Ideas for adding Kite to NACRA 5.2???? #217729
08/17/10 01:28 PM
08/17/10 01:28 PM
Seabass Offline OP
Seabass  Offline OP
Hey,
I have all of the equipment for a kite kit for 5.2 but i have yet to put it together. My hold up has been the furthest rigging towards the bow... the way i see it done mainly is by drilling through the hulls and trying to reinforce that with resin. I was wondering if anyone had any less labor intensive ideas, maybe attaching hardware to the hulls?
any ideas would be great, thanks!!
Re: Ideas for adding Kite to NACRA 5.2???? [Re: Seabass] #217730
08/17/10 01:59 PM
08/17/10 01:59 PM
That's probably the cleanest...but drill through the bows, glue in a piece of fiberglass or carbon tubing, and trim it/sand it to perfection is easier.
Re: Ideas for adding Kite to NACRA 5.2???? [Re: Jake] #217731
08/17/10 02:17 PM
08/17/10 02:17 PM
andrewscott
andrewscott
couldn't be much easier than that... shouldn't take more than an hour or 2...
Re: Ideas for adding Kite to NACRA 5.2???? [Re: Jake] #217732
08/17/10 02:18 PM
08/17/10 02:18 PM
andrewscott
andrewscott
couldn't be much easier than that... shouldn't take more than an hour or 2, and shouldn't hold up the sheer joy of flying a spin
Re: Ideas for adding Kite to NACRA 5.2???? [Re: ] #217747
08/17/10 05:55 PM
08/17/10 05:55 PM
Y
yurdle Offline
yurdle  Offline
Y
The spin you're planning to use -- what size is it? what was it originally cut for? How long's the pole?
My boat w/out re-enforcement most likely wouldn't hold up TO the sheer joy of flying a spin..
Re: Ideas for adding Kite to NACRA 5.2???? [Re: yurdle] #217749
08/17/10 06:34 PM
08/17/10 06:34 PM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
I don't have holes in my bows I have dyneema line running from my bridal tangs to the end of the pole and another dyneema line running from the bridal tang straight across the boat to the other tang attaching to the pole in the middle. Just do the two shackles up at the bridal tangs then tighten the line under the jib bridal until your happy with the bend.
Taipan spin setup.jpg (134 downloads)
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Ideas for adding Kite to NACRA 5.2???? [Re: JeffS] #217761
08/17/10 11:26 PM
08/17/10 11:26 PM
Seabass Offline OP
Seabass  Offline OP
Jeff that is really what i was hoping to do, but i am glad someone else did it so i could see that it would work....
Yurdle, i have an old tornado kite that is waaay oversize but plan on significantly cutting it down once i have an idea of the size it should be.
which i guess brings up the question... anybody have approximate luff and foot lengths for a kite?
Thanks for all the help already
Re: Ideas for adding Kite to NACRA 5.2???? [Re: Seabass] #217765
08/18/10 05:15 AM
08/18/10 05:15 AM
France
pepin Offline
pepin  Offline
France
My setup is the same as JeffS on my 5.2. No need to drill anything.
I use a F16 spi.
Re: Ideas for adding Kite to NACRA 5.2???? [Re: Seabass] #217767
08/18/10 05:57 AM
08/18/10 05:57 AM
Because of the intricate nature of the paneling in a spinnaker, it's not easy to cut down the size of one and have it work well...
Re: Ideas for adding Kite to NACRA 5.2???? [Re: Jake] #217783
08/18/10 01:31 PM
08/18/10 01:31 PM
TurboCat Offline
TurboCat  Offline
I drilled the bow's on my 5.2. The lines going back to the bridal mounts worked but it felt alot more secure with the bow lines in. I ran a F17 kite and endpole set-up and it worked great.
0 registered members (), 21,808 guests, and 852 spiders.
4 hours ago
