| Re: A Very Well Deserved Recomendation!
[Re: TeamChums]
#225610 12/17/10 06:56 PM 12/17/10 06:56 PM |
Posts: 4,119 Northfield Mn | I meant that in the most respectful way possible. hell. That ain't bad. I had a boat named A2M. Stood for "butt To Mouth". and you never go butt to mouth.
[Re: TeamChums]
#225616 12/17/10 09:52 PM 12/17/10 09:52 PM |
Posts: 3,293 Long Beach, California | So much for circling the drain...
[Re: Dan_Delave]
#225630 12/18/10 12:08 PM 12/18/10 12:08 PM |
Posts: 1,884 Detroit, MI | Karl:
You sound like you are looking for trouble... All Karl has to do to find trouble is look in the mirror. | | | Re: A Very Well Deserved Recomendation!
[Re: mbounds]
#225648 12/18/10 09:48 PM 12/18/10 09:48 PM |
Posts: 4,119 Northfield Mn | Karl:
You sound like you are looking for trouble... All Karl has to do to find trouble is look in the mirror. Ten years ago I was trouble. Now days, I'm pretty boring. The constantly drunk, fighting, adrenaline junky is no more. I've been diminished to just the occasional pain in the butt.
[Re: HMurphey]
#225661 12/19/10 02:09 PM 12/19/10 02:09 PM |
Posts: 1,403 | Hi V Red,
I'm thinking of redoing my ol' P19MX new spring, as I put a crease in the starboard bow when moving the boats around last year in the backyard ( my H18Mag won the argument w/ my P19MX ) ... and as you know I live on the east coast, so I do not think it is possible to have Jesus do the repair work. I usually work w/ WEST Epoxy making "filler" as needed. But I am curious as to what products did Jesus use ... and were the hulls painted or re-gellcoated ???
Thanks Harry Harry: To do the filling they used a product called Dyna Glass. A lot cheaper than West Systems and is already set up with the filler in this case fiberglass. Few other guys I talked with told me this is what the use for fairing hulls As for the final finish it was gel coated with a helleva damm good match. There are a couple of spots where if you look real close you can see the transition form the old to the new, but you really need to look. I really wish I had taken a few more before pic of the boat. ![[Linked Image]](http://www.handsontools.com/assets/images/443122_443120.jpg) Here you go these may help http://www.youtube.com/watch?v=iWEE6SFUdpg&feature=relatedhttp://www.youtube.com/watch?v=en-8SbhdF_kP.S. Jesus is getting a pound of scrapple for Christmas!!!!!
[Re: PTP]
#225697 12/20/10 09:51 AM 12/20/10 09:51 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Dyna Glass has glass strands mixed in it. Bondo doesn"t. For repairs that are deeper(thicker) using something like Dyna Glass will help ensure that it will be less likely to crack. For things like scratches using a glazing putty like Evercoat is better. It's all about the type of filler used to make the putty. Some are stronger, some are easier to sand. I like to use gel coat and add my own mix of fillers depending on what needs to be done.
[Re: catman]
#225699 12/20/10 10:07 AM 12/20/10 10:07 AM |
Posts: 1,403 | Dyna Glass has glass strands mixed in it. Bondo doesn't. For repairs that are deeper(thicker) using something like Dyna Glass will help ensure that it will be less likely to crack. For things like scratches using a glazing putty like Evercoat is better. It's all about the type of filler used to make the putty. Some are stronger, some are easier to sand. I like to use gel coat and add my own mix of fillers depending on what needs to be done. That is my preferred method as well, that is mix up some gel coat with colloidal silica West Systems #406(wear a mask when using this stuff, it will shred your lungs)to the point to where it has the viscosity between mayonnaise and peanut butter. My Prindle's and 5.8 have plenty of these little patches on them and they held up very well.
[Re: Ventucky Red]
#225702 12/20/10 10:29 AM 12/20/10 10:29 AM |
Posts: 5,525 | http://www.westsystem.com/ss/product-selection-chart/I believe all the bondo type products are polyester resin. At least they used to be. Polyester can be thickened with cab-o-sil which I think is collodial silica. The traditional problem with bondo is that it started out using talc as a thickener which led to water absorbancy problems. Newer products, particularly those described as lite, may not be so prone to absorbancy. I've been using a lite body filler on my Blade for some time and have had no problems.
Pete Pollard Blade 702
[Re: pgp]
#225847 12/23/10 02:36 PM 12/23/10 02:36 PM |
Posts: 1,253 Columbia South Carolina, USA | What do you do about gelcoat crazing? Im restoring a 1963 Boston Whaler, and have begun to Dremel out the Gelcoat cracks with the thought of using a filler afterwards. Is there a better way?
[Re: dave mosley]
#225849 12/23/10 03:12 PM 12/23/10 03:12 PM |
Posts: 12,310 South Carolina | What do you do about gelcoat crazing? Im restoring a 1963 Boston Whaler, and have begun to Dremel out the Gelcoat cracks with the thought of using a filler afterwards. Is there a better way? I sure hope you're talking about a Supercat catamaran that was built after Bosten Whaler bought the outfit for a short time. This 'aint no stinkpot forum.
Jake Kohl | | | Re: A Very Well Deserved Recomendation!
[Re: dave mosley]
#225852 12/23/10 03:54 PM 12/23/10 03:54 PM |
Posts: 291 | Such harsh words from Jake. So lets assume it is the cat version, or even if it is not the answer is the same. Crazing is cause by the gel coat being too thick due gel coat not having any flexabilty while the glass has some. Dremeling and filling will probably result in more of the same. I would recommend taking the gelcoat off completely, or at the very least almost completely. An air file with some 60 grit will do with some effort. In the right hands a belt sander on low speed with some 120 will make quick work of it, but if you are not carefull it will make things very bad in .21 seconds. If you use the belt sander plan to fair the surface out using 3M piranah putty or similar product. You can that paint or regelcoat (my suggestion) after that.
[Re: JACKFLASH]
#225854 12/23/10 04:44 PM 12/23/10 04:44 PM |
Posts: 12,310 South Carolina | Such harsh words from Jake. David and I go back quite some time and I was ribbing him because it sounds like he bought a motor boat instead of getting back into catamaran sailing like he's been talking about for the better part of two years! It was in good jest.
[Re: dave mosley]
#225855 12/23/10 04:58 PM 12/23/10 04:58 PM |
Posts: 5,525 | Do you have a picture? I think crazing involves a fine spider web of cracks over a large area.
333
guests, and 44
