Identify windshifts in downwind #217452
08/12/10 05:44 PM
08/12/10 05:44 PM
Budapest, Hungary, Europe
CatSailingHu Offline OP
Sailing upwind - using a compass - it is quite easy for me identify the windshifts and decide when to tack, but downwind I’m a bit lost. Any advice ?
Sanyi
Nacra Infusion
www.catsailing.hu
Re: Identify windshifts in downwind [Re: CatSailingHu] #217454
08/12/10 06:04 PM
08/12/10 06:04 PM
You can definitely still use the compass. Upwind on starboard, you tack on more negative readings (header). Upwind on port you tack on more positive readings (header). Downwind you do the opposite...on starboard, gybe on positive - port, gybe on negative.
Re: Identify windshifts in downwind [Re: Jake] #217525
08/13/10 02:09 PM
08/13/10 02:09 PM
Kiel, Germany
Baltic Offline
Baltic  Offline
Kiel, Germany
But when you get a gust, you bear away which will change the reading of the compass, too. Your method works only when you have steady wind.
F18: C2 / A-Cat: Minelli
Re: Identify windshifts in downwind [Re: Baltic] #217529
08/13/10 03:03 PM
08/13/10 03:03 PM
yes, this is my problem.
Upwind when you get a gust you do not change to much, 2-3 degree max. But downwind sometimes I need to bear away 15-20 degree, or more. So no stable reference direction.
Sanyi
Nacra Infusion
www.catsailing.hu
Re: Identify windshifts in downwind [Re: CatSailingHu] #217555
08/14/10 11:19 AM
08/14/10 11:19 AM
mikekrantz Offline
mikekrantz  Offline
Same as upwind. You have to determine whether it's velocity causing the shift or wind direction. Once the puff goes away, have you returned to your original heading??
Re: Identify windshifts in downwind [Re: mikekrantz] #217574
08/15/10 05:46 AM
08/15/10 05:46 AM
Tornado_ALIVE Offline
Apparent wind boats, look for pressure not shifts downwind unless it is VERY consistant and shifts are large.
Re: Identify windshifts in downwind [Re: Tornado_ALIVE] #217593
08/15/10 04:36 PM
08/15/10 04:36 PM
Agreed. As someone said above; you get a gust you bear off 20 or more degrees; Unless they are big shifts or bends; just look for pressure.
0 registered members (), 297 guests, and 53 spiders.
