Adding spreaders / diamonds #22659
07/28/03 01:03 PM
07/28/03 01:03 PM
MauganN20 Offline OP
Any of you guys out there with spreaders.. could you tell me if the bracket that rivets onto the mast that supports the actual spreaders is readily available in any ole Sailing shop.. or do I have to place an order with Hobie? Couldn't find anything in Murray's or Catsailor.com.
Thanks.
Re: Adding spreaders / diamonds [Re: MauganN20] #22660
07/28/03 01:10 PM
07/28/03 01:10 PM
try aps at http://www.apsltd.com
or layline at http://www.layline.com
I've seen 'em before.
Re: Adding spreaders / diamonds [Re: MauganN20] #22661
07/28/03 06:43 PM
07/28/03 06:43 PM
jcasto1 Offline
jcasto1  Offline
In hardware catalogs, they will be called "mast tangs" or "strap tangs", sold in various length, width, thickness and holes.
Check thickness & width of typical installations before buying. ou want 2-3 holes in one end to attach to mast, one in the other end to attach a shroud.
Be sure rivets to attach to mast are SS or Monel, not aluminum, as the shear forces will be quite high.
Jim Casto
NACRA 5.5 & NACRA 5.7
Austin TX
Lake Travis
Re: Adding spreaders / diamonds [Re: jcasto1] #22662
07/28/03 07:14 PM
07/28/03 07:14 PM
West Palm Beach
SingerIsland Offline
West Palm Beach
I had a local shop make one out of Stainless Steel. I used Super Cat's design.
Re: Adding spreaders / diamonds [Re: jcasto1] #22663
07/31/03 06:04 PM
07/31/03 06:04 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
I think the original post is refering to the spreader arm support fitting, not the diamond wire attachments to the mast (ie "tangs" or "hounds"). Since the arm fitting must fit around the mast cross section, these are not readily available for non-beach cat places. Hobie will have it...but Murray's should be able to source it if you get them a part number. Cost will likely be a wash with hobie though.
BTW, you might want to ask what size rivets it needs...I've seen some 1/4" monels used there and those take a special puller to set.
Mike.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Adding spreaders / diamonds [Re: Tornado] #22664
08/01/03 07:26 AM
08/01/03 07:26 AM
APS has the brackets I'm looking for. Although they are for mono's, they should do the trick.
1 registered members (Damon Linkous), 11,722 guests, and 268 spiders.
