Rigging up a Self Tacker #222431
10/24/10 11:06 AM
10/24/10 11:06 AM
V
Ventucky Red Offline OP
V
Boat = Inter 20 w/self tacker
I have never rigged this up before and need some help. Could you post or email me some pics/directions on how you have done it.
Tks
Re: Rigging up a Self Tacker [Re: Ventucky Red] #222433
10/24/10 11:21 AM
10/24/10 11:21 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Give me an hour and I'll go take some pics of how mine is rigged. Stick isn't up but that don't matter.
Re: Rigging up a Self Tacker [Re: ThunderMuffin] #222438
10/24/10 12:13 PM
10/24/10 12:13 PM
Portland, Maine
Portland, Maine
Here you go.
Traveler car view:
At the forestay - the red fleck line is the jib sheet:
Not the most elegant but it gets the job done.
Re: Rigging up a Self Tacker [Re: ThunderMuffin] #222439
10/24/10 12:15 PM
10/24/10 12:15 PM
Portland, Maine
Portland, Maine
One more thing - when you use the forestay bridle as part of the self-tacker system, you have to fasten the bridle itself to the spin pole somehow, or else when you sheet the jib in hard, the bridle will pull back and mess your jib shape up all to hell.
Re: Rigging up a Self Tacker [Re: ThunderMuffin] #222450
10/24/10 06:50 PM
10/24/10 06:50 PM
Graham, NC
WindyHillF20 Offline
Graham, NC
Would it be better to attach the pulleys to the pole or attach the pole to the bridle?
Re: Rigging up a Self Tacker [Re: WindyHillF20] #222460
10/24/10 10:13 PM
10/24/10 10:13 PM
Portland, Maine
Portland, Maine
You could attach the blocks to the pole, but thats putting more holes in an area of the pole thats already under a lot of pre-bend stress.
Also, you'd have to re-run the jib sheet everytime you break the boat down and I'm lazy. Whole system stays rigged on the trailer.
Re: Rigging up a Self Tacker [Re: ThunderMuffin] #222464
10/24/10 11:23 PM
10/24/10 11:23 PM
Scarecrow
Scarecrow
we used to run 2:1 inside the pole.
Re: Rigging up a Self Tacker [Re: ThunderMuffin] #222486
10/25/10 07:07 AM
10/25/10 07:07 AM
Graham, NC
Graham, NC
Mine is set the same but I do see the jib issue. Hadn't considered the bridles adjusting creating the issue. How did you attach the bridle to the pole? I have some eyestraps on the pole at the bridle I use to secure side deflection. I also tension the pole from a rope hoop at the furler. Thanks
Re: Rigging up a Self Tacker [Re: WindyHillF20] #222488
10/25/10 07:25 AM
10/25/10 07:25 AM
Portland, Maine
Portland, Maine
Yeah I have a padeye on the pole that I lash to the bridle wire.
0 registered members (), 305 guests, and 306 spiders.
