Page 3 of 5 1 2 3 4 5
Re: Construction of Garage Mahal has begun! [Re: Jake] #217417
08/11/10 10:05 PM
08/11/10 10:05 PM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
Wow no wire or expansion joint either. What psi concrete did you use ?
Re: Construction of Garage Mahal has begun! [Re: Dlennard] #217418
08/11/10 10:21 PM
08/11/10 10:21 PM
Jake Offline OP
Jake  Offline OP
I was also surprised that there was no wire but I didn't think to put it in the contract and it was impossible to stop everything with the truck ready at the pour. We do have soil with a very high compaction - I'm hoping it's OK.
They did cut relief joints after finishing but I thought it too early. Lord, I dunno. If only you and Renee resided in SC!
Re: Construction of Garage Mahal has begun! [Re: Jake] #217429
08/12/10 06:31 AM
08/12/10 06:31 AM
catman Offline
catman  Offline
Around here you have to have an inspection before the concrete is poured. Good luck with your builder if this is how it's starting,
Re: Construction of Garage Mahal has begun! [Re: catman] #217431
08/12/10 06:40 AM
08/12/10 06:40 AM
Jake Offline OP
Jake  Offline OP
The foundation did have to be inspected before anything was poured - and it was. This is a floating slab inside the concrete footer / block foundation - so it's not structural...it's a matter of it not cracking in an uncontrolled fashion over time.
Re: Construction of Garage Mahal has begun! [Re: Jake] #217439
08/12/10 09:01 AM
08/12/10 09:01 AM
South Louisiana, USA
Clayton Offline
Clayton  Offline
Here in Louisiana (south), you've got to put some kind of reinforcement in the concrete otherwise you're screwed. Concrete WILL crack, the reinforcement will keep it together. Heck I put wire in my sidewalk! Good catch on the vapor barrier.
Re: Construction of Garage Mahal has begun! [Re: Clayton] #217447
08/12/10 04:01 PM
08/12/10 04:01 PM
catman Offline
catman  Offline
You would think that the building code would require it especially where you have freezing temps.
Re: Construction of Garage Mahal has begun! [Re: catman] #217451
08/12/10 05:34 PM
08/12/10 05:34 PM
Jake Offline OP
Jake  Offline OP
I poked around with some other folks I know that built garages in the area and found five I know. Three had floating slabs like this and none of them had wire reinforcement in the slab - none of them have experienced any issues with the slab and one of the structures is 12 years old. Y'all are making me nervous!
My short straw pole shows that the monolithic slabs seem to universally have structure in and around them.
Re: Construction of Garage Mahal has begun! [Re: Jake] #217455
08/12/10 06:10 PM
08/12/10 06:10 PM
Northeast
E
erikcole Offline
erikcole  Offline
E
Northeast
When our house was built the slab for the garage and the basement were poured well after the framing and other stuff was done. When I had asked why; they had told me it will help with curing and keep the concrete from flaking.
I remember in the basement they had used wire that looked like chicken wire that was thicker and had bigger squares and in the garage used quarter inch "rebar" meshed out in 4" X 4" pattern.
But where I live, it gets cold and this may be the reason for it.
Keep us posted, I like the HGTV projects. Life hasn't been the same since "This Old House" is no longer available to us.
Re: Construction of Garage Mahal has begun! [Re: Jake] #217457
08/12/10 06:24 PM
08/12/10 06:24 PM
catman Offline
catman  Offline
I wouldn't worry about it. Around here everything is built on sand not clay. Just not what some of us are used to seeing.
Re: Construction of Garage Mahal has begun! [Re: erikcole] #217458
08/12/10 06:33 PM
08/12/10 06:33 PM
catman Offline
catman  Offline
Or the DIY network.
Re: Construction of Garage Mahal has begun! [Re: catman] #217463
08/12/10 07:57 PM
08/12/10 07:57 PM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
We couldn't do anything on our sand without mesh to stop the eventual cracks from moving apart, I've got a mate that poured his verandah after the house slab about 6 years ago and there is now nearly an inch gap even though the verandah poles are bolted to the concrete.
