| Re: Sailing in light winds...what to do?
[Re: fredsmith]
#217124 08/04/10 10:11 AM 08/04/10 10:11 AM |
Posts: 5,590 Naples, FL | ditto. weight low and forward. centerboards down. Keep the air attached to the sail. No radical movements (weight, rudder, sails).
When you talk light wind, I'm thinking less than 5 knots.
one crew on high side, one crew on low side. both near front beam. Don't switch sides during tacks. either hand off tiller or drive from leeward side and look under sails.
Moderately loose sails (twist off top of main) and watch the backside telltales. light to medium downhaul, full rotator (between shroud and front beam)
downwind same thing. if you can't keep the spinnaker full it is probably better to drop it and head straight down to C gate. If you can keep it inflated, don't heat up too high trying to get the hull up or you'll be missing VMG. I think the "break point" is right at 5-7 knots where going hot starts to pay big dividends..
355
guests, and 47
