| Re: Racine Catamaran Championships 2010
[Re: tback]
#217483 08/13/10 07:52 AM 08/13/10 07:52 AM | andrewscott
| andrewscott
Unregistered | Unfortunately, my boat was staked down and the mast rotator was taught. It pulled the nearly 4 feet of the auger out of the sand. More F18 than F16 flipped and they were staked down as well. Wind was howling. What I did learn was to stake down both sides using the trap wires.
Mark Thomson has loaned me his Blade mast and I am back in business. I use various anchor methods depending on the soil. For sand, I use 2x4 (about 2' long) with a line tied to them. I dig a hole in the sand to bury the 2x4 and then secure it to the trap line (same for the other side). If the ground is hard I use 18" screw anchors for each side and tie the line to the trap handle. how deep do you bury the 2x4? I have a small shovel and dig out the sand about 18" deep, insert the 2 x 4 and cover with the sand and tap down with your feet. You won't pull it out of the sand easily! good info thanks | | | Re: Racine Catamaran Championships 2010
[Re: F-18 5150]
#217519 08/13/10 01:56 PM 08/13/10 01:56 PM |
Posts: 1,430 california | F17 Class Sailed: 6, Discards: 1, To count: 5, Entries: 1, Scoring system: Appendix A Rank Bow # Class SkipperName CrewName R1 R2 R3 R4 R5 R6 Total Nett 1st 52 F17 Wally Schuette 1.0 1.0 1.0 1.0 1.0 (2.0 DNF) 7.0 5.0
Formula 16 Class Sailed: 6, Discards: 1, To count: 5, Entries: 6, Scoring system: Appendix A Rank Bow # Class SkipperName CrewName R1 R2 R3 R4 R5 R6 Total Nett 1st 61 Formula 16 Daniel Feldman Jill Feldman 1.0 1.0 (2.0) 1.0 1.0 1.0 7.0 5.0 2nd 13 Formula 16 Karl Brogger Ela Sliwerska 2.0 2.0 1.0 (4.0) 2.0 2.0 13.0 9.0 3rd 30 Formula 16 Pete Pollard 3.0 3.0 3.0 2.0 3.0 (7.0 DNF) 21.0 14.0 4th 32 Formula 16 Mark Thomson (7.0 DNS) 7.0 DNS 7.0 DNS 3.0 4.0 3.0 31.0 24.0 5th 01 Formula 16 Tom Hoscheidt (7.0 DNS) 5.0 4.0 5.0 7.0 DNF 7.0 DNS 35.0 28.0 6th 55 Formula 16 Davie Winquist Frankie Hearn Owen Eliasen (7.0 DNF) 4.0 7.0 DNF 7.0 DNF 7.0 DNS 7.0 DNS 39.0 32.0
Nacra 20 Class Sailed: 6, Discards: 1, To count: 5, Entries: 7, Scoring system: Appendix A Rank Bow # Class SkipperName CrewName R1 R2 R3 R4 R5 R6 Total Nett 1st 500 Nacra 20 Trey Brown Bryan Paine 1.0 1.0 (5.0) 1.0 1.0 4.0 13.0 8.0 2nd 08 Nacra 20 Guy Selsmeyer Dustin DeFelice 3.0 (4.0) 1.0 2.0 3.0 2.0 15.0 11.0 3rd 20 Nacra 20 Mike Hill Holly Hoffman 2.0 2.0 4.0 4.0 (5.0) 3.0 20.0 15.0 4th 42 Nacra 20 Christopher Blake Corey Hatch (5.0) 3.0 2.0 5.0 2.0 5.0 22.0 17.0 5th 68 Nacra 20 Clay Selsmeyer Alex Selsmeyer 4.0 6.0 3.0 (7.0) 4.0 1.0 25.0 18.0 6th 10 Nacra 20 Dale Eigenberger Nick Hatch (7.0) 5.0 6.0 6.0 6.0 6.0 36.0 29.0 7th 64 Nacra 20 Ed Winders Corey Roebbeke 6.0 (7.0) 7.0 3.0 7.0 7.0 37.0 30.0
[Re: F-18 5150]
#217532 08/13/10 03:21 PM 08/13/10 03:21 PM |
Posts: 3,224 Roanoke Island ,N.C. | Extra ! Extra! Read all about it. A-hole triumphs over punk.
