NACRA 5.2 JIB WIRE SLOT LOCATION #219721
09/16/10 05:17 PM
09/16/10 05:17 PM
ROLAND HAILE Offline OP
I've a NACRA 5.2, 1980 version with the jib wires on top of the tramp. If I locate the wires below the tramp, what is the location of the two slots that will be put in the tramp for the jib wires? Also is the wire location from the hull the same distance as the original jib wire? or located futher outboard towards the hull? I ask that question because my wires are approx 14" from the hull but on the following site they have the wire located 7-11 iches inboard. http://www.slosailandcanvas.com/servlet/the-879/Nacra-5.2-New-%2872.5%27%27%29/Detail Thank you.
Re: NACRA 5.2 JIB WIRE SLOT LOCATION [Re: ROLAND HAILE] #219738
09/16/10 07:50 PM
09/16/10 07:50 PM
japan
erice Offline
erice  Offline
japan
the early models had the jib block wires running more inboard
later models moved them further outboard
presumably the factory moved them further outboard as they worked better
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: NACRA 5.2 JIB WIRE SLOT LOCATION [Re: erice] #219741
09/16/10 08:35 PM
09/16/10 08:35 PM
Sounds right. I moved only one jib wire under the tramp and went for a sail. Seems there was less power on that side. Like there needed to be more seperation b/t the jib and main.
0 registered members (), 621 guests, and 207 spiders.
