Page 4 of 5 1 2 3 4 5
Re: Construction of Garage Mahal has begun! [Re: Team_Cat_Fever] #217858
08/19/10 03:27 PM
08/19/10 03:27 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
I saw on your site that you're looking for bucks to contract out the insulation. It's very well spent money. Insulation is a crappy job that will leave you with glass itch for a week. The insulation contractors can get the material for way less than you can because they buy in bulk. The price of material and installation was less than if I bought the material on our last house.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Construction of Garage Mahal has begun! [Re: hobie1616] #217860
08/19/10 03:56 PM
08/19/10 03:56 PM
Daytona Beach Florida
O
orphan Offline
orphan  Offline
O
Stray it in. Much better than fiberglass.
Re: Construction of Garage Mahal has begun! [Re: orphan] #217861
08/19/10 04:43 PM
08/19/10 04:43 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
I did all my basement renovation myself. However I did have a contractor hang and tape my drywall.
Suggestion to you if you have a contractor do your drywall. Count all of your outlets, windows, and heat vents in each room. My drywaller went over one outlet and one window. Funny until you are trying to figure out why you have 5 windows outside but only 4 inside?
I did the pink insulation myself. No big deal and saved some on what was bid. I got it on sale at a HD. It always pays to wait around and watch for sales. You would be surprised how much you can save by catching stuff on sale.
Good luck to you and we missed you at Nationals.
Mike Hill
N20 #1005
Re: Construction of Garage Mahal has begun! [Re: orphan] #217889
08/20/10 08:50 AM
08/20/10 08:50 AM
If orphan means spray it in, I agree 100%. Spray foam is the only way to go. Better R value, less worries with moisture, and it makes the structure stronger over all.
Re: Construction of Garage Mahal has begun! [Re: Karl_Brogger] #217904
08/20/10 11:13 AM
08/20/10 11:13 AM
andrewscott
andrewscott
i was very shocked at how cheap the bid was to spray in insulation in my house (attic). $300 for standard $500 for the highest R value
Re: Construction of Garage Mahal has begun! [Re: ] #217906
08/20/10 12:45 PM
08/20/10 12:45 PM
Jake Offline OP
Jake  Offline OP
Really? I had understood that the spray-in stuff was roughly twice that of fiberglass. I don't think it pays to do the insulation myself. My brother most recently had a guy quote supplying and installing insulation that was less expensive than what he could buy it for at a box store. The sprayed stuff has about twice the R value but I'm still a little concerned about the long term affect of a water problem should one ever come up.
Re: Construction of Garage Mahal has begun! [Re: Jake] #217911
08/20/10 02:32 PM
08/20/10 02:32 PM
hobie1616 Offline
hobie1616  Offline
It probably doesn't matter what you use. A house up the hill had an o-ring go bad in a water filtration system. Slow leak which eventually covered the wood plank floor, soaked through the sheetrock and was wicked up to the ceiling by the glass insulation. What a mess.
Re: Construction of Garage Mahal has begun! [Re: Jake] #217913
08/20/10 04:35 PM
08/20/10 04:35 PM
andrewscott
andrewscott
pretty certain. 1000sq' was around 3-500 .
http://www.danielinsulation.com/products/batt-blow
i think that was the product i was quoted for. i never ended up doing it. i found out it already had updated insulation
Re: Construction of Garage Mahal has begun! [Re: Jake] #217915
08/20/10 05:17 PM
08/20/10 05:17 PM
Water should not be an issue with a closed cell foam over any other of the choices. I know up here you do not have to run a vapor barrier with the closed cell.
It does cost more, but there is a savings to be had in the long term with lower heating/cooling costs. Granted our extremes are a bit different than yours. Temps here can sway 140*F with the seasons, so I'm not sure if it is as critical.
Personally if I were to build a house today, (I know a garage is a slightly different story...), I wouldn't consider anything else.
[edit]- The noise suppression from the spray in is also very impressive.
Re: Construction of Garage Mahal has begun! [Re: Karl_Brogger] #217994
08/22/10 06:43 PM
08/22/10 06:43 PM
Jake Offline OP
Jake  Offline OP
Most spray in foams are open cell - real closed cell is like 4x the price of open cell foam...or so I thought.
