Round Isle of Wight (UK) #22623
07/28/03 08:13 AM
07/28/03 08:13 AM
Gower, Wales, UK
sailwave Offline OP
sailwave  Offline OP
Gower, Wales, UK
Round Isle of Wight (UK) results at link below.
http://www.fastcatrace.com
Re: Round Isle of Wight (UK) [Re: sailwave] #22624
07/28/03 08:29 AM
07/28/03 08:29 AM
St Croix Virgin Islands
vicatman Offline
vicatman  Offline
the SCR I assume thats the rating number....if so how is it the Fox is rated the same as a Tornado and one point under an I-20
Re: Round Isle of Wight (UK) [Re: vicatman] #22625
07/28/03 08:48 AM
07/28/03 08:48 AM
Gower, Wales, UK
sailwave Offline OP
sailwave  Offline OP
Gower, Wales, UK
Hi,
I don't know; I thought the Fox was an iF20... It could be a self-declaration error because the ISAF SCHRS system which was used at the event recently changed iF20 from .94 to .95 (by removing a carbon penalty). See http://www.schrs.com...
There again, the table lists values based on specific measurements and 'formula' values based on what is presumably min/max parameters (as appropriate) of the formula rule. So a boat which is an iF20 may or may not have the same rating as 'the' iF20 value... I think Texel lists actual/formula values as well...
Colin
www.sailwave.com
Re: Round Isle of Wight (UK) [Re: sailwave] #22626
07/28/03 09:51 AM
07/28/03 09:51 AM
MI
sail6000 Offline
sail6000  Offline
MI
Thanks Colin
Good pic of Will and Mark sailing the T in the Solent ,-this team had their daggerboards rip through the Jav 2 hull after hitting a ray in the Tybee 500 , and also a past W-1000 team -http://www.fastcatrace.com/---
Is there a good pic of your new F-18 in there Colin ,-
thanks -
Re: Round Isle of Wight (UK) [Re: sail6000] #22627
07/28/03 10:02 AM
07/28/03 10:02 AM
Gower, Wales, UK
sailwave Offline OP
sailwave  Offline OP
Gower, Wales, UK
Hi Carl,
Nope, I was buzzing around Swansea Bay getting used to it; lotsa fun, but knackered today... :-) Incredibly light steering after sailing a skeg boat like the Dart 18...
Colin
www.sailwave.com
