nacra 5.8 singlhanded? #224449
11/19/10 08:56 PM
11/19/10 08:56 PM
Bay Area, California, US
Nacra5.8NA1386 Offline OP
How hard would it be to singlehand a 5.8? Seems like if you furled/didn't use the jib it wouldn't be too hard... what do you think?
Nacra 5.8NA "Royal Flush"
Re: nacra 5.8 singlhanded? [Re: Nacra5.8NA1386] #224451
11/19/10 10:31 PM
11/19/10 10:31 PM
Arizona
AzCat Offline
AzCat  Offline
Arizona
It all depends on conditions. Winds over say 12mph, maybe not. can you right the boat yourself? are there others around to give you a hand if you go over?
I single my N6.0 frequently and fly the spin. But not if I'm alone on the lake and not if the wind is up or could be expected to come up. I also have a water bag on board.
Be safe and go for it.
Auscat MKV 444 A class
NACRA I-20- 440/CATHATKA
Re: nacra 5.8 singlhanded? [Re: AzCat] #224452
11/19/10 10:56 PM
11/19/10 10:56 PM
Cool. What is your max wind range for singlehanding your 6.0?
Re: nacra 5.8 singlhanded? [Re: Nacra5.8NA1386] #224459
11/20/10 06:18 AM
11/20/10 06:18 AM
japan
erice Offline
erice  Offline
japan
a lot also depends on where you sail
on a smallish lake, give it a ago, the most you're likely to lose if you can't right it is the boat
on the ocean you could lose a lot more...
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: nacra 5.8 singlhanded? [Re: erice] #224460
11/20/10 07:01 AM
11/20/10 07:01 AM
You do realize a little girl named Ellen MacArthur single handed a 75' triamaran around the world.
http://www.amazon.co.uk/Race-Against-Time-Ellen-MacArthur/dp/0141026480/ref=pd_sim_b_1
Sailing a beach cat solo is not hard, but like everything else, you have to pick your days, prepare, and practice. Start out in light wind and work your way up once you get your coryography figured out.
Re: nacra 5.8 singlhanded? [Re: erice] #224467
11/20/10 12:15 PM
11/20/10 12:15 PM
True... I'm on a skinny bay with lots of other friendly sailors, so I'll give it a try on a light day, then slowly work up to medium-ish winds. Thanks
Re: nacra 5.8 singlhanded? [Re: Nacra5.8NA1386] #224471
11/20/10 07:32 PM
11/20/10 07:32 PM
Your only issue might be righting it if you flip it, but I've flagged down many a jet skier who was happy to lift the mast tip up for me, so be kind to them even if they insist on trying to follow you around all day...
Re: nacra 5.8 singlhanded? [Re: Timbo] #224472
11/20/10 07:36 PM
11/20/10 07:36 PM
Originally Posted by Timbo
coryography
wow
grin
Re: nacra 5.8 singlhanded? [Re: PTP] #224474
11/20/10 09:12 PM
11/20/10 09:12 PM
Does anyone have pics from their 5.8 spi setup? i have a spinnaker, and some windsurf masts for poles.
Re: nacra 5.8 singlhanded? [Re: PTP] #224489
11/21/10 09:21 AM
11/21/10 09:21 AM
coryography
wow
grin
Yeah, I know, my spelling's bad...but my typing is worse!
That's why I took up flying. You only need to spell (and say) 4 letter words up there. Most conversations start with, "What the F@#K is it doing now?!"
Re: nacra 5.8 singlhanded? [Re: Nacra5.8NA1386] #224538
11/22/10 03:34 PM
11/22/10 03:34 PM
Reno NV
Rhino1302 Offline
Rhino1302  Offline
Reno NV
I can't find any close-up photos of my set-up, but I pretty much copied the controls from the Capricorn manual.
The pole is just a stick of aluminum that I got from a local metal supply shop - saved a lot on shipping that way (it's 12.5 feet long). It is lashed to the underside of the NA foil, the foil is raised a couple of inches from stock to get the geometry right - because it's raised I have two lines from the center of the the foil to each tang to keep it from shifting side-to-side. The butt end of the pole is attached to the top of the dolphin striker (right under the main beam). Rather than attaching tangs to the bow, I just drilled holes in the bow.
The 5.8 is very forgiving, and carries a spin very well. I've never come close to pitch-poling in 3 years of racing the boat pretty hard. It's very fast off the wind - never had any problems putting time on Tigers downwind. My spin is a modern F18-style cut (custom made for the boat by Glaser). The older style kites are much larger, and if you have one, your mileage may vary.
Re: nacra 5.8 singlhanded? [Re: Rhino1302] #224542
11/22/10 05:33 PM
11/22/10 05:33 PM
awesome. thanks.
0 registered members (), 4,152 guests, and 389 spiders.
