one piece tramp for Hobie 16 #216019
07/18/10 07:35 PM
07/18/10 07:35 PM
archer Offline OP
archer  Offline OP
I am trying to replace a two piece tramp with a one piece on a Hobie 16. Can't figure out how to physically thread three sides of the tramp into the rails when it has to be inserted across the front first. Is the one piece that much more difficult to install than the two piece tramp? Looks to me like the two-piece would be an easy replacement, but I can't even figure out how to put this on?
Re: one piece tramp for Hobie 16 [Re: archer] #216021
07/18/10 09:23 PM
07/18/10 09:23 PM
archer Offline OP
archer  Offline OP
Can I just lace this in the front rather than the rear of the frame? That's only way I can think of to install the one-piece. And can't find any instructions anywhere.
Re: one piece tramp for Hobie 16 [Re: archer] #216024
07/19/10 01:31 AM
07/19/10 01:31 AM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
archer,
I can rig a 16 in my sleep and have been professionally repairing them since '98, and I can't picture what you're talking about.
The stock tramps are 3 pieces, two halves and a rear lacing strip, all tied together with some low stretch line. The tramp on a 16 is a structural part that needs to be installed properly.
Could you post a pic of what you have?
Asking technical questions like that would get more responses here.
Happy to help, just need more info.
Re: one piece tramp for Hobie 16 [Re: SurfCityRacing] #216041
07/19/10 08:08 AM
07/19/10 08:08 AM
RickWhite Offline
RickWhite  Offline
We sell the Sunise that has the threads leading at 45=degrees to the hulls, with single lacing at the rear. When tightening the aft, you draw all the threads tighter on the sides as well. Nice part is no hole in the middle for the sheets to go out the back.
They are called bias-cut tramps.
Perhaps that is what you have.
Rick
Rick White
www.onlinemarinestore.com
Re: one piece tramp for Hobie 16 [Re: archer] #216086
07/19/10 12:51 PM
07/19/10 12:51 PM
Clinton, Mississippi
rattlenhum Offline
rattlenhum  Offline
The side rails have a widening of the slot for tramp installation. Are these fore or aft? I beleive they come from the factory up front, but a lot of people like to switch them to the back. I think you're going to have to start wherever these slot-widenings are and lace at the other end (or take the frame apart and swap the rails).
Jerome Vaughan
Hobie 16
Re: one piece tramp for Hobie 16 [Re: rattlenhum] #216243
07/21/10 09:45 AM
07/21/10 09:45 AM
In the early '90s, Hobie Cat sold a 1-piece (really a two piece) tramp that was a miserable failure. You couldn't get them tight enough to provide the stiffness the boat needs.
BTW, Rick, the sheets rarely go through the lacings - at least on my boat. They tend to go over the rear crossbar if you don't practice good line management.
Re: one piece tramp for Hobie 16 [Re: mbounds] #216245
07/21/10 09:56 AM
07/21/10 09:56 AM
andrewscott
andrewscott
i had a line catcher stitched in the middle of my h16 and it worked perfectly
Re: one piece tramp for Hobie 16 [Re: mbounds] #216247
07/21/10 10:24 AM
07/21/10 10:24 AM
I'm sure that was the case with a solid vinyl case but with a bias cut mesh trampoline it should tighten up the sides just fine. As long as the mesh fibers in the trampoline are running at 45 degrees, when you tighten the trampoline at the back, it also tightens the side...kinda like those chinese fingercuffs.
Re: one piece tramp for Hobie 16 [Re: Jake] #216252
07/21/10 10:57 AM
07/21/10 10:57 AM
andrewscott
andrewscott
I read someone got a bias cut tramp for a TheMightyHobie18 from SLO and it did not work well.. he suggested the standard one and it worked fine.
Re: one piece tramp for Hobie 16 [Re: ] #216262
07/21/10 12:34 PM
07/21/10 12:34 PM
catman Offline
catman  Offline
"I read someone got a bias cut tramp for a TheMightyHobie18 from SLO and it did not work well.. he suggested the standard one and it worked fine."
Well......LOL, tell us what you really think about SLO. Enquiring minds.........
Re: one piece tramp for Hobie 16 [Re: catman] #216263
07/21/10 12:47 PM
07/21/10 12:47 PM
Santa Cruz, CA
Santa Cruz, CA
I've seen at least 3 other styles of "One Piece tramps"(actually 2 pc).
Side lace, diagonal lace, front lace. The standard is the 3 pc, center lace/ aft lace, of course.
Just need to know which one homie has.
Re: one piece tramp for Hobie 16 [Re: catman] #216265
07/21/10 01:57 PM
07/21/10 01:57 PM
andrewscott
andrewscott
I can't tell you what i really think until her returns the tramp i sent him 3 months ago.. at which point i will have an Encyclopedia Britannica worth of comments to post.
0 registered members (), 597 guests, and 44 spiders.
