| Re: one piece tramp for Hobie 16
[Re: archer]
#216024 07/19/10 01:31 AM 07/19/10 01:31 AM |
Joined: Nov 2003 Posts: 749 Santa Cruz, CA SurfCityRacing
Posts: 749 Santa Cruz, CA | archer, I can rig a 16 in my sleep and have been professionally repairing them since '98, and I can't picture what you're talking about. The stock tramps are 3 pieces, two halves and a rear lacing strip, all tied together with some low stretch line. The tramp on a 16 is a structural part that needs to be installed properly. Could you post a pic of what you have? Asking technical questions like that would get more responses here. Happy to help, just need more info. | | | Re: one piece tramp for Hobie 16
[Re: archer]
#216086 07/19/10 12:51 PM 07/19/10 12:51 PM |
Joined: Jul 2004 Posts: 125 Clinton, Mississippi rattlenhum
Posts: 125 Clinton, Mississippi | The side rails have a widening of the slot for tramp installation. Are these fore or aft? I beleive they come from the factory up front, but a lot of people like to switch them to the back. I think you're going to have to start wherever these slot-widenings are and lace at the other end (or take the frame apart and swap the rails).
Jerome Vaughan Hobie 16 Clinton, Mississippi
[Re: mbounds]
#216245 07/21/10 09:56 AM 07/21/10 09:56 AM | andrewscott
| andrewscott
Unregistered | i had a line catcher stitched in the middle of my h16 and it worked perfectly | | | Re: one piece tramp for Hobie 16
[Re: mbounds]
#216247 07/21/10 10:24 AM 07/21/10 10:24 AM |
Posts: 12,310 South Carolina | In the early '90s, Hobie Cat sold a 1-piece (really a two piece) tramp that was a miserable failure. You couldn't get them tight enough to provide the stiffness the boat needs.
BTW, Rick, the sheets rarely go through the lacings - at least on my boat. They tend to go over the rear crossbar if you don't practice good line management. I'm sure that was the case with a solid vinyl case but with a bias cut mesh trampoline it should tighten up the sides just fine. As long as the mesh fibers in the trampoline are running at 45 degrees, when you tighten the trampoline at the back, it also tightens the side...kinda like those chinese fingercuffs.
Jake Kohl | | | Re: one piece tramp for Hobie 16
#216252 07/21/10 10:57 AM 07/21/10 10:57 AM | andrewscott
| andrewscott
Unregistered | I'm sure that was the case with a solid vinyl case but with a bias cut mesh trampoline it should tighten up the sides just fine. As long as the mesh fibers in the trampoline are running at 45 degrees, when you tighten the trampoline at the back, it also tightens the side...kinda like those chinese fingercuffs.
I read someone got a bias cut tramp for a TheMightyHobie18 from SLO and it did not work well.. he suggested the standard one and it worked fine. | | | Re: one piece tramp for Hobie 16
[Re: ]
#216262 07/21/10 12:34 PM 07/21/10 12:34 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | "I read someone got a bias cut tramp for a TheMightyHobie18 from SLO and it did not work well.. he suggested the standard one and it worked fine."
Well......LOL, tell us what you really think about SLO. Enquiring minds.........
[Re: catman]
#216265 07/21/10 01:57 PM 07/21/10 01:57 PM | andrewscott
| andrewscott
Unregistered | "I read someone got a bias cut tramp for a TheMightyHobie18 from SLO and it did not work well.. he suggested the standard one and it worked fine."
I can't tell you what i really think until her returns the tramp i sent him 3 months ago.. at which point i will have an Encyclopedia Britannica worth of comments to post. | | |
2,499
guests, and 502