Re: Construction of Garage Mahal has begun! [Re: Jake] #217997
08/22/10 08:21 PM
08/22/10 08:21 PM
Yep, its significantly more. I don't know if its cost effective for you, but up here it has just about become the standard for both walls and ceilings.
Re: Construction of Garage Mahal has begun! [Re: Karl_Brogger] #223958
11/12/10 09:43 AM
11/12/10 09:43 AM
Jake Offline OP
Jake  Offline OP
The Mahal is still under construction. I haven't done crap to the inside yet other than push a boat in there and do a little work on my truck. I have been using the space to building fencing and fabricate a couple of (overly) complex gates. Also been pushing dirt around. It's getting there. I'm still blown away at the amount of space and can't wait to get it finished to get started on something fun! That's my extended cab Silverado at 19+ feet long in there with the garage door closed.
To Nigel and Dave who gave me the sage advice: "people complain about it being too small or being too expensive - but nobody complains about it being too big"....thank you!
Re: Construction of Garage Mahal has begun! [Re: Jake] #223968
11/12/10 11:24 AM
11/12/10 11:24 AM
O
orphan Offline
orphan  Offline
O
Rule 1: build it bigger than you think you need.
Rule 2: no mater how big you will fill it with stuff and wish you had made it bigger.
Re: Construction of Garage Mahal has begun! [Re: orphan] #226030
12/29/10 12:10 PM
12/29/10 12:10 PM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
How true I'm running out of room in The Man Shed 48' x 30' at first I thought man look at all this space ---- and now I have to move things around.
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
Re: Construction of Garage Mahal has begun! [Re: TheManShed] #226039
12/29/10 05:51 PM
12/29/10 05:51 PM
lesburn1 Offline
lesburn1  Offline
I have a friend with a "shed" that is 40' X 80" and it is so full with sh** that you can barely move around. Between two Cessna 185s, Piper Cub and a John Deere and 50 years of crap...
lesburn1.blogspot.com
A-Cat USA 49
18Sq 49
Re: Construction of Garage Mahal has begun! [Re: lesburn1] #236919
08/29/11 09:40 PM
08/29/11 09:40 PM
Jake Offline OP
Jake  Offline OP
The garage is slowly coming around...I'm finally ready for electrical and plumbing rough-in inspections.
BUT! projets like this keep getting in the way. We're getting our F18 infusion ready for the fall regatta season and sprucing her up.
www.teamseacats.com
Re: Construction of Garage Mahal has begun! [Re: Jake] #236946
08/30/11 09:54 AM
08/30/11 09:54 AM
that's quite a crack, and lots of good detail for us amature repair folk. It bears repeating that the elbow grease is what makes it work....
Re: Construction of Garage Mahal has begun! [Re: Jake] #236980
08/30/11 07:53 PM
08/30/11 07:53 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
AMEN!
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Construction of Garage Mahal has begun! [Re: TheManShed] #236985
08/30/11 10:10 PM
08/30/11 10:10 PM
Jake Offline OP
Jake  Offline OP
Originally Posted by TheManShed
My shop is open on the ends. I have mixed feelings about doors in a large shop in South Florida ventilation is important. It would cost an arm and a leg to cool a building like mine, then you would have to deal with the dust and chemicals so you don't blow yourself up.
Mike,
I sifted back through this thread and saw your comment. I have to say, that is one of the most sage pieces of advice I have heard. I have a 16' door in one gable end and a 12' door in the opposing gable end of my garage. I did that so, in the odd chance I needed to, I would have options to pull something large in and drive out the other side. What I've discovered, however, is that having the two doors is incredible for airflow and comfort when doing the things we do with fiberglass, grinding, welding, and other stuff. Fresh air comes easy when you have a door on either end. It really is quite nice.
Re: Construction of Garage Mahal has begun! [Re: Jake] #237001
08/31/11 09:07 AM
08/31/11 09:07 AM
If you epoxy the floors yourself, get the solvent based kits, plan on doing two coats, and put a clear coat over the top. I did my garage at my old house and the only thing I would've done differently is I should've sand blasted the floor to give it some texture for the paint to adhere to.
1 registered members (Damon Linkous), 2,526 guests, and 167 spiders.
