Tiger spi uphaul cinch cleat #216186
07/20/10 11:37 AM
07/20/10 11:37 AM
Frozen Offline OP
Frozen  Offline OP
Not sure of the exact name of it, but on my Tiger (2002 model) the spi rope passes through a cleat (up haul cleat) on the forward crossbar which is a piece of SS with a V cut in it. This is a pain when trying to douse the spi as the rope keeps catching on it. No doubt someone has a cure for this issue. I was thinking of some kind of eye or block that I could slip the rope into that would keep it from snagging on the cleat when dousing. Any suggestions/thoughts?
Alan F
Tiger
Re: Tiger spi uphaul cinch cleat [Re: Frozen] #216188
07/20/10 12:14 PM
07/20/10 12:14 PM
Vancouver, BC
westcoaster Offline
westcoaster  Offline
Vancouver, BC
It sounds like what you're describing is a 'clamcleat'. Is this cleat holding tension on the halyard when the sail is up?
Re: Tiger spi uphaul cinch cleat [Re: westcoaster] #216191
07/20/10 12:59 PM
07/20/10 12:59 PM
Frozen Offline OP
Frozen  Offline OP
That sounds about right.
Alan F
Tiger
Re: Tiger spi uphaul cinch cleat [Re: Frozen] #216198
07/20/10 01:44 PM
07/20/10 01:44 PM
doekie Offline
doekie  Offline
On our 2002 Nacra f18 the camcleat is on the forward beam as well, to prevent the clam catching the spi-halyard during a douse we have a shockcord from the boom with a shackle attached to spi-halyard behind the cleat. The shockcord basically pulls the halyard up so it cannot be catched by the cleat. With tension on the halyard (if the spi is up) the shockcord is not effective and the halyard stays in the cleat
Does this make sense?
Re: Tiger spi uphaul cinch cleat [Re: doekie] #216244
07/21/10 09:56 AM
07/21/10 09:56 AM
Frozen Offline OP
Frozen  Offline OP
Are you saying that the shockcord keeps the halyard from slipping into the clamcleat when you are dousing? Sounds like a good idea. I will look at mine to see if appropo. Thanks!
Alan F
Tiger
Re: Tiger spi uphaul cinch cleat [Re: Frozen] #216272
07/21/10 03:23 PM
07/21/10 03:23 PM
doekie Offline
doekie  Offline
exactly, good luck
Re: Tiger spi uphaul cinch cleat [Re: doekie] #216320
07/22/10 08:49 AM
07/22/10 08:49 AM
If you're using the cleat on the beam, what I did on my FXone was remove the eyelet over the top of the jaws. When I was dousing I would just pull the halyard out of the jaws and off to one side and it would rarely re-cleat itself. I tried a bungee to rotate the cleat out of the way as well, but didn't really care for it that much.
0 registered members (), 2,839 guests, and 176 spiders.
