| Re: Steeplechase Tracking
[Re: PTP]
#225253 12/11/10 12:47 PM 12/11/10 12:47 PM |
Posts: 3,224 Roanoke Island ,N.C. | what rating is the f20 using? Same as the M20, I believe.
[Re: Team_Cat_Fever]
#225254 12/11/10 12:53 PM 12/11/10 12:53 PM |
Posts: 833 St. Louis, MO, | Light wind on the nose would definitely favor the M20. They really excel in that condition.
The F20 I would think would excel in Medium winds downwind sailing. Medium being 12-18 knts.
So this might be a rough race for the F20 unless the wind does come up on the outside and the foils can come to life.
Mike Hill N20 #1005
[Re: cyberspeed]
#225255 12/11/10 12:55 PM 12/11/10 12:55 PM |
Posts: 3,224 Roanoke Island ,N.C. | The wind was straight on the nose going up to the angelfish. Started to fill in when I left the bridge. Should make better progress on the outside.
Roberts is running, somehow the spot got turned off. Probably when I installed it. I tried to check them all before they left but Roberts was on the water before I could double check it. Craig, Can you put up a full entry list, and show which teams have spots and who they are. Good job ,so far. This is the first time I've watched . Not as good as being there , but way better than waiting a week for results.
[Re: Mike Hill]
#225256 12/11/10 12:58 PM 12/11/10 12:58 PM |
Posts: 833 St. Louis, MO, | Can someone put peoples names to the boat names on the tracking page. Only one I know is
Dingo Racing = Dave Ingram and crew?
Mike Hill N20 #1005
[Re: Mike Hill]
#225257 12/11/10 12:59 PM 12/11/10 12:59 PM |
Posts: 833 St. Louis, MO, | Popping out of Angelfish before noon usually makes for a pretty good day. Now the chutes are up and they will be making pretty good time.
Wish I was there.
Mike Hill N20 #1005
[Re: Mike Hill]
#225258 12/11/10 01:00 PM 12/11/10 01:00 PM |
Posts: 2,921 Michigan | Team Redhead is Mark Smith and Joe Pocreva
looks like they are doing well, at least in terms of teams with Spots
[Re: Mike Hill]
#225259 12/11/10 01:02 PM 12/11/10 01:02 PM |
Posts: 3,224 Roanoke Island ,N.C. | CC carbon cruising is Bret Moss and John Casey RM is Mike Krantz and David Lennard TR is Mark Smith and Joe Pocreva
[Re: PTP]
#225261 12/11/10 01:03 PM 12/11/10 01:03 PM |
Posts: 3,224 Roanoke Island ,N.C. | About 1/2 way between where the last 2 Rt. 1 markers are on the map, right before the turn under the Channel 5 bridge. Check off "show split points" in the menu ,it says Steeple half. Craig has done a nice job on this.
[Re: PTP]
#225262 12/11/10 01:35 PM 12/11/10 01:35 PM |
Posts: 5,525 |
Pete Pollard Blade 702
[Re: Mike Hill]
#225266 12/11/10 02:01 PM 12/11/10 02:01 PM |
Posts: 833 St. Louis, MO, | Looking like a dead downwind run on the outside. That would make for a long day. Hope the wind turns a little for them.
Mike Hill N20 #1005
[Re: arbo06]
#225269 12/11/10 02:26 PM 12/11/10 02:26 PM |
Posts: 3,224 Roanoke Island ,N.C. | Nothing. Make sure you have them checked off in the menu box.
669
guests, and 136
