need to buy a sea anchor but confused... #222028
10/19/10 10:47 AM
10/19/10 10:47 AM
Y
yaya Offline OP
yaya  Offline OP
Y
i was told to buy a sea anchor... now when i typed in the usual websites i was struck with a huge range of things under the title 'sea anchor'...
ebay for example has 22 results http://sporting-goods.shop.ebay.com...f=1&_fln=1&_trksid=p3286.c0.m282
and twenga has 314!!! http://www.twenga.com/dir-Sports,Nautical-equipment,Sea-Anchor
now i am not only without a sea anchor and in need of one but also very confused... please could someone help me? you may have already guessed that i am new to boating...! help me not look like a fool please??!!
Re: need to buy a sea anchor but confused... [Re: yaya] #222029
10/19/10 10:50 AM
10/19/10 10:50 AM
pgp Offline
pgp  Offline
What kind of boat do you sail? What part of the world are you in?
Pete Pollard
Blade 702
Re: need to buy a sea anchor but confused... [Re: pgp] #222036
10/19/10 11:26 AM
10/19/10 11:26 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
A sea anchor is a parachute type affair that really puts the brakes on a boat. It would be set on a long line and bridle from the bow of a cat or tri. sometimes and un-even bridle is best as the boat will lie diagonally to the waves. The sails would be down if a sea anchor is deployed. The foils would also be raised - keels/skegs on a multi are a bad idea at this point
A drogue is similar to a parachute sea anchor, but is designed to be towed at a speed [Less drag] off of the stern of a cat or tri that is running away from the wind direction. It is supposed to give the boat more stability and directional control.
In the recent Round Britain Race, the multihulls all picked up pairs of car tyres in Lerwick to be used on the howlin' downwind leg that was ahead of them [As drogues].
Re: need to buy a sea anchor but confused... [Re: TEAMVMG] #222230
10/21/10 12:02 AM
10/21/10 12:02 AM
ruthie Offline
ruthie  Offline
I think you just have to be specific which type of sea anchor you are going to buy. . So for you it does not consumed time of choosing. Good luck. cremation urns for pets
Re: need to buy a sea anchor but confused... [Re: ruthie] #222241
10/21/10 03:37 AM
10/21/10 03:37 AM
Y
yaya Offline OP
yaya  Offline OP
Y
wow thank you so much for explaining in such detail, so helpful. at the moment i'm in central america on a long holiday buying and sorting the boat stuff... not as dodgy as it sounds, just seeing what i must buy now and what i can probably get away with buying when i get home, this sounds pretty important though to sail it back...!! thanks guys
Re: need to buy a sea anchor but confused... [Re: ruthie] #222246
10/21/10 04:49 AM
10/21/10 04:49 AM
pgp Offline
pgp  Offline
Gee Ruthie, I hope you get to use one of your urns for yourself. Soon.
Pete Pollard
Blade 702
Re: need to buy a sea anchor but confused... [Re: pgp] #222247
10/21/10 04:51 AM
10/21/10 04:51 AM
Yeah, she urned it! grin
Re: need to buy a sea anchor but confused... [Re: Tony_F18] #234269
07/01/11 12:55 PM
07/01/11 12:55 PM
sailors delight Offline
0 registered members (), 3,034 guests, and 366 spiders.
