New to Inter/NACRA 20 #221351
10/09/10 06:22 PM
10/09/10 06:22 PM
V
Ventucky Red Offline OP
V
I am the process on getting a NACRA 20 and want to bend the ear of a few of you that have owned these for a few years.
The one I ma getting is going to need a once over when I get it, that is some minor hull work, rigging etc... the normal stuff you looking into when you buy a used boat.
Are there some things that I should be looking at when I go through the refit over the winter. Not so much concerned about the upgrades but more so stuff that would be keeping me off the water come spring - summer.
Thanks
John
Re: New to Inter/NACRA 20 [Re: Ventucky Red] #221461
10/11/10 04:53 PM
10/11/10 04:53 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
I have sat staring blankly at the wall for a while now and really can't think of anything that could be called a weak point on the inter 20! its a really good boat - congratulations!
One trick that I did learn was for when the rudders start to come up a fraction at speed, giving a bit of weather helm. the first instinct is to change or try and tighten the springs. But it is the pairs of rollers that are wearing. If you wrap some insulation tape around the top one to thicken it up a bit, it does the trick.
Re: New to Inter/NACRA 20 [Re: TEAMVMG] #221500
10/12/10 09:55 AM
10/12/10 09:55 AM
Austin, TX
BoK Offline
BoK  Offline
Austin, TX
Check the bridle tangs for fractures.... Don't ask me how I know.
Bo Kersey
Corsair 31-1D 276
Re: New to Inter/NACRA 20 [Re: BoK] #221524
10/12/10 06:44 PM
10/12/10 06:44 PM
V
V
To quote that line form Dirty Harry "Hey...eyes gots to know"
The spinnaker or the forestay jib pairs
Re: New to Inter/NACRA 20 [Re: Ventucky Red] #221531
10/12/10 07:48 PM
10/12/10 07:48 PM
Israel, Sdot Yam
Opher Offline
Opher  Offline
Israel, Sdot Yam
Replace the eye screws that attach each rudder to the top gudgeon (Checking they look good is not enough - don't ask me how I know)
Opher
Nacra F20C ISR1
F18 Cirrus ISR2
Sdot Yam, ISRAEL
Re: New to Inter/NACRA 20 [Re: Opher] #221709
10/15/10 05:26 PM
10/15/10 05:26 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
My last great race against the I20 fleet in SD had us pushing Brandon on the infamous Black boat pretty good...nipping at his heels as the breese came up. On the second of three beats, we were looking good to pass him for the first time on course when we split tacks. Knew it would be closer at the next cross...but we were denied our glory when his main traveller shackle-loop exploded, forcing him to pull up lame and we strolled to victory.
He stated that part was the original...never heard of one blowing up before. We walked around the yard checking other I20's and found one out of the six other boats had a stress crack in the same part.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: New to Inter/NACRA 20 [Re: Tornado] #221762
10/16/10 05:16 PM
10/16/10 05:16 PM
Israel, Sdot Yam
Opher Offline
Opher  Offline
Israel, Sdot Yam
We actually had 2 parts blow in that neighbourhood:
A bolt holding the main traveller shackle loop blew its head - you can't even see cracks without taking it apart.
The becket in the center of the lower main main block, to which the sheet is spliced, blew.
Both times we ended up jury rigging with spare dyneema we always carry aboard.
Opher
Nacra F20C ISR1
F18 Cirrus ISR2
Sdot Yam, ISRAEL
Re: New to Inter/NACRA 20 [Re: Opher] #222224
10/20/10 08:45 PM
10/20/10 08:45 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Definitely replace anything thats metal or plastic on the rudder assembly outside of the castings.
What type of tramp style is it? If its the bolt rope system then you'll need to convert it over to a bolt-rope-lacing system that works much much better.
Other basic boat maintenance stuff applies. It really is a solid boat overall.
