Page 3 of 3 1 2 3
Re: You must read all the replies Eric ! [Re: ejpoulsen] #22367
08/24/03 04:28 PM
08/24/03 04:28 PM
Netherlands
Marc Woudenberg Offline
Netherlands
Eric, find attached the sketch as I promised. Took my first trip around today. Quite a diference to my previous N450 and N50.
Marc Woudenberg
T49/F16 Ned302
Re: You must read all the replies Eric ! [Re: ejpoulsen] #22368
08/24/03 04:37 PM
08/24/03 04:37 PM
Netherlands
Netherlands
The attachment was lost, here's again
23677-Spi halyard.jpg (323 downloads)
Marc Woudenberg
T49/F16 Ned302
Spin set up [Re: Marc Woudenberg] #22369
08/25/03 04:40 PM
08/25/03 04:40 PM
Central California
ejpoulsen Offline OP
Central California
Marc,
I'm set up the same way with one exception: My tramp came with a notch at the rear beam where the bar slides in; it is located just off center but in line with the spinlock cleat on the front beam. I incorporated a small block at that , fastened with the line holding the tramp. So the continuous halyard/retrieval line exits the grommet at the rear of the snuffer bag, passes through the block, and then runs forward across the whole tramp to the spin lock. When sailing alone, it's handy having the line all the way back, but the tramp isn't as clean.
With your set up, does the line simply exit the snuffer grommet, pass through the tramp grommet and then back to the cleat with no block? The center grommet on my tramp is really so small that I can't see that working.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Spin set up [Re: ejpoulsen] #22370
08/26/03 09:08 AM
08/26/03 09:08 AM
Cape Town, South Africa
Steve_Kwiksilver Offline
Hi Marc,
Had a look at your diagram, I have my spinn. set up in much the same way, just curious as to the purpose of the ball you show just below the top patch on the spinn. (I can only imagine it adds weight to the halyard & frustrates you in light wind !) Does it help with retrieval ?
Hi Eric, whatever became of the logo ?
Re: Spin set up [Re: Steve_Kwiksilver] #22371
08/26/03 10:59 PM
08/26/03 10:59 PM
taipanfc Offline
taipanfc  Offline
When you are pulling the spinnaker down it tends to clump in a large mass at the patches. By having a ball below the top patch it allows you to minimise the clump and spread it out. Means that the spinnaker is a lot easier to pull down through the chute.
JC
Re: Spin set up [Re: ejpoulsen] #22372
08/29/03 12:40 PM
08/29/03 12:40 PM
Netherlands
Netherlands
Eric, the spi line goes through the grommet in the tramp directly to the Spinlock. However the grommet is fairly wide and has been rounded off to run the line smoothly. Since it's only a 4 mm line, passing and running is no problem whatsoever and I like the clean tramp this way.
Marc Woudenberg
T49/F16 Ned302
Re: Here is the correct link [Re: Wouter] #22373
06/15/06 04:40 PM
06/15/06 04:40 PM
Edmonton, Alberta, Canada
bobcat Offline
bobcat  Offline
Dredging up ghosts past. I found Eric's link to be broken. Eric, do you have your knowledge gained stored anywhere? I hope to be getting a Blade in the next 2 weeks and am starting to do my homework.
Re: Here is the correct link [Re: bobcat] #22374
06/15/06 09:03 PM
06/15/06 09:03 PM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
Hopefully, you'll get the hardcopy assembly guide. It is pretty helpful for simple rigging (tuning, not so much - but rigging, yes). If you get stuck, Tiki's boat is handy and he has a very nice digital camera <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />. He was very helpful with some measurements I needed.
Page 3 of 3 1 2 3
0 registered members (), 13,947 guests, and 1,085 spiders.
Most Online16,046
4 hours ago