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Construction of Garage Mahal has begun! [Re: JeffS] #217467
08/12/10 08:59 PM
08/12/10 08:59 PM
FL
sail7seas Offline
sail7seas  Offline
FL
Some of the new slab on grade concrete mixtures today add some kind fibre or wire fibre to increase contraction/control joints spacing and can exceed an old commercial standard of 20 ft. o.c. If the subgrade is compacted properly or moisture density is off is another cause of cracking, but appears inspection covered that base.
Re: Construction of Garage Mahal has begun! [Re: sail7seas] #217468
08/12/10 09:11 PM
08/12/10 09:11 PM
Jake Offline OP
Jake  Offline OP
What about topsoil under a concrete drive? I was surprised when they pushed three large piles of topsoil back where the drive is going to go. The moved and moved-back dirt is probably 2 to almost 3' deep in places and I wasn't here to see how much, if any, attention they paid to compacting it. I had expected them to haul it off and bring in fill. I don't yet know what the builder intends to do with that but I've got some time to make my case about that.
They're supposed to start framing tomorrow and they expect to get the 2nd story floor system in....I'm not even two weeks into this yet.
Re: Construction of Garage Mahal has begun! [Re: Jake] #217469
08/12/10 10:10 PM
08/12/10 10:10 PM
JeffS Offline
JeffS  Offline
With sand we keep a sprinkler on it for days on end, water forces the air bubbles to the surface compacting the soil. Would that work with your soil?
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Construction of Garage Mahal has begun! [Re: JeffS] #217471
08/12/10 10:58 PM
08/12/10 10:58 PM
Clayton Offline
Clayton  Offline
I would be concerned about top soil under my drive way. Especially more than 6" freshly put. I don't know what soil you have but even then more than 6" needs to go back in "lifts" not more than 6" at a time and compacted to 90 to 95% of original (of recommended density material) Check this out for basic information on the subject:
http://www.concrete-catalog.com/soil_compaction.html
A proctor test will determine the compaction/density of the soil you have. Might want to do that to see is what you have can actually be compacted sufficiently for concrete overlaying.
BTW, I did stay at a Holiday Inn once...
Good luck,
Re: Construction of Garage Mahal has begun! [Re: Clayton] #217805
08/19/10 04:47 AM
08/19/10 04:47 AM
Jake Offline OP
Jake  Offline OP
And she's up! (yes, the grass has been neglected for a bit)
http://www.teamseacats.com for more
Re: Construction of Garage Mahal has begun! [Re: Jake] #217807
08/19/10 07:02 AM
08/19/10 07:02 AM
When the Taj Mahal was finished the emperor chopped of the hands of the builders so that they could never build something as beautiful again.
You knew this right? grin
Re: Construction of Garage Mahal has begun! [Re: Karl_Brogger] #217810
08/19/10 08:31 AM
08/19/10 08:31 AM
Houston
carlbohannon Offline
Houston
Concerning the built-in Vac.
I have used both. There is no comparison in the suction between a good built-in and a portable. I use a 15 amp 230 volt built-in with centrifugal filtration and an outside vent. It roughs out vacuum bags in seconds. Also if you do anything that produces any toxic or semi-toxic vapor, it's very good to exhaust outside sometimes.
However, never use a built-in when grinding something that produces white sparks, don't ask.
Re: Construction of Garage Mahal has begun! [Re: carlbohannon] #217813
08/19/10 09:04 AM
08/19/10 09:04 AM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Pictures? sick
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Construction of Garage Mahal has begun! [Re: Jake] #217854
08/19/10 02:33 PM
08/19/10 02:33 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
Looks good.
Isak Dinesen
E. B. White
0 registered members (), 16,911 guests, and 1,043 spiders.
Most Online22,490
Yesterday at 08:14 AM
