to Jib or not to Jib? #22037
07/10/03 09:10 AM
07/10/03 09:10 AM
Doschev Offline OP
Doschev  Offline OP
I'm researching buying a new club wave and was wondering whether I should get the jib. What do you think?
Thanks
No! Get the Hooter Kit -- coming next week [Re: Doschev] #22038
07/10/03 11:47 AM
07/10/03 11:47 AM
RickWhite Offline
RickWhite  Offline
The jib kit does not work on the Wave. It adds a sail, but it is pretty useless as you cannot put any luff tension on it.
Meanwhile, here is a previous post that explains it all:
Finally back home and happy with my DSL.
OK, I was about to go into a lengthly dissertation and realized it is all on the page linked below.
The Hobie jib set up does not work at all -- you cannot put any load on the forestay as it will simply bend the pole between the bows. So, be sure to take a look at what you can do.
Here is the link:
http://www.catsailor.com/waves/superwave_overall.html
Good luck,
Rick
Rick White
www.onlinemarinestore.com
Re: to Jib or not to Jib? [Re: Doschev] #22039
07/14/03 10:25 AM
07/14/03 10:25 AM
Portland, OR
BarrySteel Offline
BarrySteel  Offline
Portland, OR
I just go the jib kit for my Wave about a month ago. Definitely faster (I can't say how much, but quite noticable
in the 7-15 knot winds I usually sail in. I would agree that a better system to tension would be good (I plan on trying Rick's
method using two pieces of stay-cable across the bows and avoid connecting directly to the spreader bar.
I might also mention that the jib saved my buns the other day. I got caught out in gusting-to-28mph weather and dropped the main
and sailed home using the jib only. That was pretty quick downwind sailing even with the tiny jib let me tell you!
barry
Re: to Jib or not to Jib? [Re: Doschev] #22040
04/21/04 09:50 PM
04/21/04 09:50 PM
Titusville, Florida
Gus Offline
Gus  Offline
Titusville, Florida
Anyone know where I can find a used jib?
Gus
0 registered members (), 681 guests, and 362 spiders.
