| Re: Tornado classic rig
[Re: Carl_Andreasson]
#22606 07/28/03 04:02 AM 07/28/03 04:02 AM |
Posts: 4,451 West coast of Norway | Hi,
the Tornado is an all out racing boat, where you can design your own deck layout to fit your needs (within the class rules). Convenient for racers and experienced sailors, but a bit of a problem for people new to the class.
Anyway, inside the boom it usually is a outhaul system for the main. I would guess your boom has a pulley system and a bungee to put the outhaul in the 'minimum outhaul' position. A mast rotation control system can also be buildt into the boom, with or without pulleys..
Lines coming trough the mastfoot can be anything, from downhaul, jib downhaul to positive mast rotation. Hard to say without seeing the boat and the setup.
Mainsail halyard are usually put in the mast groove, in front of the main. The main hooks on to a hook in the top of the mast. Put the rest of the halyard in the bag you have on your trampoline. If you have a sealed mast, the halyard is usually but inside the zipper on the jib and the jib 'hooked' in a cleat attached to the forstay. If the jib halyard goes trough the mast and down the mainsail luff groove there is some arrangment for securing it on the bottom of the mast.
There is lots of guessing here, but as there are many different ways to rig a Tornado some pictures are neccesary to help you any further.
#22608 07/28/03 11:55 PM 07/28/03 11:55 PM |
Joined: Nov 2001 Posts: 116 Edmonton, Alberta, Canada Al Schuster
Posts: 116 Edmonton, Alberta, Canada | Hi, on my reg white, the jib halyard runs down the inside of the mast and out a hole in the side about even with the gooseneck. There is a pulley system inside the mast that attaches to the bottom of the halyard (where rope meets wire) with a hook. The tensioning of the halyard can then occur from either side of the mast via the rope running along the front beam. The rope has bungie within the beam to maintain tension. To rephrase; the line comes out of the beam, runs through the cleat into the mast, up & down twice, out of mast through cleat and into the other side of the beam. You have to remove the bottom of the mast to rig the pulley system. The line in the boom must be the outhall. I haven't taken mine apart to discover the inner workings, but if you pull back on the outhall fitting, it hopefully will snap back into place. The main should hook at the top of the mast as previously described. Hope this helps Al | | | Re: Tornado classic rig
#22609 07/29/03 08:24 AM 07/29/03 08:24 AM |
Posts: 395 LA | If you classic T-cat sailors are in need of some good sails for those rigs, contact me at [email] [email protected].[/email] | | |
857
guests, and 34
