| nacra 5.8 singlhanded? #224449 11/19/10 08:56 PM 11/19/10 08:56 PM |
Joined: Aug 2010 Posts: 50 Bay Area, California, US Nacra5.8NA1386 OP
Posts: 50 Bay Area, California, US | How hard would it be to singlehand a 5.8? Seems like if you furled/didn't use the jib it wouldn't be too hard... what do you think?
Nacra 5.8NA "Royal Flush" | | | Re: nacra 5.8 singlhanded?
[Re: Nacra5.8NA1386]
#224451 11/19/10 10:31 PM 11/19/10 10:31 PM |
Posts: 337 Arizona | It all depends on conditions. Winds over say 12mph, maybe not. can you right the boat yourself? are there others around to give you a hand if you go over? I single my N6.0 frequently and fly the spin. But not if I'm alone on the lake and not if the wind is up or could be expected to come up. I also have a water bag on board. Be safe and go for it.
Auscat MKV 444 A class NACRA I-20- 440/CATHATKA | | | Re: nacra 5.8 singlhanded?
#224459 11/20/10 06:18 AM 11/20/10 06:18 AM |
Posts: 757 japan | a lot also depends on where you sail
on a smallish lake, give it a ago, the most you're likely to lose if you can't right it is the boat
on the ocean you could lose a lot more...
[Re: erice]
#224467 11/20/10 12:15 PM 11/20/10 12:15 PM |
Posts: 50 Bay Area, California, US | a lot also depends on where you sail
on the ocean you could lose a lot more... True... I'm on a skinny bay with lots of other friendly sailors, so I'll give it a try on a light day, then slowly work up to medium-ish winds. Thanks
#224471 11/20/10 07:32 PM 11/20/10 07:32 PM |
Posts: 6,049 Sebring, Florida. | Your only issue might be righting it if you flip it, but I've flagged down many a jet skier who was happy to lift the mast tip up for me, so be kind to them even if they insist on trying to follow you around all day...
Blade F16 #777
[Re: PTP]
#224489 11/21/10 09:21 AM 11/21/10 09:21 AM |
Posts: 6,049 Sebring, Florida. | wow Yeah, I know, my spelling's bad...but my typing is worse! That's why I took up flying. You only need to spell (and say) 4 letter words up there. Most conversations start with, "What the F@#K is it doing now?!"
Blade F16 #777
#224538 11/22/10 03:34 PM 11/22/10 03:34 PM |
Posts: 308 Reno NV | Does anyone have pics from their 5.8 spi setup? i have a spinnaker, and some windsurf masts for poles. ![[Linked Image]](http://surfcityracing.smugmug.com/Boats/Delta-Ditch-2010/IMG7782/899800752_8TGgS-L-1.jpg) I can't find any close-up photos of my set-up, but I pretty much copied the controls from the Capricorn manual. The pole is just a stick of aluminum that I got from a local metal supply shop - saved a lot on shipping that way (it's 12.5 feet long). It is lashed to the underside of the NA foil, the foil is raised a couple of inches from stock to get the geometry right - because it's raised I have two lines from the center of the the foil to each tang to keep it from shifting side-to-side. The butt end of the pole is attached to the top of the dolphin striker (right under the main beam). Rather than attaching tangs to the bow, I just drilled holes in the bow. The 5.8 is very forgiving, and carries a spin very well. I've never come close to pitch-poling in 3 years of racing the boat pretty hard. It's very fast off the wind - never had any problems putting time on Tigers downwind. My spin is a modern F18-style cut (custom made for the boat by Glaser). The older style kites are much larger, and if you have one, your mileage may vary. | | |
666
guests, and 49