Re: New to Inter/NACRA 20 [Re: ThunderMuffin] #222355
10/22/10 11:40 AM
10/22/10 11:40 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
If the tramp is the bolt rope system in the hull with side lacing check the straps coming from the bolt rope in the hull. They wear fairly quickly. If you plan ahead you can find an awning shop to make them for about $1.25 to $1.50 ea. If you don't plan ahead and you have five kids showing up and you find that some have worn thru, you will end up driving to a sail maker and they will charge you $5 each while you wait. Don’t ask me how I know…
I would not sail with too many of these straps that are worn thru since the hull slot can become overloaded. I've seen a crack develop and it then becomes a much larger problem...
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: New to Inter/NACRA 20 [Re: Chris9] #222367
10/22/10 05:38 PM
10/22/10 05:38 PM
V
V
Right now it has the old style tramp and it is in fair to good condition and usable for at least another season. But thats today, things could change tomorrow.
Thanks everyone for your r help here. I appreciate the advice.
Re: New to Inter/NACRA 20 [Re: Ventucky Red] #222665
10/26/10 08:44 AM
10/26/10 08:44 AM
Portland, Maine
Portland, Maine
I have a much better system for the side bolt lacing system than the little webbing tabs. Let me go take pics of mine real quick and I'll brb.
Re: New to Inter/NACRA 20 [Re: ThunderMuffin] #222667
10/26/10 08:59 AM
10/26/10 08:59 AM
Portland, Maine
Portland, Maine
Ok so what we have here is a solid piece of webbing. There's the bolt rope that goes into the slot, and then the holes burned into the webbing for the lacing. There's a 3/8" fiberglass backing rod to support it.
The theory (that has worked for me):
The reason why the old style tramps pulled out of the slot was because the groove in the hull expanded gradually over time. Then came the webbing straps - but the problem with that was that it only put pressure on the bolt rope at very specific points, like right at the daggerboard trunk, and that eventually pulled out of the slot too, or it slowly sliced itself apart over time. The solid piece of webbing with the fiberglass backing rod spreads the load out evenly before it gets to the bolt rope. Its worked for me, and worked well. Only thing to be careful about is the ends will fray.
This set I ordered have reinforced ends to account for that.
Re: New to Inter/NACRA 20 [Re: ThunderMuffin] #225005
12/07/10 05:47 PM
12/07/10 05:47 PM
upper rudder gudgeon (and lower, for that matter) need to be welded on both top and bottom. Don't ask me how I know
Hounds on mast - check how stretched out the forestay attachment hole is.
Those were the only two things that ever gave me trouble... but I wasn't very hard on the boat.
Re: New to Inter/NACRA 20 [Re: ThunderMuffin] #225045
12/08/10 07:50 AM
12/08/10 07:50 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Tad,
Where did you find that webbing? Whats the specs on it?
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: New to Inter/NACRA 20 [Re: waterbug_wpb] #225202
12/10/10 05:26 PM
12/10/10 05:26 PM
V
V
Hounds on mast - check how stretched out the forestry attachment hole is.
How was yours compared to this?
Re: New to Inter/NACRA 20 [Re: Ventucky Red] #225272
12/11/10 02:53 PM
12/11/10 02:53 PM
Israel, Sdot Yam
Opher Offline
Opher  Offline
Israel, Sdot Yam
That's thin and slightly elongated. Just a matter of time till it breaks. We weld stainless steel washers on both sides of the lower hole.
We also run a short 5mm dyneema line through the eyes of all 3 stays and loop it through the top (trapeze) shackle. That way, if the lower hole or shackle gives the mast stays up - Saved the day a couple of months ago.
Opher
Nacra F20C ISR1
F18 Cirrus ISR2
Sdot Yam, ISRAEL
Re: New to Inter/NACRA 20 [Re: Opher] #225715
12/20/10 11:33 AM
12/20/10 11:33 AM
That, and a lot of us used to shim the shackle that went into the hounds to avoid all the movement (which exaserbated the elongation/cracking). I used plastic shims since they were disposable. I basically cut up a plastic kitchen cutting board with a drill and set of bits. I also used SS washers but had trouble finding the right sizes..
I replaced my hounds when I started to see a small crack at the bottom of the fitting. Adding the shims seemed to correct the problem, but I didn't have as many years of sailing on the new hounds before the boat was sold, so I don't know how the modification worked long-term..
0 registered members (), 2,816 guests, and 517 spiders.
Yesterday at 10:10 AM
