Page 2 of 8 1 2 3 4 5 6 7 8
Re: See the F20c in person [Re: ThunderMuffin] #221725
10/16/10 12:44 AM
10/16/10 12:44 AM
Australia
macca Offline
macca  Offline
Australia
if you can't see the youtube video (some countries are not able to ...)
try this link:- F20C Rib video (Vimeo)
________________________
http://aus300.blogspot.com
Re: See the F20c in person [Re: macca] #221737
10/16/10 07:19 AM
10/16/10 07:19 AM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
Mike.. did you get Chuck Allen from North Sails out? He's usually one of the BOTY judges.
Re: See the F20c in person [Re: wildtsail] #221738
10/16/10 07:23 AM
10/16/10 07:23 AM
mikekrantz Offline OP
yes, Chuck was one of the judges. He had a blast.
Re: See the F20c in person [Re: mikekrantz] #221766
10/16/10 05:51 PM
10/16/10 05:51 PM
looks like quite an awesome boat. I want one. replacement board has to be at least 800$ though. that would suck.
Re: See the F20c in person [Re: PTP] #221772
10/16/10 06:52 PM
10/16/10 06:52 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Replacement board I heard was $1300
Re: See the F20c in person [Re: ThunderMuffin] #221773
10/16/10 07:02 PM
10/16/10 07:02 PM
I paid that for my first Hobie 16.
Re: See the F20c in person [Re: ThunderMuffin] #221774
10/16/10 08:26 PM
10/16/10 08:26 PM
are you friggin kidding? I was thinking 1k, but wanted to give them the benefit of doubt.
Re: See the F20c in person [Re: PTP] #221775
10/16/10 09:51 PM
10/16/10 09:51 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
Macca said the boards are same as the infusion boards price wize.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: See the F20c in person [Re: F-18 5150] #221779
10/17/10 01:32 AM
10/17/10 01:32 AM
Australia
macca Offline
macca  Offline
Australia
I said:- it's comparable to an F18 board in price/size ratio
The F18 board is smaller and hence cheaper. The F20 boards are doing a lot more than a normal daggerboard, so don't underestimate the complexity of their job!
Re: See the F20c in person [Re: macca] #221786
10/17/10 03:41 AM
10/17/10 03:41 AM
Remember this when Macca makes another (broad) statement in the future guys !
With him there is always a catch !
Re: See the F20c in person [Re: Wouter] #221825
10/18/10 02:48 AM
10/18/10 02:48 AM
Australia
macca Offline
macca  Offline
Australia
Wouter, you are without a doubt a world class clown.
I don't think i could have made it any clearer in my statement: the price/size ratio is comparable to the F18... pretty freaking simple really! The F20 boards are clearly bigger so they are more expensive but not 4 times the cost etc..
Re: See the F20c in person [Re: macca] #221831
10/18/10 04:12 AM
10/18/10 04:12 AM
waynemarlow Offline
waynemarlow  Offline
I have to side with Wouter on this, Macca you do have such a subtle way of avoiding direct dialogue, with words which direct sideways any real meaning. You should be a politician, mind you there is a problem, no one any longer believes a politician. wink
Re: See the F20c in person [Re: waynemarlow] #221832
10/18/10 04:20 AM
10/18/10 04:20 AM
Australia
macca Offline
macca  Offline
Australia
Wayne, I am not going to quote spare parts prices in here for the simple fact that there are different prices in each country due to local variations and taxes etc. So I think its pretty reasonable to make a comparison between the F18 board costs and the F20 to point out that the board is not stupidly expensive compared to a "normal board"
Re: See the F20c in person [Re: macca] #221835
10/18/10 05:52 AM
10/18/10 05:52 AM
waynemarlow Offline
waynemarlow  Offline
So where did the personal attack on Wouter come into it.
Macca you always have a smoke and mirrors message with everything you write, we have simply become used to it. When people are asking you straight questions, give a straight answer and we would all be better off.
If Nacra design the board correctly, there is little in extra cost in materials and time to produce it over a normal board ( the surface area is not unsimilar ), in theory then it should be a similar price to a normal F18 ? My bet is that won't be the case.
