Prindle 19 #226497
01/09/11 03:19 PM
01/09/11 03:19 PM
Stephan Bitterwolf Offline OP
So today begins the dismantling of my Prindle 19. I want to cut an inspection port in each of the bow pontoons. I have no idea what a prindle 19 looks like on the inside. However the catamaran is in need of some TLC. Does anyone know anything about this type of procedure? I'd greatly appreciate any input/ideas!
Thanks!
Re: Prindle 19 [Re: Stephan Bitterwolf] #226560
01/10/11 03:46 PM
01/10/11 03:46 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
You said the P - word!
Re: Prindle 19 [Re: Stephan Bitterwolf] #226564
01/10/11 05:32 PM
01/10/11 05:32 PM
JACKFLASH Offline
JACKFLASH  Offline
I will give you one major tip. Don't put an inspection port in any catamaran in front of the front cross beams. The loads up there will certainly cause a hull failure.
Collin Casey
Re: Prindle 19 [Re: Stephan Bitterwolf] #226565
01/10/11 06:05 PM
01/10/11 06:05 PM
Dallas, TX
L
lonestarcat Offline
lonestarcat  Offline
L
Dallas, TX
Somebody suggested looking inside with a web cam, something I hadn't thought of, and found quite useful. You can attach one to something flexible and see quite a bit from the rear inspection ports. Don't know if that would help, since you didn't say what problem you were trying to solve...
Prindle 19MX
Re: Prindle 19 [Re: lonestarcat] #226605
01/11/11 10:11 AM
01/11/11 10:11 AM
Daytona Beach Florida
O
orphan Offline
orphan  Offline
O
Re: Prindle 19 [Re: orphan] #226764
01/13/11 09:05 PM
01/13/11 09:05 PM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
Here is how I do it.
http://themanshed.net/archived-projects/g-cat-catamaran/?g2_page=2
Except I use Epoxy now instead of Poly resins. There are a lot of posts against messing with the bows on Prindles. But I look at this way you can fix it before it breaks or afterwards.
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
0 registered members (), 439 guests, and 53 spiders.
