| N6.0 mast mod vs rating #225889 12/25/10 05:22 PM 12/25/10 05:22 PM |
Posts: 337 Arizona | I changed the mast on my N6.0 orig to an NA mast(ie-double diamond wires). I raced this fall in a local regatta and they insisted on rating me as a 6.0 NA. I do not carry the sail area of the NA(self tacking jib and 3% increase of main sail when changed to sq top). Does the addition of the extra diamond wire make my 6.o orig an NA? Personally, I wouldnt think it would. Along this same line, I havnt been able to find a max sq ft for the main sail of an NA. I dont sail one design obviously. Always Portsmouth. If they insist on rating me as an NA, Couldnt I have a low wind monster main made to include the SF lost in the jib and Orig Main? Im getting killed in the lites.
Auscat MKV 444 A class NACRA I-20- 440/CATHATKA | | | Re: N6.0 mast mod vs rating
[Re: Ventucky Red]
#225900 12/26/10 12:28 PM 12/26/10 12:28 PM |
Posts: 337 Arizona | Yes, I do have the bridal foil, sq top main. But when I had the new main made, I stayed with the size of the orig main that it came with. Maybe I need to have a main made that fits within the measurement parameters of the 6.0 NA for low wind days. I dont think its worth changing the jib over, lotta work. Do you or does anyone else out there know the sf of the NA main? Thanks for the input VR. Merry Christmas.
[Re: AzCat]
#225901 12/26/10 12:59 PM 12/26/10 12:59 PM |
Posts: 1,304 Gulf Coast relocated from Cali... | Contact Skip Elliot at E/P sails, he did all the designs for the 6.0. As for the mast, it is a modified rig regardless of change in sail size. Since you have a mast that can take it, get a new main made. E/P makes a bad a$$ sq top for the 6.0 NA.
Lee
[Re: TeamChums]
#225907 12/26/10 11:03 PM 12/26/10 11:03 PM |
Posts: 337 Arizona | There is SE a sq top on beachcats but I don't know if its maxed out or not. Seems to have a pretty small sq top also. Maybe Ill contact SE and see if I can get some info on it from them.
[Re: AzCat]
#225909 12/26/10 11:57 PM 12/26/10 11:57 PM |
Posts: 1,304 Gulf Coast relocated from Cali... | I looked at that main. It's not a NA. Something fishy about it and I'd bet it was made for a boat that simply had a 6.0 mast. For that price, I'd go to Skip or Chip Buck at Whirlwind. If you go to Chip, be specific on the amount of curve you want in the luff (around 1.5 inches) and let him do one for you.
Lee
[Re: TeamChums]
#225924 12/27/10 11:24 AM 12/27/10 11:24 AM |
Posts: 337 Arizona | Yea, I had chip @ Whirlwind do my current main, he does a beautiful job, and his pricing can't be beat. I think that I could go a lot bigger though. I sent Skip an email re the one on beachcats, Ill see what he says about it. Im going to try to get Matt on the 6.0 sometime in January,. Its been a while since he's been on the water. Im going to have him skipper so I can learn a bit more about the spin. I also got him hooked up to race the Birthday regatta and Leukemia Cup at Pleasant on an R-33.
[Re: AzCat]
#225967 12/28/10 11:16 AM 12/28/10 11:16 AM |
Posts: 1,403 | Yes, I do have the bridal foil, sq top main. But when I had the new main made, I stayed with the size of the orig main that it came with. Maybe I need to have a main made that fits within the measurement parameters of the 6.0 NA for low wind days. I dont think its worth changing the jib over, lotta work. Do you or does anyone else out there know the sf of the NA main? Thanks for the input VR. Merry Christmas. I may be wrong, but I don't think the boat came from the factory with a square top main even with the NA configuration. The North American configuration was the addition of the foil to accommodate the large jib sail for off the wind sailing. IMPO if you don't want to be "dinged" for being an NA then take the foil off. | | | Re: N6.0 mast mod vs rating
[Re: Ventucky Red]
#225971 12/28/10 12:33 PM 12/28/10 12:33 PM |
Posts: 12,310 South Carolina | Yes, I do have the bridal foil, sq top main. But when I had the new main made, I stayed with the size of the orig main that it came with. Maybe I need to have a main made that fits within the measurement parameters of the 6.0 NA for low wind days. I dont think its worth changing the jib over, lotta work. Do you or does anyone else out there know the sf of the NA main? Thanks for the input VR. Merry Christmas. I may be wrong, but I don't think the boat came from the factory with a square top main even with the NA configuration. The North American configuration was the addition of the foil to accommodate the large jib sail for off the wind sailing. IMPO if you don't want to be "dinged" for being an NA then take the foil off. The Factory specified Nacra 6.0 and 6.0NA sails were pin-head sails. Any square top sails were custom built.
Jake Kohl | | | Re: N6.0 mast mod vs rating
[Re: TeamChums]
#225994 12/28/10 04:52 PM 12/28/10 04:52 PM |
Posts: 3,224 Roanoke Island ,N.C. | All the 6.0's came with a foil too. The early ones were round. Nope ,the original had a pigtailed forestay like the N-20, the NA had the foil.
[Re: Team_Cat_Fever]
#225999 12/28/10 07:12 PM 12/28/10 07:12 PM |
Posts: 1,304 Gulf Coast relocated from Cali... | I didn't know that. Roy Seaman told me otherwise when I was looking at one of the first ones which was a lengthened 5.8. It was also 9'3" wide. Kind of strange. I've seen three "originals" with the round bar spreader/foil on the west coast.
Lee
[Re: TeamChums]
#226001 12/28/10 08:24 PM 12/28/10 08:24 PM |
Posts: 3,224 Roanoke Island ,N.C. | They probably added the round bar after the NA was released to be able to get the larger jib plan.Like all the mess added to the n-20 in different forms.
#226038 12/29/10 05:39 PM 12/29/10 05:39 PM |
Posts: 1,403 | They probably added the round bar after the NA was released to be able to get the larger jib plan.Like all the mess added to the n-20 in different forms. Nah! This was another one of Roy's Toys! This was a true Franken Boat made form parts that were lying around Roy's yard. Was an awesome boat though. | | | Re: N6.0 mast mod vs rating
#226046 12/29/10 08:23 PM 12/29/10 08:23 PM |
Posts: 337 Arizona | I guess I better suck it up and run as an NA then. It wont be long till i get the itch to upgrade to an f-18 or a N20. Till then I'll have to learn to sail it faster. I guess that aint a bad thing.
441
guests, and 41
