| Re: mast rotation when flying a spin
[Re: davefarmer]
#219899 09/20/10 12:08 AM 09/20/10 12:08 AM |
Posts: 586 Hobart, Tasmania, Oz. | Ok...
The SPI loads up the mast above the hounds and diamond, so if the mast is going to break it will be the unsupported section just above the hounds. so we can rule out the diamonds as being a factor in supporting the mast.
the SPI is loading up the mast in a forward and leeward direction. you would hope more forward if the boat is going fast. The main support for the forward force is the main sheet, a tight main sheet will act as a back stay preventing the mast from failing from the forward forces.
The leeward force is being supported by the major axis of the mast, particularly in a wing mast as it is very strong across its major axis (the fore and aft one). if you don't have the mast rotated you will be presenting the minor axis of the mast to the leeward forces and make it more susceptible to failure.
as far as performance goes, the mast should be rotated downhill to 90 degrees anyway.
[Re: Dazz]
#219908 09/20/10 07:22 AM 09/20/10 07:22 AM |
Posts: 246 Kiel, Germany | On inquiring some time at AHPC concerning this subject, I received the following reply: "The mast rotation should be at about 80deg on the downwind leg. The tuning guide is not accurate in this description as 80 deg would have the mast spanner pointing slightly forward of the sidestay. In practice if the mast is completely free to rotate downwind at times it will rotate past 90 deg. The only problem with this is that the boat is not quite as fast. If the mast is rotated a lot less, say 50 deg, then the mast bends too much sideways which can be bad for the mast. Also the air flow around the mast is not as good and the boat is slower."
F18: C2 / A-Cat: Minelli
[Re: Dazz]
#220448 09/28/10 12:24 AM 09/28/10 12:24 AM |
Joined: May 2008 Posts: 107 Melbourne, Australia MitchB
Posts: 107 Melbourne, Australia | when they do break don't they normally break between the spreaders and the hounds? That where I have have seen them go (not my own mast)
Stingray #579 GLYCish
[Re: MitchB]
#220632 09/30/10 04:58 AM 09/30/10 04:58 AM |
Joined: Aug 2007 Posts: 142 3 weeks Newman WA 1 week Robe ... Brian P
Posts: 142 3 weeks Newman WA 1 week Robe ... | in my I14 days we used to have a telescopic type mast setup, such that light days = big rig, heavy days = small rig. you would reef the mainsil from the bottom. i.e. roll and zip up the bottom 700mm and you would have two sets of tack/clew points. one of our guys thought it would be easier to leave mast at full height and just run the main up the mast so the head was about 700mm from the top. end result was ( in this order and about same timing as you are reading) 1, round top mark 2, kite goes up to mast head 3, sheet comes on 4, top of mast comes off it was plain and simple to see that it is the leach / sheet tension of the mainsail that holds the mast up under spin p.s. and we were all using diamonds to the mast head, swept back at about 45 degrees.
Brian Partridge STINGRAY 580 "Fantasia" A Class 585 "FHARKEN A"
YOU CAN'T POLISH A TURD BUT YOU CAN ROLL IT IN GLITTER!!!!!
[Re: Baltic]
#221564 10/13/10 09:54 AM 10/13/10 09:54 AM |
Posts: 606 League City, TX | On inquiring some time at AHPC concerning this subject, I received the following reply: "The mast rotation should be at about 80deg on the downwind leg. The tuning guide is not accurate in this description as 80 deg would have the mast spanner pointing slightly forward of the sidestay. In practice if the mast is completely free to rotate downwind at times it will rotate past 90 deg. The only problem with this is that the boat is not quite as fast. If the mast is rotated a lot less, say 50 deg, then the mast bends too much sideways which can be bad for the mast. Also the air flow around the mast is not as good and the boat is slower." Certainly good advice when buoy racing.For distance racing if you have a stout mast (not a wing mast) then you can rotate in to depower when reaching - this bends off the top of the mast. Looks horrible - but lets you carry the spin higher than not doing it - which can be the difference between dropping the kite and dropping back - or keeping it up and staying out front. Not advisable on a wing mast...
[Re: mikekrantz]
#222004 10/19/10 08:11 AM 10/19/10 08:11 AM |
Posts: 120 | Anybody ever think of changing from a wing mast to a 'standard' mast for the distance stuff for this reason alone?
[Re: maritimesailor]
#222098 10/19/10 10:18 PM 10/19/10 10:18 PM |
Posts: 606 League City, TX | Anybody ever think of changing from a wing mast to a 'standard' mast for the distance stuff for this reason alone? Yes. Of course you also need a sail cut for that standard mast to be competitive. | | | Re: mast rotation when flying a spin
#222141 10/20/10 08:43 AM 10/20/10 08:43 AM |
Posts: 976 France | Just a thought, more of an academic thought. Wonder what you would change for a 'standard' mast on the sail, I woudl suspect the draft would change a lot, specifically in the luff area. The sail would be bigger for a start as the sail area is main sail + mast area. Picking up a mast with less circumference will allow for more sail area somewhere else. | | |
1 registered members (FredL),
2,799
guests, and 283
