| using gps #218380 08/27/10 04:34 AM 08/27/10 04:34 AM |
Posts: 5,525 | Does anyone know if the Foretex 301 will allow me to upload gps waypoints and another person download them into their gps device?
Thanks.
Pete Pollard Blade 702
| | | Re: using gps
[Re: pgp]
#218381 08/27/10 06:40 AM 08/27/10 06:40 AM |
Posts: 12,310 South Carolina | Does anyone know if the Foretex 301 will allow me to upload gps waypoints and another person download them into their gps device?
Thanks. Yes - but you'll need a PC interface cable and a PC with the Garmin software.
Jake Kohl | | | Re: using gps
[Re: pgp]
#218424 08/27/10 07:00 PM 08/27/10 07:00 PM |
Posts: 757 japan | if you have garmin's mapsource software
you'd use it to connect to your foretrex and download the tracks, waypoints and routes
then you'd delete the tracks and routes leaving only the waypoints
then save the file as something like pgpwaypoints.gpx file
thius .gpx file can be sent by email as an attachment
the receiver could then load the .gpx file to pretty much any gps that had a computer connection as .gpx files are supposed to be the new standard for gps transfers
if you don't have mapsource there are many other freeware programs that can do much the same thing
| | | Re: using gps
[Re: erice]
#218439 08/28/10 09:14 AM 08/28/10 09:14 AM |
Posts: 5,525 | Thanks Eric. I'm planning to use "Garmin Connect", but this is all new to me.
Any idea how accurate the speed is for the Foretrex?
| | | Re: using gps
[Re: pgp]
#218450 08/28/10 05:22 PM 08/28/10 05:22 PM |
Posts: 757 japan | speed readings are generally very accurate on gps as long as they have a good lock on the sats. eg they are generally MUCH more accurate than car speedometers (zero to +10%) which rely on tyre size, eddy currents, cables etc.
but they can sometimes give some wacky results, like 500mph, when you startup in a new area. however once settled down with a good lock and open skies they are the best
after all the top units are used to measure changes in the earth's surface of less than an inch around volcanoes and fault lines etc
| | | Re: using gps
#218586 08/30/10 12:58 PM 08/30/10 12:58 PM |
Posts: 571 Hamburg | Does anyone know if the Foretex 301 will allow me to upload gps waypoints and another person download them into their gps device?
Thanks. Yes - but you'll need a PC interface cable and a PC with the Garmin software. I had the 201 and it worked also with usual freeware. Problem was the pin... so it is no on the seabed. Cheers, Klaus | | | Re: using gps
[Re: Smiths_Cat]
#218594 08/30/10 02:40 PM 08/30/10 02:40 PM |
Posts: 5,525 | Hmm, that's good to know! This one has a velcro thingey to wear around the forearm. I was going to mount it on the boom. Maybe not.
| | | Re: using gps
[Re: ThunderMuffin]
#218599 08/30/10 02:50 PM 08/30/10 02:50 PM |
Posts: 5,525 | Well...at least he didn't use duck tape.
| | | Re: using gps
[Re: pgp]
#218607 08/30/10 05:51 PM 08/30/10 05:51 PM |
Joined: Jun 2004 Posts: 502 Port Noarlunga, SA, Australia Darryn
Posts: 502 Port Noarlunga, SA, Australia | As long as the 201 doesn't get to wet they are fine. In conditions were its being blasted with water, which happened to my boom mounted units, they failed.
I have yet to find a waterproof gps, even velocitek speedpucks, which I use now, get a bit misty inside and require regular dissassembly and drying out.
On the plus side with the foretrex most of them come back to life after a drowning, one of them it took over a year to dry out enough to work, but it does.
Darryn Mosquito Bullet 1782 | | | Re: using gps
[Re: Darryn]
#218609 08/30/10 06:13 PM 08/30/10 06:13 PM |
Posts: 5,525 | I got the 301. It arrived today. Hopefully, the bugs have been worked out.
Years ago, a friend had trouble with his expensive "yachting chronometer" (wrist watch), falling off his wrist and disappearing into the drink. So, he cut a section off the arm of a defunct wet suit, cut a hole in it so he could read his watch and slipped it over his wrist and watch. He was able to push all the buttons just fine and had no more problems. Maybe I'll try something like that, except on the boom.
| | | Re: using gps
[Re: Dan_Delave]
#218646 08/31/10 11:41 AM 08/31/10 11:41 AM |
Posts: 5,525 | Hopefully you'll post some picture? Details get the best of me.
| | | Re: using gps
[Re: pgp]
#218923 09/07/10 11:33 AM 09/07/10 11:33 AM |
Posts: 5,525 | So, I'm finally getting around to the Foretrex 301. All I've been able to determine so far is that I must buy a download from Paretologic. It's only $30, still, does this sound right? https://buy.paretologic.com/safecar...&uid=0&buttonTrackingID=18597837
| | | Re: using gps
[Re: ThunderMuffin]
#218925 09/07/10 11:56 AM 09/07/10 11:56 AM |
Posts: 5,525 | thanks Tad. I owe you a beer.
| | | Re: using gps
[Re: ThunderMuffin]
#218952 09/07/10 06:39 PM 09/07/10 06:39 PM |
Posts: 1,200 Vancouver, BC | GPS Action Replay can be used to replay your entire track on a pc and even on a webpage..like google earth...but also has sailing specific indicators/features.
484
guests, and 30
