | you would think that with all this emphasis on playing the downhaul, they'd make that line a little more forgiving on the hands.... But maybe it's just me and my house bi*ch hands... Mine is 16:1 on a cascade system. Works very well.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: best vmg
[Re: Smiths_Cat]
#215911 07/14/10 03:30 PM 07/14/10 03:30 PM |
Posts: 3,528 Looking for a Job, I got credi... | hm, I don't use the downhaul without using the rotation. Pulling the downhaul only opens the leach and the lower part of the sail stays full. Thats good in waves and chop, but in most cases it is better to make the whole sail flat (=rotation plus downhaul) not just the top. But this might be different from boat to boat, sloop or uni, conventinal or wing mast.
Also I don't play the downhaul/rotator all the time (again depends if you are single or double handed). Better concentrate on course, sheet and pitch trim and only correct the big stuff with the sail trim. Maybe not the fastest way, but works for me. Cheers,
Klaus As you pull the DH you also SHEET IN that flattens the sail.
[Re: scooby_simon]
#215912 07/14/10 03:43 PM 07/14/10 03:43 PM |
Posts: 571 Hamburg | As you pull the DH you also SHEET IN that flattens the sail. yes, but mainly in the top, because the lower part of the mast is still stiffend by the diamonds, if rotated out. Here is a link to Landenberger sails: trim guide , which fits well to my mast. When I remember back on the Tiger, we used the rotation only between up and down wind, but not with different downhaul setting. Not clear if it because of the jib or the mast profile or because I sail better now (at least I think that I do). Cheers, Klaus | | | Re: best vmg
[Re: Smiths_Cat]
#215916 07/14/10 06:07 PM 07/14/10 06:07 PM |
Posts: 1,200 Vancouver, BC | For those new to these adjustments...here's what found out when first learning them (Charlie Ogletree's advice to me):
1. Stay off the downhaul until you're double-trapped and still unable to depower easily with an arm's length of main sheet out. If the hull is popping up rapidly, then start inching on the downhaul until you find more control.
2. On many boats, as you apply DH, inch by inch, be sure to sanity check how much you've applied. If you put too much on for the conditions, boat will be slow, flat and require you to foot off hugely to get the hull out of the water...bad for VMG. In high wind days, Charlie stated my boat had the flattest sail in the fleet, we were footed 10-15deg lower than everyone and we were still popping the hull up (cause of the wide angle to the wind gusts). Note that when easing the DH, the sail may not actually move back up the luff track until the mainsheet is also eased momentarily...that's important! Otherwise you think you've eased DH...then crank on more at the next gust, then "ease" and repeat...ultimately you've got a sheet of plywood/barndoor for a mailsail and you've lost your race.
3. going to weather the crew sheets the main, anticipating gusts and lulls. When hull raises too far, crew eases just enough main to control the hull height...then immediately re-sheets BEFORE the hull starts to drop again...if you wait until it's on it's way down, it will likely hit the surface and slow you. If crew has to move more than 1 arm's length to maintain hull height, and you're double-trapping, then start inching the DH on.
When we starting mastering this technique, our performance went huge. Boat feels like it's on rails...each gust squirts you forward, not up in the air.
| | | Re: best vmg
[Re: smv]
#215975 07/17/10 06:48 PM 07/17/10 06:48 PM |
Posts: 1,911 South Florida & the Keys | I'm with you.. I think keeping the sail in a contant shape is important. I like to run the traveler from the crew spot amd let the skipper steer and use the main as a last resort to depower.
Eric Arbogast ARC 2101 Miami Yacht Club | | |
2,517
guests, and 112
