| Spinnaker check #216505 07/26/10 08:36 PM 07/26/10 08:36 PM |
Joined: Sep 2003 Posts: 264 Long Island, NY gregP19 OP
Posts: 264 Long Island, NY | I usually set up the chute in the bag, point the boat downwind and launch it while I'm on the beach to scout for problems before discovering them on the water. The other day it was blowing 20 so it was a bit of a Nantaucket Sleighride in the sand trying to see if the lines weren't tangled. What do you guys do before a regatta when it's blowing? I figure the only alternative is to run the tapes to make sure there are no problems as you do on a monohull with a symetrical chute. Thanks, Greg
G Gove
Blade #728
Long Island, New Yawk
| | | Re: Spinnaker check
[Re: gregP19]
#216512 07/27/10 02:31 AM 07/27/10 02:31 AM |
Posts: 1,382 Essex, UK | Only if it's VERY light (less than 5mph) will I pull the kite ashore when rigging. I always just follow the tapes.
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Spinnaker check
[Re: Karl_Brogger]
#216527 07/27/10 08:56 AM 07/27/10 08:56 AM |
Posts: 3,528 Looking for a Job, I got credi... | I have a line that goes thru the patches on the kite so these always get threaded correctly. Start with the kite in the chute and set up correctly.....
Pull out enough to expose the whole of the downhall to the top patch; with a bit of rope about 2m long; put a stopper knot in one end; thread the other end thru the bottom patch, following the downhaul, to the top patch and tie a bowline; you now have a guide next time you put it up.
To set it up…..
1, put the clew onto the end of the pole. 2, Follow the luff to the head and tie this on (if you stuff the kite into the bag right; you can do most of this with the kite still in the sail bag 3, Dig out the bit of rope you added above; you now have a guide for the downhaul; make sure you get the DH the right side/inside the clew line and thread the DH; Remove the guide rope. 4, Pull it in the bag; rig the sheets (again the right side of the uphaul)
5, I usually do a partial hoist to check everything is the right side of everything else; and as Andrew suggests, if it’s howling you can tip the boat on it’s side…
To pack away
1, remove from tack 2, remove head 3, undo sheets and put these on the sail bag 4, Pull spi out of the chute and find the downhaul; thread guide rope; untie downhaul 5, stuff body of kite in bag
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Spinnaker check
[Re: waynemarlow]
#221352 10/09/10 06:58 PM 10/09/10 06:58 PM |
Posts: 14 Houston, TX | Do any of you guys have pics of the rigging and setup to raise, please....U can share..?
tks, Blade X1
Asim_Saber - Blade X-1 'No Mo Speed, I'm almost there'
626
guests, and 34