26th 09 672 David Ingram Kathy Ingram 15.0 23.0 (39.0) 23.0 34.0 134.0 95.0 27th 16 1162 Bill Gillespie Martin Brosch (35.0) 25.0 25.0 28.0 17.0 130.0 95.0 28th 29 GER 623 Uli Gollwitzer Alex Prohaska 20.0 (37.0) 18.0 35.0 31.0 141.0 104.0 29th 18 1025 Todd Riccardi Brendon Scanlon 34.0 (38.0) 24.0 38.0 10.0 144.0 106.0
[Re: Team_Cat_Fever]
#217586 08/15/10 10:54 AM 08/15/10 10:54 AM |
Posts: 3,906 Clermont, FL, USA | Extra ! Extra! Read all about it. A-hole triumphs over punk.
26th 09 672 David Ingram Kathy Ingram 15.0 23.0 (39.0) 23.0 34.0 134.0 95.0 27th 16 1162 Bill Gillespie Martin Brosch (35.0) 25.0 25.0 28.0 17.0 130.0 95.0 28th 29 GER 623 Uli Gollwitzer Alex Prohaska 20.0 (37.0) 18.0 35.0 31.0 141.0 104.0 29th 18 1025 Todd Riccardi Brendon Scanlon 34.0 (38.0) 24.0 38.0 10.0 144.0 106.0 That alone made the 24 hour drive one way, disappointing weather and the $$$ worth it. Grandpa Ding still rules!
[Re: David Ingram]
#217588 08/15/10 11:13 AM 08/15/10 11:13 AM |
Posts: 5,525 | Kudos to CRAW and Racine Yacht Club. Superb effort on their part.
Thanks to all the sponsors.
Pete Pollard Blade 702
[Re: pgp]
#217618 08/16/10 08:45 AM 08/16/10 08:45 AM |
Joined: Jul 2005 Posts: 267 Ocean Springs, MS Capt_Cardiac
Posts: 267 Ocean Springs, MS | Where are the Championships going to be held in 2011? cc
Capt Cardiac Ocean Springs Yacht Club Sailor Nacra20 - Flight of Ideas #5 | | | Re: Racine Catamaran Championships 2010
#217619 08/16/10 08:48 AM 08/16/10 08:48 AM | andrewscott
| andrewscott
Unregistered | Extra ! Extra! Read all about it. A-hole triumphs over punk.
26th 09 672 David Ingram Kathy Ingram 15.0 23.0 (39.0) 23.0 34.0 134.0 95.0 27th 16 1162 Bill Gillespie Martin Brosch (35.0) 25.0 25.0 28.0 17.0 130.0 95.0 28th 29 GER 623 Uli Gollwitzer Alex Prohaska 20.0 (37.0) 18.0 35.0 31.0 141.0 104.0 29th 18 1025 Todd Riccardi Brendon Scanlon 34.0 (38.0) 24.0 38.0 10.0 144.0 106.0 hahah... funny | | | Re: Racine Catamaran Championships 2010
[Re: Capt_Cardiac]
#217621 08/16/10 09:09 AM 08/16/10 09:09 AM |
Posts: 5,525 | Depends on what you sail I suppose. F16s will be here, in Sept. 2011. http://www.westriversc.org/
[Re: David Ingram]
#217670 08/16/10 05:14 PM 08/16/10 05:14 PM |
26th 09 672 David Ingram Kathy Ingram 15.0 23.0 (39.0) 23.0 34.0 134.0 95.0 27th 16 1162 Bill Gillespie Martin Brosch (35.0) 25.0 25.0 28.0 17.0 130.0 95.0 28th 29 GER 623 Uli Gollwitzer Alex Prohaska 20.0 (37.0) 18.0 35.0 31.0 141.0 104.0 29th 18 1025 Todd Riccardi Brendon Scanlon 34.0 (38.0) 24.0 38.0 10.0 144.0 106.0 That alone made the 24 hour drive one way, disappointing weather and the $$$ worth it. Grandpa Ding still rules! Gives hope to us old guys. keep it up, Ding.
#217713 08/17/10 09:48 AM 08/17/10 09:48 AM |
Posts: 5,525 | http://www.kattack.com/ Look for CRAW F18 (or F16 if you're interested)
[Re: pgp]
#217737 08/17/10 04:11 PM 08/17/10 04:11 PM | DUH
| DUH
Unregistered | I kinda put everything together here JCWW There was an unbelievable amount of coverage in pics, stories, interviews, live webcasting, tracking..on and on on on on on. Well done by the media! Look out for the I4C coming up on SA!
21,417
guests, and 762