Re: See the F20c in person [Re: waynemarlow] #221836
10/18/10 06:04 AM
10/18/10 06:04 AM
Australia
macca Offline
macca  Offline
Australia
Wayne, again you simply just don't understand how stuff is built. The material costs in building the curved boards correctly is more than a straight board, the time is more also. The internal structure is very hard to build. Consider this: to have a high density stringer inside an F18 board is pretty easy, you just insert a straight spar in the build process. Now how do you do that for the curved f20? You have to make the stringer pre curved and the loads (as you can see from onboard video) are very high. So you need to make the board suitably strong.
keeping that in mind, the price of a F20 Carbon board is not drastically different from a F18 board, especially when you consider that the board is larger as well.
Re: See the F20c in person [Re: macca] #221837
10/18/10 06:22 AM
10/18/10 06:22 AM
waynemarlow Offline
waynemarlow  Offline
Macca you come straight back with the above statment, you know full well that I know more than most about this sort of thing and yet you still put it in writing. This is typical, time you put a bit of thought into things before putting it out on the net.
A curved spar is no more costly nor time consuming to make in mould than a straight spar. May I also remind you that a curved structure is always stronger in one direction than a straight structure which is inherantly weak in both directions, I think the Romans proved that a good few years ago.
As I said earlier you are all smoke and mirrors.
Re: See the F20c in person [Re: waynemarlow] #221840
10/18/10 06:40 AM
10/18/10 06:40 AM
Australia
macca Offline
macca  Offline
Australia
Wayne, I have no idea how much you do or don't know about the subject. But your statements on the matter to date have led me to believe that you have little knowledge. and it has been said that there is nothing more dangerous than someone with a little knowledge of a subject... If you can build curved foils for the same cost as a set of straight boards then please tell us all how to do it. But remember they have to be strong enough...
Re: See the F20c in person [Re: macca] #221845
10/18/10 07:54 AM
10/18/10 07:54 AM
waynemarlow Offline
waynemarlow  Offline
Macca like yourself, compared to some on this forum I know very little, what I do know is that a dagger board is simply built in a process which is no different whether it is curved or not.
Yes you are correct, there will be additional loads requiring additional layers of strengthening fibres, but those fibres will cost little in the comparison to the materials over all costs. I'm talking 10's of dollars rather than 100's.
The highest cost of these type of products is the R & D but over a volume product then most of these costs can be absorbed into quite small numbers per item produced.
Its time we took the ohhhh factor out of curved boards, they have been around a very long time ( the very early Farriers had them way back in the 80's ) and got on with the job of learning how to sail with them as one thing for certain, the marketing boys and girls have them in their sights as the next holy grail and will push them hard in the next few years, what ever their worth.
As I have said before, I will reserve judgement on their worth until classes such as the A class, where the light weight of the platform should enhance this type of structures useage, have firmly come on side.
Re: See the F20c in person [Re: macca] #221846
10/18/10 07:58 AM
10/18/10 07:58 AM
LA
Acat230 Offline
Acat230  Offline
LA
Macca,
I'll put a break in the exchange between you and Wayne. In the test video, it looks like it's a bit too easy to get a "wheelie" with the boat which while cool to watch, does not seem fast in a straight line. Our experience with the curved boards in the A-Class is to fine tune to get just enough lift to keep the bows up but not much more. Some of the A-Cats are using trunks that allow adjustment of the daggerboard fore and aft rake for different conditions.
It looks like you are always sailing with the windward board at least half up both upwind and downwind. Towards the end of the video, there is a shot of the boat sailing upwind on port tack with the leeward board up about 4-6 inches. Do you think the boards may have too much lift potential (like they experienced with the first iteration for the M-20)? Just curious if there might be more fine tuning.
There is still a lot to be learned about curved daggerboards for sure.
Bob Hodges
A-Class USA 230
Re: See the F20c in person [Re: waynemarlow] #221848
10/18/10 08:05 AM
10/18/10 08:05 AM
Australia
macca Offline
macca  Offline
Australia
Wayne, you can think what you like, but its pretty stupid to try and tell me the component cost breakdown of developing and building these things. I know because I have been involved from concept to production. You are making assumptions without any practical application or first hand knowledge.
And to use the A class as a measure of the boards viability is a fallacy as I have pointed out in another thread. But if thats the measure you want to use then go ahead...
0 registered members (), 3,630 guests, and 121 spiders.
