Mozzy photos from Milang SA 30th Sept #221411
10/11/10 05:07 AM
10/11/10 05:07 AM
Kingston SE South Australia
JeffS Offline OP
JeffS  Offline OP
G'day heres some photos of Peter in 20 to 30 knots making it look so easy, he eventually went in when he broke a rudder.
Peter on his Mozzy.jpg (2612 downloads)
Peter on his Mozzy2.jpg (1061 downloads)
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Mozzy photos from Milang SA 30th Sept [Re: JeffS] #221414
10/11/10 05:21 AM
10/11/10 05:21 AM
thricebitten
thricebitten
If that is 20 to 30 knots, he shouldn't have his foot that full. Irwin sails unlike some other Mossie sails I have used are very sensitive to foot depth, flattening foot is a major part of depowering them.
Re: Mozzy photos from Milang SA 30th Sept [Re: JeffS] #221421
10/11/10 06:12 AM
10/11/10 06:12 AM
Peter_Foulsum Offline
Jeff,
Is that a carbon fibre boom Peter is using ??? shocked
Mosquito 1814
Macka Mozzie
Re: Mozzy photos from Milang SA 30th Sept [Re: Peter_Foulsum] #221422
10/11/10 06:36 AM
10/11/10 06:36 AM
JeffS Offline OP
JeffS  Offline OP
I don't know what boom he was using it was full on 20 gusts to 30 recorded at the clubhouse I've got other photos on my blog site which shows a sequence of a 5.7 going over and more excitement. I said to Peter he makes it all look pedestrian the way he calmly just sails along while I splash and yell at my crew. I ripped my main sail broad reaching to the start line when a wave hit the back of the sail it may have had a fish in it and also blew my PFD apart. One of the photos shows the rips
http://beachcatsaustralia.ning.com/photo/album/listForOwner?screenName=2x6sbetq65fle
regards
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Mozzy photos from Milang SA 30th Sept [Re: JeffS] #221458
10/11/10 03:57 PM
10/11/10 03:57 PM
To windward of you!
Sixth Element Offline
To windward of you!
hi Peter,
Yes Peter Hallsworth has joined the carbon club and got a carbon boom on his boat.. Makes 3 of us with them now..
"Sixth Element"
1782 MK2 w/spinnaker.
Lake Bonney Y.C.
National Sec. / S.A President / S.A Measurer / Commodore LBYC
Re: Mozzy photos from Milang SA 30th Sept [Re: Sixth Element] #221463
10/11/10 05:40 PM
10/11/10 05:40 PM
Simon C Offline
Simon C  Offline
What section are you guys using and how is it holding up?
That one seems to be doing well given the reported conditions smile
Love to see a photo of the outhaul setup. I've been considering going carbon as the only old thing on my new girl is the rectangular section alloy boom.
Simon
Taipan AUS341
Re: Mozzy photos from Milang SA 30th Sept [Re: Sixth Element] #221464
10/11/10 05:43 PM
10/11/10 05:43 PM
Fulham S.Aust
Wannabe Offline
Wannabe  Offline
Fulham S.Aust
Hey Gary.
Foot? is that the downhaul? As I have been told that you require less downhaul the more wind and to pull it on when you encounter light winds. I realise that everyone will have a different version on this but is that the general idea :blush. I did have a 505 for a few years and was told to pull everythig tight in the big blows.
Saw it on a cartoon once.....I'm pretty sure I can do it
Mozzie
1728
Re: Mozzy photos from Milang SA 30th Sept [Re: Wannabe] #221479
10/11/10 10:20 PM
10/11/10 10:20 PM
Scarecrow
Scarecrow
Foot is traditionally outhaul.
Unless mossies are different to every cat I've ever sailed, more wind= more downhaul.
Re: Mozzy photos from Milang SA 30th Sept [Re: Wannabe] #221482
10/12/10 01:27 AM
10/12/10 01:27 AM
thricebitten
thricebitten
Originally Posted by Wannabe
Hey Gary.
Maybe a slight misunderstanding on what you have been told, definetly more downhaul the stronger the wind, on a Mossie it helps bend the mast which flattens the sail, as well as opening the leech.
By talking about flattening the foot of the sail, I was referring to the need for more outhaul. Generaly the outhaul is increased with increasing wind strength also.
It is all about control and speed, if you can control the power of the sail with where your settings are and you are sailing fast, they are ok for you. But if you are struggling to control the boat and feel overpowered, flattening the sail should help with control and increase speed.
Re: Mozzy photos from Milang SA 30th Sept [Re: ] #221490
10/12/10 07:05 AM
10/12/10 07:05 AM
Beyond a Joke Offline
Hi Guys,
To answer a few questions : Yes the boom on my boat is carbon fibre. I obtained it from New Zealand about 15 months ago, so it has already done a season without problems, though never before in winds as strong as those encountered at Milang. The outhaul is set up the same as on an A class. i.e. a simple 2:1 pulley attached to the clew, back through an exit block into the boom and exiting to a swivelling cleat on the underside of the boom and within east reach of the skipper.
Garry is right---I didn't have enough outhaul on on the day, but found the boat easy enough to control with full Cunningham tension, mast de-rotated to about 20 degrees and traveller out to the footstraps. Oh and it was going like a rocket too, though I must admit that height was a bit compromised. Damn good fun until the leeward rudder snapped that afternoon...
Regards Peter
Mosquito 1777
Re: Mozzy photos from Milang SA 30th Sept [Re: ] #221491
10/12/10 07:13 AM
10/12/10 07:13 AM
Hi Guys,
Regards Peter
Mosquito 1777
Re: Mozzy photos from Milang SA 30th Sept [Re: Simon C] #221493
10/12/10 08:22 AM
10/12/10 08:22 AM
JeffS Offline OP
JeffS  Offline OP
Your wish is my command grin
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Mozzy photos from Milang SA 30th Sept [Re: JeffS] #221516
10/12/10 03:59 PM
10/12/10 03:59 PM
To windward of you!
To windward of you!
Hi All,
Dad and I have been using Carbon booms for the past 4-5 seasons. Our sections were made By Composite Spars and Tubes (CST) in Sydney, (they make everything carbon, tillers/rudder cross bars etc) Dad worked with them to come up with a 50mm tube section that is doing an excellent job which we have never had any problems even in a few 30knt plus winds, will break alot more before break carbon.
Our outhaul system is pretty much the same as Peter Hallsworth decribed, the same as the A Class system with a loop on the mainsail clew and then 2:1 system internal in the boom, this works well.
If anyone wants any details on the section specs, Dad or myself will be happy to help you out.
"Sixth Element"
Lake Bonney Y.C.
Re: Mozzy photos from Milang SA 30th Sept [Re: Sixth Element] #221540
10/13/10 06:17 AM
10/13/10 06:17 AM
Simon C Offline
Simon C  Offline
Thanks for that (and the photos Jeff). Details would be great. I'm curios about the fit out as looking at the photo there seem to be some load points that are not recomended by CST.
Simon
Taipan AUS341
Re: Mozzy photos from Milang SA 30th Sept [Re: Beyond a Joke] #221673
10/14/10 11:41 PM
10/14/10 11:41 PM
thricebitten
thricebitten
Regards Peter
Mosquito 1777
[/quote]
Hi Peter,
settings sound familiar, Irwin Sails are awesome in these conditions, they just blade out so well and go sooooooooo fast grin. Glad to hear you are enjoying it. Sorry to hear about the rudder blade, where they ones you made yourself? Did you have centre boards up a bit when it broke? That allways puts a lot of extra load on rudders.
0 registered members (), 668 guests, and 142 spiders.
Posts267,056
